| 12-16-2025, 02:18 PM | #133 |
all I do is test!!6
5460
Rep 1,005
Drives: I lost count of how many2
///M Power-Belgium88948.50 Assimilator1811.50 |
| 12-17-2025, 06:45 AM | #134 |
Rep 1,244
Drives: BMW M3 e92 08 & 330d e90 10
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
| 12-17-2025, 11:05 AM | #135 |
Rep 2,053
Drives: 2020 G20 320i M Sport
Is Hong Kong geo blocked now? I can't access the site from here at all and we're a sponsored vendor of the forum.
CMB Solutions Limited |codemybimmer.ca
Diagnostics/Coding | CarPlay Solutions | iDrive head unit repair & retrofits steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca iDrive Head unit repair services | Remote Coding Package| NBTEVO Retrofit wiring kit + programming |
| 12-17-2025, 03:59 PM | #136 | |
Rep 1,244
Hopefully they'll get back to you to sort it out.
| 12-18-2025, 01:48 AM | #137 |
In The Rain
9032
Rep 6,917
I know it started randomly happening, and I can definitely access it on my phone by turning off my Wi-Fi.
It constantly says Bimmerpost connection has timed out despite the fact that I just managed to make a post through my computer prior. It will load a little bit than it just stops without me changing anything on my end. |
| 12-18-2025, 08:49 AM | #138 |
Rep 2,053
First time I’ve been able to reach the website this whole week without a VPN.
Hope it stays this way.
| 12-18-2025, 12:35 PM | #139 | |
Rep 1,244
Anyway, apptest sorted it for me, seems much quicker now too! ![]()
| 12-18-2025, 01:24 PM | #140 |
Rep 3,412
Working on WiFi now
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black 2018 VW Passat SEL IG: @060Motorsports / @junglehour |
| 12-21-2025, 06:59 AM | #142 | |
![]() ![]() ![]() 73
Rep 461
I'll PM you once I'm back home, but honestly there's clearly something majorly wrong and has been for at least half a year; you really need to identify whatever it is, or just turn off whatever security feature started this in the first place, because it's going to kill the forum. I'm already finding that I'm using Reddit for my BMW discussions because it's so much more convenient, if this isn't fixed very soon this entire forum is quickly but quietly going to reach a tipping point where people will stop bothering to try visiting and it'll spiral from there, probably irrecoverably. I'd hate to see that happen. |
| 12-21-2025, 10:47 AM | #143 |
Rep 1,244
Re-subscribed because it just happened again earlier today
, had been ok since the fix until then.
| 12-25-2025, 07:45 PM | #144 |
In The Rain
9032
Rep 6,917
I hope they fix whatever is happening. I don’t know what is causing it. Maybe instead of a blanket IP ban for bots they can do it a little bit differently.
| 01-04-2026, 11:23 AM | #145 |
![]() ![]() ![]() 645
Rep 418
Drives: Z4 M40i HS
Unable to open bimmerpost.com on Mac
Using Safari on my Mac opening the site is very much a hit or miss, getting cannot find server error. Firefox or Chrome works on same computer. Safari is my main browser and not looking to switch to either for various reason.
Any settings in Safari that may interfere? Mine is all the defaults with only the 1Password extension. private window in Safari does not help |
| 01-04-2026, 06:22 PM | #146 | |
Rep 1
I've read through some of the prior posts in this thread mainly on account I am experiencing similar issues. But behavior you observe, given two of three browsers on the same computer are able to connect, is different. Even a chance Safari connects via proxy whereas Firefox and Chrome do not ? Or vice versa ? Or some other difference in network connection between browsers ? My experience and there is indication of same for others is the connection to the *.bimmerpost.com server is blocked at an IP address level. Hence changing your IP address via use of a VPN restores ability to connect. If you have option to use a VPN, it would be a great troubleshooting tool for you. As in are you able to connect via all browsers while using a VPN ? Best, |
| 01-04-2026, 11:49 PM | #147 |
Rep 2,686
I’m back for my bi-monthly request to have me unblocked for whatever reason I’m getting blocked every couple of months. I will send a PM as usual.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
| 01-05-2026, 01:25 PM | #149 | |
Rep 1,244
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 01-05-2026 at 04:27 PM.. |
| 01-05-2026, 02:04 PM | #150 |
Rep 0
I just tried with a VPN and no such luck.
Edit: switched locations a few times and one started to work. We will see how long this lasts for. |
| 01-06-2026, 06:10 PM | #152 |
all I do is test!!6
5460
Rep 1,005
… for bots! 😂
On the chance your a real person, feel free to PM your ip address to me and I can take a further look. Of course saying you tried from ‘multiple ISPs in new york’ doesnt exactly sound right, so just one of those will be enough lol Of course, if that’s actually true (you use multiple ISPs in New York), it speaks to a you problem and not an IP block. If it really is happening like that, the more (accurate) information you can provide the better Last edited by apptest; 01-06-2026 at 06:17 PM.. |
vreihen1630861.50 ///M Power-Belgium88948.50 |
| 01-07-2026, 12:26 AM | #153 | |
Rep 1,098
ROTFLMAO!
![]() Quote:
apptest5459.50 |
| 01-09-2026, 07:46 AM | #154 |
Rep 418
Drives: Z4 M40i HS
| Bookmarks |
