12-25-2014, 08:23 PM | #1 |
Rep 712
Drives: 22' M240i
Spacers?
Hey
I am lowering the 550i on H&R springs and I am wondering if I should run spacers? At least in the front? If so what size would you recommend? Here are my wheel sizes and offsets. Front 20x9 et35 245/30/20 Rear 20x10 et35 285 /30/ 20
2022 M240i Thundernight Metallic / Oyster
Previous 2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i Last edited by FeckinSpaceman; 12-26-2014 at 02:53 AM.. |
12-26-2014, 12:18 AM | #2 |
Rep 413
Yes, you can have spacers all around if you want. My summer setup is Vorsteiner VS-310 20X8.5 ET20 and 20X10 ET28 with 245-285 Michelin PSS tires and it sits very flush (pics before lowering):
This setup is equal to 20X9 ET26 and 20X10 ET28, therefore it is clear that you can run 8 mm front (with 245) and 8 or 10 mm rear (with 275). I would also recommend you to make the very simple measurements on your wheels: http://www.turnermotorsport.com/t-te...l-spacers.aspx. In fact, the F10 fenders and axis are standard, but the different aftermarket wheels and tires of the same specs can introduce minor shape deviations depending on their design and size. |
12-26-2014, 08:13 AM | #3 |
Rep 712
Drives: 22' M240i
My bad, my rear tires are 285, I updated my first post
Thanks for the info. Sounds like 8 mm for the front might look nice. After i get the springs on I will measure to be safe.
Previous 2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i |
12-26-2014, 08:27 AM | #4 |
Rep 413
OK so have 5 mm for the rears, and it will be fine ) Please don't forget to get the lug bolts extended to the same added length: there is not that much of bolt thread effectively used. The extended bolts normally offered together with the spacers. And: measurements never hurt!
01-01-2015, 02:03 PM | #5 | |
Rep 712
Drives: 22' M240i
01-04-2015, 07:18 PM | #8 | |
Rep 712
Drives: 22' M240i
01-21-2015, 06:10 PM | #12 |
Rep 29,202
On OEM wheels you mean? Yes.
01-21-2015, 07:12 PM | #13 | |
Rep 2,196
Bake
01-22-2015, 01:19 PM | #14 |
Rep 9
Question. Are spacers irrelevant from the shock and struts? By saying that I can get any brands of spacers as long as they fit with the requirement of F10?
Thanks!
'11 528i Space Grau Metallic
Plasti-dipped Emblem Premium Package 2 Adaptive light control Xenon headlights |
01-22-2015, 02:04 PM | #15 |
Rep 413
Absolutely. Spacer is nothing but an artificial extension of a wheel hub made to move the wheel outwards. Using spacer is even good because gives the wheel a bit more space by moving away from the suspension elements (shocks and struts). But not to make the spacer too thick because the tire will start rubbing the fender.
01-22-2015, 02:09 PM | #16 |
Rep 9
Got it Valbm. That's a good information. And finally, will I have the option to install lowering springs in the future, if I just get a moderate length spacer, say 15mm?
01-22-2015, 02:41 PM | #17 |
Rep 413
Yes you will. Like most of the members here who have already done lowering + larger wheels + spacers for flush and aesthetic look.
The thing is, the spacers should come the last, and measured together with the wheels. Depending on a specific tire brand and square/stretched tire shoulder shape, you can afford different offsets/spacers. As for the spacer technology, the lightest ones are the best, for example RS Technik. Also they must have the extended lug bolts (normally sold together). |
