2010 2011 BMW 5 Series Forum F10 Help needed "lowslung Sport Suspension" |
03-16-2020, 04:55 PM | #1 |
The Slow And The Furious
Rep 32
Drives: BMW 535i 2010
Hello dear people.
About a week ago my right rear coil spring said "ski daddle ski doodle your car is now a noodle" and snapped in two. luckily for me it snapped right at the bottom where it rest against the lower rubber spring pad. The big problem is i cant find right replacement part to order online. when i use online decoder to decode my car i can see it has something called "S230A Lowslung Sport Suspension" and the indie mechanic tells me i have to order it from the stealers? My car i a non m-sport F10 535i "European" Vin: WBAFR71040C542107 i would really appreciate some help which coil spring would fit my cars OEM strut so i can fix my car and make it stop sounding like an old bed in a 70's porno movie. and yes i have googled far and wide without any luck!
Drive like you stole it!
Then regret that you broke it! |
03-17-2020, 06:50 AM | #2 |
Rep 1,873
You're probably in a situation where your options are:
1/ replace all four springs with something matching like H&R, Eibach, ACS. It will be lower and stiffer, the degree of which depends on which you choose 2/ replace all four corners with coilovers or similar 3/ order the real part from the dealer, preferable paired with the other rear. |
03-17-2020, 07:52 AM | #3 |
Rep 1,299
4th option like I did... Went to eBay and bought the entire strut with spring from a lower mileage car and installed that. New spring was 300 bucks due to discount I get, otherwise I think it was 500 dollars. The strut with spring from a 60k car was 150.
03-18-2020, 03:08 AM | #4 |
Rep 32
Update
I took my Vin number and whent to my local BMW shop and the nice sparepart worker helped me figure out what i needed. He told me my car was equiped with standard suspension and that what the vin code decore gave me was bullsh*t. So i ordered two new rear springs Thanks for your help tough!
