2010 2011 BMW 5 Series Forum F10 N55 Behind the Grill Intake DIY |
01-19-2022, 01:12 AM | #111 |
Rep 104
Since you have a manual, I think your 4th gear is equivalent to my 6th gear in the 8sp auto trans. Can you do a log in 3rd gear? It will probably be more like my 4-5th gear. My WGDC in 6th gear is around 60-65% @ 5k RPM making 22 psi.
01-19-2022, 11:16 AM | #112 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
This log covers from about 55mph to about 140 mph. I would say it shows about everything it is gonna show. I only say that because regardless of what gear I am in, the ram air intake's advantage is a function of speed. As speed increases, ram air intake will help WGDC. So that is basically all there is to it. I don't think what gear I am in will change that. The slower I go the less impact it makes, the faster I go the more impact there is. I hope this helps.
01-26-2022, 06:56 PM | #113 |
Rep 1,445
Here is a 3rd gear log to redline. This log shows about 485 whp. I'm on e30 but running a pump gas map. Boost is turned down in 3rd to keep my HPFP happy.
https://datazap.me/u/browbmw/messing...38-39-40-41-42 |
Bmwdoubles_194.00 |
01-26-2022, 07:47 PM | #114 | |
Rep 104
Does your intake require removal of bumper for install? Count me in for one of your RAM AIR CAI! |
01-26-2022, 08:19 PM | #115 | ||
Rep 1,445
Anytime you make any changes to how you feed the motor air, you are going to need to adjust fuel accordingly. You'll need a tune for this or the MST intake but it is well worth it. David Shoup is familiar with this intake from a tuning perspective. |
01-27-2022, 10:33 PM | #116 | |
Rep 507
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
01-28-2022, 09:54 AM | #117 | |
Rep 2,595
2015 BMW 535xi
01-28-2022, 10:01 AM | #118 | |
Rep 1,445
within a "normal" range. When you get into the higher RPMs that's when you got to watch it. I have noticed I periodically get some minor adjustments on a random cylinder on lower RPMs, not always 6. It's something to watch. |
01-28-2022, 10:29 AM | #119 | |
Rep 2,595
2015 BMW 535xi
01-28-2022, 02:20 PM | #120 |
Rep 1,445
Here is another log where you can see two 4th gear pulls and barely any timing corrections, each pull has blips on different cylinders (none on 6) but they clear up in higher RPMS... I think the DME is just doing what it's supposed to do and I don't really need to worry about anything... ¯\_(ツ)_/¯
https://datazap.me/u/browbmw/e28-4th...38-39-40-41-42 |
01-28-2022, 03:47 PM | #121 | |
Rep 670
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
02-08-2022, 02:28 PM | #122 |
Rep 1,445
here is another log where I went through 4th 5th and 6th to redline... pegged the speedo! I have started to sell these intakes if anyone is interested.
https://datazap.me/u/browbmw/160-mph...4-5-8-15-20-32 |
02-08-2022, 06:50 PM | #123 |
Rep 507
congrats bro... good work, maybe I'll pull thre trigger one day on this from you
BimmerHausPerformance514.00 |
02-09-2022, 09:43 AM | #124 |
Rep 2,595
Not sure how you extended the MAF wiring, but I MIGHT have found adapters that work.
https://www.ebay.com/itm/254655726572?var=554416090828 They sell both the male and female end, you just gotta crimp your own wires or buy the pig tail version, but tbh I don't really trust their wiring and would rather spec my own GXL wires. The housings came in today and I will be test fitting them later.
2015 BMW 535xi
02-09-2022, 03:59 PM | #126 | |
Rep 1,445
02-09-2022, 04:01 PM | #127 |
Rep 1,445
It all depends on what you are going for. MST probably looks better under the hood, not gonna argue there, but mine is all the way to the inlet and is proven to make more boost. Plus it is louder since the filter is literally outside :-). Sorry for my bias opinion lol
02-09-2022, 04:09 PM | #128 | |
Rep 6
02-09-2022, 04:14 PM | #129 | ||
Rep 1,445
95blkmax216.50 musclesmarinara75206.00 |
02-09-2022, 07:09 PM | #130 | |
Rep 507
02-09-2022, 10:10 PM | #131 |
Rep 2,595
Funnily enough, the male part of the adapter is actually an OEM BMW part. Just verified their adapters work
2015 BMW 535xi
95blkmax216.50 |
02-10-2022, 08:01 AM | #132 |
Rep 670
NICE! what about the female side (the pseudo-MAF)?
