2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions AC Intake Location
      08-15-2017, 01:39 AM   #1
HarinderG
HarinderG's Avatar
13
Drives: 2015 535i
AC Intake Location
I've seen a bunch of tutorials online showing how to fix the odor that comes from the air vents. I got a can of Lysol spray, but I'm not sure where the AC intake is located.
Is it below the wipers?
2013 535i (totaled)
2015 535i
      08-19-2017, 01:33 PM   #2
HarinderG
HarinderG's Avatar
13
Drives: 2015 535i
bump
2013 535i (totaled)
2015 535i
      08-20-2017, 11:38 PM   #3
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
The cabin filters(this car uses 2), if you feel the need to change it, is located under the glove compartment on the passenger side. Part #64119272642.
      08-20-2017, 11:42 PM   #4
HarinderG
HarinderG's Avatar
13
Drives: 2015 535i
any idea where I can grab new filters?
sorry I'm new to the Bmw world
2013 535i (totaled)
2015 535i
      08-21-2017, 12:16 PM   #5
Google the part number(s).
      08-21-2017, 01:22 PM   #6
HarinderG
HarinderG's Avatar
13
Drives: 2015 535i
Also, if I replace the air filters, will it fix the wet sock smell whenever I turn the AC off?
      08-21-2017, 03:00 PM   #7
Aaron@Autosource
98
Drives: F110/F22
http://www.ebay.com/itm/272789805992
It should, yes-
      08-24-2017, 08:00 AM   #8
txoid
Drives: f10
It will if the smell is coming from the filter. There are ways to remove the smell if it's still there after changing the filter. A carbon filter sometimes help more than the paper filter.
Search youtube.
      08-24-2017, 11:43 AM   #9
I think he means the intake prior to the filters.
Should be passenger side below the windshield. Look for a grille/grate of some sort.
      08-25-2017, 08:41 PM   #10
txoid
Drives: f10
here you go.
      08-25-2017, 09:08 PM   #11
HarinderG
HarinderG's Avatar
13
Drives: 2015 535i
Originally Posted by txoid
here you go.
Is the hole adjacent to the area he's working on the intake for the blower?
See attached picture.
2013 535i (totaled)
2015 535i
      08-25-2017, 09:30 PM   #12
txoid
Drives: f10
That part is a drain. Not 100% but that's what it looked like when I saw it on my car. The opening from the windshield trim goes into that.
      09-16-2017, 12:42 PM   #13
AldoNY
Drives: 2014 550i x drive
Can anyone confirm if we snake a tube down the center vent and spray the cleaner though there to get to the A/C could, I'm thinking that's where the smell is coming from, probably a mold build up .
      06-08-2018, 07:24 PM   #14
FiveFiftyEye
Drives: 2011 550i M Sport
Hi AldoNY
Did you find the cabin air intake vent. I've got the same issue on my f10, nasty odor from vents, but only when the AC is off. When turn on the AC there's no smell out of the vent at all. I'mthinking the same, to spray a can of Klima in the intake hose. Might even try Tilex mold mildew cleaner.
Has anyone here had any success with this issue?
Thanks!
      06-15-2018, 09:56 AM   #15
eghmsport
Drives: 2011 550i M Sport 6sp manual
I have not had the smell but I have had to replace the blower for my 550i.
The intake for AC is on the front blower housing just below and to the left of the passenger side brace in the video. It is covered with a piece of dark large cell foam. This area goes the blower fan. You can spray something into this area and hope that it goes to the source of the smell but the only way to get to the bottom of the housing is to take the blower completely out. If you remove the filters in the cabin , I believe you could spray back towards the fan housing.
Make sure your car is draining the moisture from the fan housing via the drain tube (where you see water dripping under you vehicle when the AC is on). I have had other vehicles where the drain tube was clogged or partially from debris or insects and moisture backed up causing a smell.
Eric
      06-24-2018, 01:34 PM   #16
mrashton
Drives: 2017 G32 6GT; 2014 F45 218i
The foul odour via the vents is generally caused by a bacteria build up on the AC evaporator which is accessible by taking the cabin filters out of their housing giving the necessary access. I've had mine professionally cleaned where they remove the cabin filters and spray a specific chemical directly onto the evaporator while the aircon is on with the engine running. You can buy a can of AC cleaner which you put in the rear passenger footwell, release the contents which are then circulated through the AC system.
Here is a link to BMW's process:
https://www.newtis.info/tisv2/a/en/f...ments/GiMdQbtM
      11-08-2018, 06:42 AM   #17
Falcon20x
Drives: 201q BMW F10 528i
This is how I sprayed the Lysol into the a/c air intake
This is a video to show the location of the air conditioning system air intake on a BMW F 10 To get rid of the mildew smell you need to spray Lysol directly into the air intake of the A/C.
To save time on the video, I unscrewed all the bolts and remove the clips before starting the filming. It takes about 10 to 15 minutes to do the all procedure.
Do not run the A/C in max or recirculating mode. Doing so will automatically close the isolation door to the fan intake vent, it will keep the Lysol from going into the system.
      11-08-2018, 01:34 PM   #18
HarinderG
HarinderG's Avatar
13
Drives: 2015 535i
Thank you! I will now spray Lysol in there from time to time.
2013 535i (totaled)
2015 535i
      12-24-2018, 09:56 PM   #19
joemulder
Drives: bmw 535xi
update
Can someone confirm that this part is a drain?
I sprayed a can into this location today..
Don't know what's going to happen now..
I am new here. Thank you for your help!!!
      01-03-2019, 12:57 PM   #20
Andrei525
Drives: BMW 525d
Indeed, that one is a drain.
When put back the upper cover pay attention as it can bend and the water/dirt is going around the cabin intake air fan and will smell funny inside your car.
