2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
02-27-2020, 10:52 PM | #1585 |
Rep 188
Hey Turbo, I think the new tips look great. My personal opinion, the tips should just slightly poke out of the diffuser. Good luck with yet another mod to your never ending project
lsturbointeg9167.50 |
02-28-2020, 11:58 AM | #1586 |
Rep 14,521
Slightly like an inch maybe? You know because the tips just clamp on I'll probably take several pictures at different lengths and see what everyone thinks is good. Yea. Projects seem never ending lol
02-28-2020, 01:56 PM | #1587 | |
Rep 188
Good luck man! |
02-28-2020, 03:29 PM | #1588 |
Rep 207
No matter what color, nothing beats a clean car
02-29-2020, 09:52 AM | #1589 | |
Rep 4,209
lsturbointeg9167.50 benacto348.00 |
02-29-2020, 02:40 PM | #1590 |
Rep 538
Finally washed the car since November and popped on some CF M4 style mirror caps
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
Ickdeep5727.00 ezaircon4jc4557.50 |
02-29-2020, 02:58 PM | #1591 |
Rep 14,521
that actually looks perfect to me Ick!
02-29-2020, 03:46 PM | #1592 |
Rep 206
Getting a light polish and wax done today. Previous owner let water spots SIT for lord knows how long
02-29-2020, 03:49 PM | #1593 |
Rep 14,521
looking good
02-29-2020, 03:52 PM | #1594 |
Rep 14,521
just ordered the Vibrant 11619 j style o2 sensor to hopefully prevent the CEL coming on when i install the Catless VRSP dp in.
jayster0966209.00 |
03-04-2020, 01:59 PM | #1595 |
Rep 63
Oil change, washed it, added 12mm rear wheel spacers. Still need to lower it and do a paint correction.
Ickdeep5727.00 lsturbointeg9167.50 |
03-14-2020, 07:57 AM | #1596 |
Rep 14,521
Currently changing the oil using LIQUI MOLY MFC, oil filter housing gasket, oil cooler gasket and belt all installed courtesy of Burrninja himself! everything ordered from ECS Tuning. comes to find out it looks like my Indy mechanic never actually changed out my oil filter housing gasket 2 years ago by looking at the gasket as it was pretty hard and not soft? we're suspecting he changed the oil cooler gasket instead as it still looked new. pretty ridiculous if you ask me! anyways, gonna use some simple green to scrub out all the oil cake build up on the motor where all the pulleys are with a wire brush. also gonna remove the cover underneath that protects the engine since it's been drenched in oil!
also my 4" tips came in! can't wait to get these on
03-17-2020, 07:11 AM | #1597 |
Rep 14,521
been busy that last couple of days just cleaning up all the oil sludge that was left on the motor when i had the oil filter gasket housing replaced. as most of you know when it leaks it drips onto the belt which than flings all over everything. Much cleaner now!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 03-17-2020 at 07:21 AM.. |
03-17-2020, 07:21 AM | #1598 |
Rep 14,521
what a PITA LOL! so because the gyms are now closed in Ohio i decided to put my energy into installing the VRSF catless dp. so there were quite a few issues i ran into. the 2nd nut bracket was really hard to get off because of how much room there was to work with. i eventually got it off but it did take some time. the 2nd was no matter what i do there just wasn't enough room to get the dp off with the exhaust still on. so that was the 3rd issue was removing the whole exhaust system including removing the lower brace bracket. once the exhaust was dropped it was just a matter of wiggling off the dp.
here she is flying high! exhaust is down and here's the OEM dp! will post more progress pictures when i start reinstalling everything
03-18-2020, 07:37 AM | #1599 |
Rep 14,521
alright, got the Vibrant defouler installed along with all the OEM o2 sensors. per discussion in the Vibrant defouler thread i used the middle size restrictor and i have it facing upward as recommended. hope this helps other people interested in doing this as i couldn't find any info on which defouler to use which restrictor to use and the fact it needs to face up!
so after everything was installed i'm happy to report there's no CEL!!!!!! just in case someone is researching i attached the link regarding the Vibrant defouler https://f10.5post.com/forums/showthread.php?t=1698863 thanks to top ramen for the info on restrictor size during his research and thanks to ziekxq for info regarding which way the vibrant faces and which 02 sensor it's to be installed on
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 03-18-2020 at 07:45 AM.. |
fletchf69.50 ezaircon4jc4557.50 |
03-18-2020, 06:55 PM | #1601 |
Rep 277
03-18-2020, 10:29 PM | #1602 |
Rep 305
Nice. Please post up some sound clips.
03-19-2020, 07:01 AM | #1603 |
Rep 14,521
03-21-2020, 04:09 PM | #1604 |
Rep 119
got a quick wash in before the rain and installed the new trunk spoiler.
Sup
lsturbointeg9167.50 ezaircon4jc4557.50 |
03-22-2020, 11:03 AM | #1605 | |
Rep 538
Installed a K&N drop in just now. Looks like my cars filter hadn't been replaced in more than 20k mi. I'm at 65k now after having put 4K on.
