2010 2011 BMW 5 Series Forum F10 Connecting amplifier to battery |
04-23-2019, 03:35 AM | #1 |
Rep 11
Hello, I am about to install a Mosconi-amplifier in my F11. I am wondering if this is the right way to connect the V+. Not sure if I am about to disturb the battery-monitoring or something...
This post got me wondering which one to use. Anyone with experience on the F10/F11 battery? Last edited by robbb; 04-23-2019 at 09:53 AM.. |
04-23-2019, 02:55 PM | #2 |
Rep 5,362
Personally, I would stick with the under-hood connection. Though I don't know for sure, I imagine you would be able to access the cable after the battery. Maybe intercept the cable between the battery and under-hood connection. If you go straight to the positive side of the battery the IBS won't be able to detect current draw and could leave you with a dead battery.
Disclaimer: I am not an electrical engineer but did stay at a Holiday Inn Express last night |
04-24-2019, 04:16 AM | #3 |
Rep 11
Sorry I am a non-native English speaker. Allthough I understand most concepts I do not understand all terminology. What do you mean with "under-hood connection"? A distribution block other than the one directly on the battery? Do you literally mean under the hood, because the battery& are in the trunk.
04-24-2019, 06:35 PM | #4 | |
Rep 5,362
04-26-2019, 09:31 AM | #5 |
Rep 1,126
Don't go under the hood to make it complicated. Use the positive distribution block to connect amp cable. In pic, you can see many empty slots, next to blue ring connector with red wire. The method you are suggesting in pic is fine too.
04-26-2019, 12:15 PM | #6 | |
Rep 5,362
Be sure to put a fuse on the power cable. |
04-27-2019, 10:45 AM | #7 |
Rep 342
04-27-2019, 12:42 PM | #8 |
Rep 5,362
04-29-2019, 01:25 AM | #9 |
Rep 11
I chose to install it this way, with the ring connector. The battery was not dead this morning and the car was not on fire, so everything seems to be working fine
04-29-2019, 01:29 AM | #10 | |
Rep 11
Connector: 61136920092 Plastic cover (1x): 61136925176 Plastic cover (2x): 61136925166 |
ezaircon4jc4479.00 |
06-24-2019, 03:48 PM | #11 | |
Rep 17
Did you end up using the + you shared on your first post? Any issues? About to do this on Saturday Thanks |
Tags |
amplifier, battery |
