2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Off-Topic Discussions Board Garage lighting recommendations
      03-18-2023, 05:03 AM   #1
larsek
larsek's Avatar
Germany
139
Drives: F82 M4
I will be renovating my garage this spring.
For the floor I am either buying Ribtrax floor tiles similar to this style (click!) or paint it with anthracite floor paint.
The walls will be painted anthracite or dark grey, similar to the walls you see in this video (click!).
Now I am unsure about the lighting... Do you have any recommendations/ ideas?
The layout of the garage is as follows:
      03-18-2023, 08:16 AM   #2
2000cs
Drives: Potato
https://www.garagejournal.com/
Look through those forums and then ask them.
Anthracite will soak up the light. Are you wanting to set a mood, do mechanical work or detail. Each of those would give a different lighting requirement.
      03-29-2023, 11:07 AM   #3
unluky
unluky's Avatar
7526
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Not in a garage, but in a display room next to me they installed those roof hex lights and they throw a PERFECT light. I have newish lights in my garage and I am thinking of changing anyway - they look fantastic.
Not these, but just for reference.
https://www.amazon.com/LZHOME-Hexago...7-857e17e03685
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
vreihen1615242.50
      03-29-2023, 11:47 AM   #4
diirk
diirk's Avatar
1032
Drives: 2023 X3MC BGM
Hex lights are all the rage and they look cool.
I picked up a bunch of LED tube lights at Costco. They can be linked inline up to 4 units, which is also nice and were relatively cheap.
You can see a few of them in the pic...
23 X3MC BGM. MSS. H&R 12mm spacers
20 4Runner
18 Cayman GTS
15 Beetle Vert
      04-01-2023, 11:10 AM   #5
brettcp
Drives: 2012 E93 M3
I did these in 2019, they look great. Very clean, perfect color temperature. Never had any issues in the 3-1/2 years they've been installed. Will try to get a photo later.
      04-11-2023, 08:36 AM   #6
unluky
unluky's Avatar
7526
This is basically when I have in my garage/shed. It has lower trusses so I put a string of them on the middle in between the other LED tubes I have on the outsides to get rid of the shadows in the middle. Added benefit - they ones I used have motion sensors in them so they kick on when I pull in. They work great and were cheap.
diirk1031.50
      04-11-2023, 12:22 PM   #7
///MPhatic
The Seeker
///MPhatic's Avatar
13856
Drives: OG M2 • Exige
I just daisy-chained a bunch of inexpensive Amazon LED's in my basement. I didn't break the bank, and it works great.
New Shop Lights. by Andrew Thompson, on Flickr
tcphoto3531.00
      04-11-2023, 01:16 PM   #8
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I'm renting at this point but shared a link below from a YouTube Channel that I follow.
      04-11-2023, 01:22 PM   #9
CarsAndGuitars
Drives: 2022 M240i
Still thinking over the plan, but I am considering ~6-9 of these https://www.ledlightingwholesaleinc....3.htm?CartID=1 for my 20x20 / 8.5' ceiling garage. Initially, I am not going to add lighting to the area above the garage door when opened, since I usually have the door open anyway.. tbd
2022 BMW M240i Portimao
Gone: 2020 Genesis G70 3.3T | 2018 Audi A5 SportBack | 2015 Challenger Scat Pack | 2011 Mustang V6 | numerous others..
      04-11-2023, 02:21 PM   #10
rbryantaz
Drives: 2007 E70 4.8i, 2008 E90 335i
2008 BMW 335i  [7.67]
2007 BMW X5 4.8i  [10.00]
That light seems to be for a specific case of wanting a UL listing or something that probably isn't needed in a home garage: "The fixtures allow installers to avoid bypassing the ballast and adopt the energy-saving benefits of LED technology while keeping the product UL listing intact."
I have had better luck with native LED light strips than the CFL tube replacements. Costco has the LED tubes cheap and they work as a retrofit but I have been happier with a LED strip lights that I got from amazon.
I got these to replace my old fluorescents that had buzzing ballasts I probably could have bypassed the ballast, etc but it was time for something new lightweight, etc:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller.
      04-11-2023, 02:50 PM   #11
CarsAndGuitars
Drives: 2022 M240i
Just about every review I've read of any led shoplight on Amazon has a noticeable number of people reporting high failure rates in 1-2 years or less.
That said, I did not realize the tubes I selected were CFL. Hard pass.
      04-11-2023, 06:13 PM   #12
rbryantaz
I think the ones you showed were an LED in a FL style tube. That works fine but the tube is really just wasted plastic.
The only issue I had was that one of them had a bad solder on the power line when I got it. I contacted the seller and they gave a fair discount and re-soldered it.
I have only been using 2 of the 4 I bought. I mounted the second pair last night and plan to connect them tonight. I just need to decide if I want to add a front and rear switch or just turn them all on together.
-Rich
      04-12-2023, 02:16 AM   #13
CC M3C X
Drives: M3 Comp Xdrive
So I’d have to do some digging to see exactly which lights these are but… In my shop and in the main garage our builder’s electrician highly recommend these LED light panels. I considered the hex led lighting that has gained popularity lately but my ceiling is at about 17 feet and I don’t know how functional the hex lighting is from that height. They also seem to create a crazy amount of reflection which I am not a huge fan of. Anyhow, super happy with the ones we have.
      04-12-2023, 09:35 AM   #14
CarsAndGuitars
Drives: 2022 M240i
-Rich
Thanks, any opinions on these?
https://www.lowes.com/pd/Eveready-Ev...?user=shopping
