2010 2011 BMW 5 Series Forum F10 Downpipes/intercooler required?? |
07-16-2020, 09:26 PM | #1 |
Rep 40
I just ordered intercooler, downpipes and bootMod3. Hesitant on installing the downpipes as I don't want to deal with the CEL and smog check. Are there any options of dealing with said issues above or is it just part of the headache when having downpipes? Lastly, is anyone running a tune without the downpipe? Do I really need to have the intercooler? I am a novice and am trying to learn.....so be gentle.
Engine mods so far is VRSF charge Pipe, M Performance Exhaust, BMS intake. |
07-16-2020, 09:54 PM | #2 | |
Rep 716
Jcole965616.00 |
07-16-2020, 11:28 PM | #3 |
Rep 14,522
Did you get catless dp? Also, you should do your research before just buying parts. Plenty of threads here that go over everything you just asked to give you a better understanding of what works in your situation
Jcole965616.00 |
07-17-2020, 12:04 AM | #4 | |
Rep 40
On word of mouth. Just curious to get an actual board conversation and thoughts here. If I don't install it, I'll just send it back. But thanks for the feedback. Really I just want someone to give me that extra warm and fuzzy to take that move to just say "eff" it and install it. |
07-17-2020, 08:38 AM | #5 |
Rep 289
Bootmod3 has option to turn off CEL for downpipes. You can run a Stage 1 tune with stock downpipes.
If you install downpipes, you will not pass smog. Bootmod3 Stage 2 requires downpipes and at least 1 step colder spark plugs. If you want to play it safe, run stage 1 and return the downpipes and intercoolers. Not sure the power increase between Stage 1 & 2, but I think with downpipes it should be around ~30-40 whp. Edit: ignore this I thought you had the N63 |
Jcole965616.00 |
07-17-2020, 10:35 AM | #6 |
Rep 2,590
bootmod3 lists the required mods in the maps, so just read that.
Stage 1 is no hardware required, but generally a charge pipe is heavily suggested. Stage 2 is FMIC and HF downpipe, a catless if you go with the aggressive burbles map Sparks are not required for any of the stages, but they do suggest one step colder: https://bootmod3.atlassian.net/wiki/...+and+which+gap CEL won't pop since BM3 gives you an option to turn it off (in customize map options), but you won't pass smog.
2015 BMW 535xi
Jcole965616.00 |
07-17-2020, 10:44 AM | #7 | ||
Rep 40
07-17-2020, 07:12 PM | #8 |
Rep 2,590
Protip for the downpipe, if you're doing it yourself: drop the entire exhaust. Makes the whole thing so much easier to line up. And get a propane torch in case the connection is being stubborn (rust welded)
2015 BMW 535xi
Jcole965616.00 |
07-17-2020, 07:44 PM | #9 |
Rep 85
Eff it and do it. same thing I did, just different tune. did new plugs 1 step colder soon after stage 1 and downpipe. I figure it's cheap and doesnt hurt. going in for stage 2 soon and dyno. emissions need to be done before Sept so will figure that out soon enough. not worried about it. also for DP install I didnt need to drop full exhaust. I loosened the bracket mid car holding it up and was able to get enough play from hangers to give myself plenty of room to get it out, easily 4 to 5in.
07-18-2020, 06:35 AM | #10 | |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I'll just mention having gone down this road in the past. That it is possible to go catless or high flow cat and not trigger a CEL and not have to tune the CEL out. Do some research here, and you'll find the solution, it will allow the car to pass inspection without bribing someone. Pro-Tip. Its a lot easier to pass inspection if you have a high flow cat as cars with no cats at all smell, and its recognizable to anyone with automotive experience the smell of unburned fuel. A high flow gives you the performance and eliminates the stink, its also quieter as the cat acts as a bid of a sound absorber. Personally I've never liked cat-less because of the smell and preferred high flow. The difference in performance is barely measurable on a dyno and in the real world unnoticeable, but the stink being gone is real noticeable. |
07-18-2020, 10:45 AM | #11 | ||||
Rep 40
07-19-2020, 12:58 PM | #12 | ||
Rep 2,590
Evolution racewerks is what I went with, great build quality. You definitely want one that has a flex section.
2015 BMW 535xi
07-20-2020, 03:30 PM | #13 |
Rep 14,522
My 535i RWD catless dp from VRSF was pretty easy and straight forward to install other than it sucked i had to drop the whole exhaust down in order to get the OEM dp out since there not a whole lot of wiggle room to separate the dp from the exhaust. but i did use the Vibrant o2 spacer to prevent the CEL from coming on. make sure the Vibrant o2 spacer is facing upward.
Jcole965616.00 |
07-21-2020, 12:08 AM | #14 | ||
Rep 82
Do you have the jack stands on the control arms? I might have to give this dp install a try 😉 |
lsturbointeg9152.50 |
07-21-2020, 11:56 AM | #15 |
Rep 2,590
DIYing the DP is honestly not hard. The hardest part is getting the damn v-band clamp on properly.
2015 BMW 535xi
07-22-2020, 06:30 AM | #16 |
Rep 14,522
Haha no worries! Yup, doesn't look.like its hurting the arms at all. I need to order 3 more BMW jack adaptors cause I don't want to ruin those plastic housing thingies
07-22-2020, 11:22 AM | #17 |
Rep 97
sorry to jump in guys. also a noob with tuning thingy.. have some question about tuning.
so let say i wanna go with bm3 stage 2 but my mods is all that required but not the intercooler, what will happen with the car? and what is the gains am i lookin at? |
07-22-2020, 11:51 AM | #18 |
Rep 2,590
Do what Tommy L Garage did. Get the rubber-y ones, and just screw them into the plastic housings. It's what I'm doing as well. Prevents dealers from "forgetting" to use adapters and non-BMW places from ruining them unintentionally.
2015 BMW 535xi
07-23-2020, 05:10 PM | #19 | ||
Rep 82
Can you link me a picture for reference? Might have to try to do same or have to do like my friend did and put it on control arms |
07-23-2020, 08:46 PM | #20 |
Rep 2,590
2015 BMW 535xi
07-29-2020, 11:03 AM | #21 | ||
Rep 40
On stage 2 can still be run. It becomes a problem if you are running the car at Long times in hot weather. Anyone else To chime in would be awesome! Thanks! |
08-01-2020, 08:53 AM | #22 |
Rep 14,522
only issue is how the rubber one's get really deformed. i would think overtime chunks would fall off. what about the metal adaptors. i'm thinking drilling holes should be fine?
