2010 2011 BMW 5 Series Forum F10 removing OEM seat for aftermarket seats |
03-27-2020, 05:27 PM | #1 |
Rep 14,521
just toying with the idea but what errors would come up and would it be possible to have them coded out?
03-29-2020, 05:09 PM | #2 |
Rep 1,254
I can't imagine any codes coming up because of the seats but again its BMW
I think only if you touch seatbelts that would make car angry. what do you have in mind?
lsturbointeg9161.00 |
03-29-2020, 05:45 PM | #3 | |
Rep 14,521
so i was able to find a seat bracket specifically made for the F10 for both the driver and passenger side $140 each. here's some info: PLANTED. SEAT BRACKET TECHNOLOGY. Planted Seat Bracket- BMW 5 Series [6th Generation, F10/F11/F07 Chassis] (2011-2016) - Driver / Left •Universal design will work with most racing seat designs (Sparco, Momo, NRG) •Made from thick steel and hand welded to ensure superior strength •This is a direct bolt on There is extra space on the bracket for drilling your own hole pattern, if using a slider with a less common hole mount •These are drop shipped directly from Planted Technology, there may be a small handling time aside from ours. •These are made to order. The Planted Seat Bracket is a vehicle specific bracket used as an adapter between the floor of the vehicle and an aftermarket seat and it's accessories. Because the floor of each vehicle varies and typically is not flat, a vehicle specific Seat Bracket is required for installing an aftermarket seat. We create each seat bracket using the floor of the vehicle as a reference. We literally bring each vehicle into our development center so we can create the best fitting, bolt in, universal seat bracket possible. For more specifics on installing a Planted Seat Bracket and what other components you may need please refer to our installation instructions and our Frequently Asked Questions section. UNIVERSAL. STRONG. SECURE Planted Seat Brackets are laser cut from 3/16 inch thick steel and hand welded to ensure weld penetration for superior strength. Each bracket is pre-slotted with hole patterns to accept sliders from most major seat manufacturers like Braum, Bride*, Cipher Auto, Cobra**, Corbeau, Momo, NRG, OMP, Racetech, Recaro, Sabelt, Sparco, Status Racing, Takata and more. There is extra space on the bracket for drilling your own hole pattern if using a slider with a less common hole pattern, or direct mounting a seat or side mount when eliminating sliders is preferred. They are finished with a black powder coat and applications are available for many vehicles here's the seat i was inquiring about. it is mocha so i asked for the manufacture to send me a sample of the material to see if it's a close enough match to my existing interior. if it doesn't than i'll look for an all black seat. so my main concern since there's not enough info out there for the F10 platform with guys swapping their seats out is what possible kind of error codes would i get? i did read that i should be able to reuse my seat belt mechanism which should just reattach to the new seat. what are your thoughts on possible errors?
03-29-2020, 05:56 PM | #4 | ||
Rep 1,254
That seat looks amazing I like that style Things I would do before pulling trigger. Adjust seat to your liking then unplug it See what happens. I didn't think seatbelt retracts back to the seat it retracts to the pillar.
03-29-2020, 06:27 PM | #5 | |
Rep 14,521
03-29-2020, 06:32 PM | #6 | ||
Rep 1,254
and you love ones ones Speaking of coding off topic I just ordered my OBD wireless adapter from amazon I will be coding my car with BeemerCode app Look it up it's legit stuff if you decide to do same thing look up make sure OBD is computable with app
03-29-2020, 07:11 PM | #7 | |
Rep 14,521
03-29-2020, 07:24 PM | #8 | ||
Rep 1,254
I don't know nothing about trunk One thing I hate I can't close trunk with remote or inside the car.
03-31-2020, 09:43 PM | #9 |
Rep 221
would you not be needing some of these as well? I know they work well on 3 series, and x series.
https://www.ebay.com/itm/Seat-Occupa...YAAOSwaadau8hE Last edited by jayster0966; 03-31-2020 at 09:58 PM.. |
03-31-2020, 09:56 PM | #10 | |
Rep 14,521
04-15-2020, 02:37 PM | #11 |
Rep 38
Coding for M5 seats
I have a similar dilemma as Isturoteg- I have a 2013 Msport as a dd which has just the regular leather seats.I found a pair of front seats out of a 2012 M5,great condition, good price but am in the dark about coding. What is the exact name of the app used and could someone give me a link as to whats involved? Greatly appreciate it!
04-15-2020, 02:50 PM | #12 | |
Rep 14,521
04-15-2020, 03:43 PM | #13 |
Rep 38
Coding for M5 seats
Ikr,just got off the phone at BMW parts and they dont' have a clue either. Its hard to pass on these seats, the lumbar and bolster are so much better,plus 20 way adjust.
04-15-2020, 03:45 PM | #14 |
Rep 14,521
i know! but say you spend the money and in the end realize you can't use them because of coding? that would suck
