2010 2011 BMW 5 Series Forum F10 MHD tune didn't pass emissions test |
07-02-2019, 02:13 PM | #1 |
Rep 105
I just flunked the emissions test in Ohio...
The dude was a dick, he asked me to pop the hood and told me he was looking for cats.. asked me if I modified the car. I guess I will flash back to stock and try again. I have no ses lights.... my buddy with the same set up passed |
07-02-2019, 02:48 PM | #2 |
Rep 21
Where at in Cleveland? This is one of the hangups with me and why I haven't gotten a tune yet.
I tried to get tested back when I had my Subaru at the one in West Park and some ultra try-hard, Heath Ledger looking dude laid in a puddle to look for cats because my car was too low for the mirror... popped the hood and saw I had an aftermarket catted downpipe and failed me immediately. Even if it was a stock downpipe, the cats aren't visible under the car. I swapped stock back on and got tested at the one in Berea and they didn't even use a mirror or pop the hood, which showed I wasted a couple hours swapping it out. |
07-02-2019, 03:23 PM | #3 | |
Rep 105
There is a do it yourself in Berea that my buddy passed. I'm going to flash back to stock and take it up there. |
07-02-2019, 03:40 PM | #4 |
Rep 1,299
You have to check OEM/Catted-DP option in order to enable catalytic converter monitoring on. Otherwise on emission test it will show that catalytic converter is not supported and you will fail the test. Even going back to stock map you have to change this setting.
By default MHD disables this monitoring so you have to go into flash option and enable this. Also, you can go into read error codes and there it will show you if your emission systems are ready or not. Last edited by ziekxq; 07-02-2019 at 03:50 PM.. |
07-02-2019, 04:20 PM | #5 | |
Rep 105
07-02-2019, 07:17 PM | #7 |
Rep 590
07-02-2019, 07:20 PM | #8 | |
Rep 1,299
Not sure about bootmod3 as I have not used it or did research on it. For me MHD was plain and simple and to the point . Last edited by ziekxq; 07-02-2019 at 09:26 PM.. |
07-02-2019, 08:31 PM | #9 |
Dream crusher
984
Rep 2,421
Flash to stock not stock 0
IG: @bmwdoubles |
07-03-2019, 12:12 AM | #10 |
Rep 14,522
OH doesn't have emission test? I've been here for 7 years now or are you guys talking about dealership warranty work?
07-03-2019, 07:21 AM | #11 |
Rep 105
07-03-2019, 11:35 AM | #12 |
Rep 14,522
Huh? Not Toledo
07-05-2019, 09:52 AM | #14 | |
Rep 105
I went back to stock with cat/downpipe checked. It's very hot but the car feels sluggish...can't wait to get the tune back in the car |
07-05-2019, 10:56 AM | #15 | ||
Dream crusher
984
Rep 2,421
- on cold start idle for 2.5 minutes with ac on max and defroster on. Basically max load on idle. - drive under 30mph for about 2 minutes and never clearing 3k rpm and no stopping. - drive 50mph for about 5 minutes also never clear 3k rpm on any shift and no stopping. - let car idle 5 minutes This worked for me. Here's the recommendation
IG: @bmwdoubles |
07-05-2019, 12:45 PM | #16 | |||
Rep 105
Thanks again |
04-12-2022, 01:39 AM | #18 |
Rep 36
Quick question guys
So lets say I get the VRSF Downpipe installed on my 2012 535 and have the stage II MHD tune Can I pass emissions in Illinois if I do the following 1)Flash car back to stock 2) Have the catted DP option checked 3) Do the drive cycle? I don't understand what all this other stuff about a DP fix is that I am reading on f30 post |
04-12-2022, 02:24 AM | #19 |
Rep 36
One more note.
In Illinois: Remember, vehicles are rejected when more than two (2) non-continuous readiness monitors are “not ready” for 1996 to 2000 model year vehicles, or when more than one (1) non-continuous readiness monitor is “not ready” for 2001 and newer model year vehicles. Additionally, the catalyst monitor must be “ready” at the time of any retest after a vehicle failed an initial test for any catalyst code. So looks like we can have one non continuous monitor show up as "not ready". Do I even have to flash MHD back to stock? |
