2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Parking Brake Failure
      01-26-2023, 06:42 PM   #1
Casa
Casa's Avatar
Drives: 520d M Sport F10
Hello all,
It’s great to be here and a proud member of this innovative community.
Im new here and just signed up as I want to seek some guidance on a parking brake failure on my F10 2013 which only appears in cold or wet weather. Throughout the summer it’s perfectly fine. The brake functions it’s just the warning light that keeps triggering.
I think I’ve found the problem so I am after the spec or BMW part number of the o ring on brake caliper housing (photo attached), which acts as a sealant to prevent moisture from entering the internals of the actuator.
Any help much appreciated.
Many thanks
Casa
      01-27-2023, 09:01 AM   #2
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Welcome to the forum. Unfortunately you never stated if it was front or rear.
Here's a link to one of the online part database sites. You can enter the last 7 digits of your VIN...or select the correct tabs...then go to the brake diagrams. From there you should be able to find the part nbr in the index below the diagrams. Once you have the 11 digit BMW part nbr...you can them easily shop using the part nbr (type "BMW xx xx x xxx xxx" {where x=the actual part nbrs} into a google search).
www.bimmercat.com
Example: front brakes
Example: rear brakes
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
Casa1.50
      01-27-2023, 09:58 AM   #3
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
www.bimmercat.com
Parking brake is the rear only, no?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      01-27-2023, 01:09 PM   #4
SWFLf10
SWFLf10's Avatar
I’ve never seen or heard of it on the front, believe it’s only rear.
And I would imagine there is a brake caliper rebuild kit that would include that oring if it’s not available seperately.
Casa1.50
      01-27-2023, 01:18 PM   #5
Casa
Casa's Avatar
www.bimmercat.com
Thanks so much — it’s on the rear.
      01-27-2023, 01:19 PM   #6
Casa
Casa's Avatar
It’s definitely the rear.
      01-27-2023, 01:30 PM   #7
Casa
Casa's Avatar
Thanks so much. Can you recommend one that I can use as BMW sadly don’t supply one. Much appreciated.
      01-27-2023, 01:49 PM   #8
SWFLf10
SWFLf10's Avatar
Unfortunately all I’m seeing is the whole caliper or the seal for the piston, which seems to look a bit different. This is the part number I’m finding. 34206786064
Another option would be to go to a local industrial supplier like Grainger or Fastenal and see if they can measure the oring and match it. An issue here is not knowing exactly the makeup of the rubber material. It can swell or be damaged if you use the wrong rubber incompatible fluid. In industrial applications where I work, Viton is usually specified because it’s more resistant to various additives in hydraulic systems.
Casa1.50
      01-27-2023, 10:38 PM   #9
Qsilver7
Qsilver7's Avatar
HA! You guys are absolutely correct…I read right past “parking brake”. I even reread the original post several times to see if I missed front or rear. I guess “parking” didn’t register in my brain.
      01-28-2023, 03:02 PM   #10
Unspec
Unspec's Avatar
1301
Rockauto has the rebuild kits
Just seals:
https://www.rockauto.com/en/moreinfo.php?pk=13370113
https://www.rockauto.com/en/moreinfo.php?pk=3766350
https://www.rockauto.com/en/moreinfo.php?pk=5632164
https://www.rockauto.com/en/moreinfo.php?pk=3059688
Entire rebuild kit:
https://www.rockauto.com/en/moreinfo.php?pk=13650357
Ebay option:
https://www.ebay.com/itm/134326077709
https://www.ebay.com/itm/115578417099
UK option (from Burnley):
https://www.ebay.com/itm/334325613583
_________________
Ebay search
Hope these options were helpful
2015 BMW 535xi
Casa1.50
SWFLf10373.50
      01-28-2023, 05:32 PM   #11
Casa
Casa's Avatar
Superb. Thanks so much. Hopefully this will fix the issue of my parking brake failure which is driving me nuts. I’ll keep you posted.
      01-29-2023, 07:22 AM   #12
Casa
Casa's Avatar
One more question where is the sensor located in the EMF that triggers the parking light failure when there’s moisture in the unit ?
      01-29-2023, 10:52 AM   #13
Unspec
Unspec's Avatar
1301
There isn't one. Your motor is likely just going bad
2015 BMW 535xi
Casa1.50
      01-29-2023, 11:38 AM   #14
Casa
Casa's Avatar
Just a silly question from my side — how does it know it’s going bad and pop the failure and auto hand brake light on dash?
Thanks so much
      01-30-2023, 07:57 AM   #15
SWFLf10
SWFLf10's Avatar
Thanks so much
Just guessing here, but the computer could sense the motor is drawing more current that it is supposed to because it’s getting stuck and then throws the error?
Casa1.50
      01-30-2023, 12:36 PM   #16
Casa
Casa's Avatar
You’ve been ever so helpful — thank you. One more. Is is normal to get the Autohold error and parking light failure together as a fault.
      01-30-2023, 01:06 PM   #17
bk_mike
Drives: F10 550ix
Yep the autohold uses the EMF to hold the car.
Casa1.50
SWFLf10373.50
      01-31-2023, 06:50 AM   #18
HighlandPete
Drives: BMW F11 535i Touring
Autohold uses the service brakes, (the hydraulic system). Not the electric parking brake.
Casa1.50
      01-31-2023, 11:59 AM   #19
Unspec
Unspec's Avatar
1301
This is correct. From newTIS:
The automatic hold function is activated using a button behind the parking brake button. The button is connected to the Dynamic Stability Control (DSC). When the function is selected, the vehicle is hydraulically braked from the first application of the brake by the DSC until it comes to a complete halt. When the engine is switched off, the parking brake assumes the holding function.
Which is why autohold and parking brake are interlinked and both are disabled if there is a parking brake failure: it cannot do the last sentence of "parking brake assumes the holding function" if the parking brake is malfunctioning, leading to a risk of a vehicle rolling away when drivers expected it to be held.
2015 BMW 535xi
Casa1.50
      01-31-2023, 02:53 PM   #20
HighlandPete
Yes, I understand that the two are linked for sequential function.
My understanding, the OP's EMF is working, even though getting a warning. Interesting to know if Autohold is also working and the EMF takes over when switching off.
If so, I'm also minded the EMF may be drawing more current when damp, triggering the warning.
Casa1.50
      02-19-2023, 01:55 AM   #21
Casa
Casa's Avatar
All
Problem has now been resolved. It was water ingress in the base of the boot (trunk) and this was getting to the connector of the EMF module. We cleaned it out and let it dry and now hey presto it’s all good.
The actuator resistance was 1ohm on the cables so new it wasn’t the EMF actuators.
I have videos if anyone is interested in the process if you ever get this problem.
Thank you all so much for your valuable feedback and patience in answering my questions.
Have a lovely weekend all.
Casa
      03-11-2023, 09:01 PM   #22
alfredsadiku
Drives: bmw
All
Casa
hey man please can i have your contact can you help me with this is driving me crazy can you please help me with a video or guidance i have exact same problem and spend quite some money untill now to fix this... failed so far
