2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Help with dtc
      08-20-2017, 09:40 PM   #1
Creynolds
Drives: 550i
Help with dtc
I have paid for every app, BimmerLink obd this obd that. Nothing gives me answers to what is wrong with my car.
BimmerLink does nothing it's in German!
Alldata says P117e and P11bd?
I can't take this much longer.
I will pay for the service only if it will work. Wasted enough money as it is
      08-20-2017, 09:58 PM   #2
wcr3d
Drives: 2013 535i XDrive M Sport
The favorite by far is called Carly.
None of them are going to tell you in plain English what is wrong and what to do to fix it.
You already have two error codes reported, it is up to you to research from there.
      08-20-2017, 10:27 PM   #3
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
On these cars playing around with OBDII bluetooth phone dongles is just that... playing
Get yourself set up with a cheap laptop, an enet cable, and ISTA/D.
      08-21-2017, 03:46 AM   #4
Creynolds
Drives: 550i
Some screens
      08-21-2017, 03:47 AM   #5
Creynolds
Drives: 550i
German to English still no help
Error memory
22 errors
Junction Box Beifahrer III
2 errors?8020E6: Zu?ndung ein: Startfa?higkeit gefa?hrdet?8020E7: Klemme 30B aktiv: Startfa?higkeitsgrenze erreicht oder Kl. 30B lange Zeit aktiv
Airbag-Elektronik (Conti)
2 errors?930988: Kopfairbag links: Widerstand zu groß 93098E: Kopfairbag rechts: Widerstand zu groß
Zentrales Gateway
1 error?801C20: Zentraler Fehlerspeicher voll
Motorelektronik MSD 85 8 Zylinder N63
6 errors?102901: 0x102901 Luftmasse 2, Plausibilita?t: Luftmasse zu hoch
140102: 0x140102 Verbrennungsaussetzer, Zylinder 1: abgasscha?digend nach Startvorgang
140602: 0x140602 Verbrennungsaussetzer, Zylinder 6: abgasscha?digend nach Startvorgang
107001: 0x107001 Drosselklappenwinkel - Saugrohrdruck 2, Korrelation: Grenzwert u?berschritten
140002: 0x140002 Verbrennungsaussetzer, mehrere Zylinder: abgasscha?digend nach Startvorgang
140501: 0x140501 Verbrennungsaussetzer, Zylinder 5: Einspritzung wird abgeschaltet
COMBOX Telefon
1 error?B7F18A: USB-Anschluss: Abschaltung wegen U?berlastung
Car Access System 4
3 errors?930769: Deaktivierung Klemme 15: OSFG erreicht?93076A: Deaktivierung Klemme 15: OSFG erreicht, jedoch Abschaltverhinderer aktiv 930798: Antenne Kofferraum links (KRLI): Kurzschluss, offene Leitung oder defekt
Funktionszentrum Dach III
2 errors?030215: SHD: ungu?ltige Kennlinie, keine Normierung vorhanden 801A4A: Deaktivierung IRS und Neigungsgeber per Kundenfunktion
Heck- Funktionsmodul Mid
1 error?801730: HKL-Sensorversorgungsspannung Hallsensor
Fussraummodul III
3 errors?800EC2: Schloßnuß 1 ha?ngt?800FB7: Außenspiegelheizung oder Elektro.-Crome rechts defekt 800F8D: Abbiegelicht rechts defekt
Zentrales Info Display
1 error?800334: PWM Reduktion auf Grundu?bertemperatur
memory
22 errors
Junction Box Passenger IIl 2 error
8020E6: Ignition on: Starting capability at risk 8020E7: Terminal 30B active: Start capability limit reached or terminal 30B active for a long time
Airbag electronics (Conti)2 errors
930988: Head airbag left: Resistance too large
93098E: Head airbag right: Resistance too large
Central gateway
1 error801C20: Central error memory full
Motor electronics MSD 85 8 cylinder N63
6 errors102901:
0x102901 Air mass 2, plausibility: Air mass too high
140102: 0x140102 Combustion valve, cylinder 1: harmful to exhaust gas after start-up
140602: 0x140602 Combustion valve, cylinder 6: exhaust-gas-damaging after start-up
107001: 0x107001 Throttle valve angle - intake manifold pressure 2, correlation: limit value exceeded
140002: 0x140002 Incineration, several cylinders: harmful after startup
140501: 0x140501 Combustion valve, cylinder 5: Injection is switched off
COMBOX telephone
1 errorB7F18A: USB port: overload protection
Car Access System 4
3 errors930769: Deactivation of terminal 15: OSFG reached93076A: Deactivation of terminal 15: OSFG reached but cut-off inhibitor active 930798: Antenna trunk left (KRLI): Short circuit, open line or defective
Functional Center Roof III
2 errors030215: SHD: invalid characteristic, no scaling available 801A4A: deactivation of IRS and inclination sensor by customer function
Rear function module Mid
1 error801730: HVAC sensor supply voltage Hall sensor
Footrack module III
3 errors800EC2: Lock nut 1 hangs800FB7: Outside mirror heater or electric drive Crome right defective 800F8D: Cornering light right defective
Central info display
1 error800334: PWM reduction to basic overtemperature
      08-21-2017, 04:09 AM   #6
Creynolds
Drives: 550i
Perm
Permanent codes
