03-21-2020, 09:21 PM | #111 |
Rep 1,458
Drives: F10 S55, E93 M3, E89 N54
What can the PS2 set up hit? What more would you need to do to allow you to get to that level? This is all very interesting, thanks for posting all this.
03-21-2020, 09:39 PM | #112 |
Rep 1,299
What I have realize is that David Shoup likes to keep engine running clean meaning try to have zero timing corrections that is why he doesn't push crazy psi right away. Also, correct me if I am wrong but you can have low boost psi but run advance timing which will give you more power at lower psi.
03-21-2020, 09:41 PM | #113 |
Rep 1,299
03-22-2020, 12:36 AM | #114 |
Rep 554
I'm gonna get 500whp with my man D Shoup. I have the inlet, fueling, 3.5 sensor, and the turbo, plus other hardware that will allow 25psi. Tryna make N54 owners upset.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
03-22-2020, 01:45 AM | #115 |
Rep 1,299
03-22-2020, 05:06 AM | #116 |
Rep 554
I don't know just going off D Shoups words. 25 is high and quite honestly I think 22 is max for a daily. Our 5 series are finicky beasts and require more attention when it comes to tuning. 25 might need to happen but I'm about to discover with this HOD, PS2 and D Shoup.
03-22-2020, 12:27 PM | #117 | |
Rep 1,299
03-22-2020, 12:45 PM | #118 | ||
Rep 554
The fueling your getting from stage 2 lpfp seems good in your datalogs. Not sure at what PSI that will start falling off. Remember your inlet is your next blocker to go over 20psi. I have az racer's custom inlet so I'll know soon if we can clear 20 with hod, inlet and PS2. However, if you can clear 20 with an inlet, stage 2 lpfp, and PS2 I would reconsider my HOD.
03-22-2020, 01:10 PM | #119 | |
Rep 1,299
03-22-2020, 04:07 PM | #120 | ||
Rep 554
03-23-2020, 06:41 PM | #121 |
Rep 1,299
We're having to readjust upper range due to overboosting issue. Car running super good and clean. I think one more revision to hold 18psi till at least 6300-6500rpm and I am good until Helix OD.
Here are new logs: https://datazap.me/u/ziekxq/v27-last...=0&data=4-5-22 https://datazap.me/u/ziekxq/v27-seco...=0&data=4-5-22 Before adaptations kicked in: https://datazap.me/u/ziekxq/v27-1st-...=0&data=4-5-22 |
Bmwdoubles_210.00 |
03-23-2020, 09:32 PM | #122 | |
Rep 554
https://datazap.me/u/bmwdoubles
03-23-2020, 09:36 PM | #123 |
Rep 554
$howtime456
How much boost do you run to get 570hp?
03-23-2020, 10:29 PM | #124 |
Rep 1,299
03-24-2020, 11:22 PM | #125 |
Rep 554
23 psi sounds about right for 500rwhp.
03-25-2020, 12:11 PM | #126 |
Rep 1,458
What does the PS2 set up top out at regarding PSI?
03-25-2020, 12:20 PM | #127 |
Rep 1,299
I don't know psi but the way I understand is:
Pump gas (depend on octane): 400-450whp Pump + e85 mix: 500-550whp Pump + port injection + meth: close to/at 600whp 600whp would be max and pushing pure stage 2 to it's efficiency limit I think. |
03-25-2020, 12:40 PM | #128 |
Rep 1,458
Ok, clarification needed... Doesn't the HOD accomplish the same thing as port injection? Or is port injection better?
Maybe it's better cause then you don't have to clean your intake valves!!! Lol, but seriously - I am curious. |
03-25-2020, 01:30 PM | #129 |
Rep 1,299
Helix OD is different then PI but I think you can accomplish same powa! Lol. But HOD with meth injection and you are maxing out pure stage 2. I just don't want to do meth due to pump failure issues I have read everywhere.
03-25-2020, 01:52 PM | #130 |
Rep 1,458
I am gonna do meth just for cleaning and IAT. Not sure on the HOD, with the noise, plus there is a cool intake mani that has pre done ports that might be cool!
03-25-2020, 02:26 PM | #131 |
Rep 1,299
I did read somewhere that they had a fix for this beside bmwdoubles telling me this. I will do HOD and maybe water injection for lower IAT without any meth.
03-25-2020, 05:12 PM | #132 |
Rep 1,230
im at 20psi all around the board.
570 on racegas. 475 on 93. i havent tuned for e85 since i have AIC2 and it uses tuner pro for port injection. Different software from AIC1. we tuned on e40 last yr and made 530hp but that was with a massive fuel leak unknown only putting out 36psi of pressure. Also didnt have PI at the time so we were limited.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
