2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Drivetrain message HELP!
      03-09-2018, 12:02 PM   #1
Cmfigueroa16
Drives: 2012 535i x drive
Guys help,
I installed JB4 on my F10 N55 and I was driving to work this morning I got this message on my screen.
Could I have installed it wrong? Or can there be an easy fix?
      03-09-2018, 01:28 PM   #2
Stück
Stück's Avatar
That message is like getting a text message on your phone and asking someone what it might say before you open it and see....
The faults need to be read out to make a determination as to the cause, real or user introduced.
      03-09-2018, 03:25 PM   #3
5soko
5soko's Avatar
333
Drives: M5
haha i like that one...
Read the bmw specific codes and get back to us OP.. We can help from there.
But as a start, check all the connections and such of the jb4 to start off.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      03-09-2018, 03:41 PM   #4
Cmfigueroa16
How do I find out the code?
ey2001310.00
      03-09-2018, 07:35 PM   #5
Stück
Stück's Avatar
Looking at your post history briefly I don't think you need to be reading out codes or trying to work on your own vehicle. I would recommend that you take the vehicle to a competent independent shop that specializes in BMWs. Leave the car there and have them call you when they know what it needs.
      03-10-2018, 12:59 AM   #6
AZ-MCRacer
AZ-MCRacer's Avatar
306
Drives: 2022 G82 M4, 2013 F10 N55
If you just installed a JB4, use a USB cable or Bluetooth and read codes from it. You will need one or the other to use the JB4, if you do not have it, take off the JB4 until you do.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD!
1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped
      03-11-2018, 06:34 PM   #7
Cmfigueroa16
My check engine light came on
the codes are
138701 radiator shutter. Top upper stop. Recognized to early.
122108 BOV plausibility - ignore tuner code
120308 boost pressure lower then expected
18001 catless downpipe detected
108F01 boost pressure lower then expected.
Any idea what the radiator code would mean?
      03-11-2018, 08:43 PM   #8
Stück
Stück's Avatar
It is a plausibility fault. The upper stock switch is sending a signal before it is plausible for the shutters to have hit it after being commanded open / closed. It will require a competent technician to diagnose. Reading out fault codes isn't diagnosis.
Looks like you have more important faults there though, multiple boost pressure lower than expected is concerning.
      03-11-2018, 09:06 PM   #9
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
As long as the battery was unplugged during install (and you haven't shorted your ECU), you've just wired it improperly and it can be corrected without harm more than likely. Double and triple check your wiring.
2019 M5C Matte MBB / Tartufo
      03-12-2018, 01:26 PM   #10
Cmfigueroa16
Will do thanks.
      03-12-2018, 01:38 PM   #11
Cmfigueroa16
Do I have to connect the fuel pressure sensor to the jb4?
Is that really optional?
      03-12-2018, 02:51 PM   #12
Stück
Stück's Avatar
Does it have to be connected? No. It just allows the JB4 to sample the high pressure fuel rail pressure in real time and inter-modulate the data the DME sees to allow you to push the envelope well into the realm the DME knows is DANGER BAD regarding high pressure fuel rail pressure.
The "flex fuel" wires not being installed properly isn't the source of your issue.
      03-12-2018, 06:41 PM   #13
Cmfigueroa16
So I just got back from my mechanic and he said that the drivetrain malfunction message might of popped up becuase about 1 week ago I got a flat tire and I found one the same size but used for sale and put it on. He said that that can send a message saying something wrong with the transmission. Anyone ever heard of this?
      03-12-2018, 08:57 PM   #14
Stück
Stück's Avatar
Find a competent independent BMW specialist with certified BMW technicians and ditch your "mechanic"
      06-29-2019, 09:41 PM   #15
JLBimmer
Drives: 2016 BMW 435ix Gran Coupe
Getting the same fault codes for low boost on EWG N55
So I have 2016 435 ix Gran Coupe with EWG
Mods: Intake, axleback exhaust, JB4 Stage 2
Today I ran it WOT and then noticed wasnt hitting boost target on Map2 (14 psi) so switched to Map 5 (Auto) and still didnt hit targets on pull 2. Missed by 6PSI. So gave it another run this time got the Fault Code Drivetrain Malfunction... yadadada reduced power blah blah. Stopped read codes and got these two
120308 Boost Pressure Lower than Expected
108F01 Boost Pressure Lower than Expected
So since my N55 is using and EWG I dont have Boost pressure solenoids to check. i also dont see andy vacuum lines. How do I troubleshoot this?
My first guess is boost leak somewhere.I deleted codes and restarted. The car feels strong but not as strong and I cant get beyond 7psi now
My second guess and I hate this one but a may be a bad wastegate?
Any thoughts on DIY trouble shooting this?
      07-01-2019, 01:59 AM   #16
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
diverter valve maybe?
      07-03-2019, 03:30 PM   #17
JLBimmer
So how do I test this. Is there a way to fun the test with the JB4
      07-14-2019, 07:51 AM   #18
NYC535iowner
Drives: 2013 535i X-drive
So recently I got that message. It used to go away after turning off the car.
Took it to the mechanic and finally found out what it was. For me it was the turbo solenoid that was reading bad pressure. It will say too much pressure and low pressure at the same time.
After replacing it it hasn't come back.
      07-14-2019, 11:51 AM   #19
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra 5MT
2013 BMW M6  [10.00]
Definitely should be able to push more than that, even on a stock car map 5 peak boost I've seen is 16-17 psi on my 2011 PWG 535i xDrive
