2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications B58 Coils
      01-21-2022, 10:50 AM   #1
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
B58 Coils
Just did the upgrade and holy cow! smooth as butter... I'll post a quick video here soon. Pics on insta. Totally worth it.
2011 F10 S55 6MT
      01-22-2022, 02:36 PM   #2
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
What adapter plate did you go with?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      01-23-2022, 09:27 AM   #3
513
I got the nxm plates. But I have an early n55 so the mounting holes didn't line up, I had to slightly modify them.
The kit comes with longer boots for the coils and the wire harness, so you need more than just the brackets.
2011 F10 S55 6MT
      01-23-2022, 03:19 PM   #4
BrandBMW
Drives: 2011 535ix M-sport
2011 535ix Msport  [0.00]
1992 850i  [0.00]
Hmm, I too have an early N55 so modifying the existing holes is interesting.
On another note, I believe your Instagram is @bimmerhausperformance, different than what's on your sig
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2
Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc.
      01-23-2022, 10:28 PM   #5
513
Thanks, it is updated. I didn't modify the hole itself, just used oversized washers to pin them down. I will do a you tube video soon.
2011 F10 S55 6MT
      01-30-2022, 09:57 PM   #6
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
First time hearing about b58 coils. Care to elaborate? Curiosity has gotten me. Cost? Benefits?
      01-31-2022, 09:42 AM   #7
Unspec
Unspec's Avatar
1301
***********[dot]com/threads/ignition-coil-secondary-spark-energy-comparison-n54-n55-b58-and-pr.7169/
From that thread's conclusion:
In conclusion: The B58 coil is a light, low profile coil that produces substantial spark energy over a long spark duration. The B58 coil's shorter dwell time places less load on ignition IGBT's while matching the Precision Raceworks coil in total energy delivered over the spark event.
2015 BMW 535xi
      01-31-2022, 09:45 AM   #8
513
Practically speaking, I have better spark which translates to better combustion, less timing corrections, which builds boost faster and allows me to turn boost up because I get less knock.
2011 F10 S55 6MT
      02-01-2022, 11:02 AM   #9
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
Great product i had to sell to Dan!!! I see hes loving it!!
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      02-01-2022, 01:09 PM   #10
musclesmarinara75
musclesmarinara75's Avatar
2013 535 XDrive  [9.75]
does this require re-tuning on whatever tune will be used ?
      02-01-2022, 01:12 PM   #11
513
There is a check box within MHD you can check for these coils, but if you are on a custom tune your tuner will be able to add boost if you have the fuel available.
2011 F10 S55 6MT
      02-01-2022, 01:14 PM   #12
musclesmarinara75
ohhh.. Im BM3.. so i'll have to check, I heard people having really good luck with these.. was wondering for awhile... how much for the 6 cost you?
      02-01-2022, 01:19 PM   #13
513
The coils are one cost... you can google B58 Coils from FCP or ECS, then the kit to adapt them to your car from nxm is a separate cost. Kit is the wire harness, install plates, and the longer boots for the coils.
2011 F10 S55 6MT
zvery777272.50
      02-01-2022, 02:38 PM   #14
musclesmarinara75
Thanks for info... i'll keep that in mind
      02-01-2022, 09:56 PM   #15
insane11
Drives: 435i GC
here another alternative for the earlier n55
https://www.e 90post.com/forums/showpost.php?p=27973271&postcount=15
https://www.e 90post.com/forums/showthread.php?t=1822338&page=2
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
      02-28-2022, 05:29 PM   #16
paul223
paul223's Avatar
Drives: F10
I contacted bootmod3, they have enabled b58 coil option now on website, app to follow
      03-01-2022, 10:16 PM   #17
95blkmax
Drives: '11 535 M-Sport
So I've been rocking the B58 coils for a couple weeks now (Eldor B58 coils sourced from FCP along with the Nexsys conversion kit). I can attest that even on the stock PWG turbo the improvement is noticeable. Both in idle and WOT, but also in normal driving. As I was telling others, the rev-range feels "effortless". It's still hard to describe but it feels butter smooth and VERY responsive.
Having said that, I am truly happy with it. Is this something for everyone? Probably not.
I cannot tell if I feel more power or not. I honestly do not think so (on my baby PWG stock turbo). I personally did it being aware of the many benefits of having a stronger voltage & longer duration spark. This improvement will mostly be felt when pushing the limits of the ignition system once equipped with a larger turbo (which I intend to do). A tuner can push the limits of boost and ignition timing FURTHER and SAFELY.
Who would I recommend this to?
- ALL who are going to run a larger turbo, point blank. Is it NEEDED, no. Is it better than N55 Eldor coils, or PR coils? According to testing over in "that unspoken other forum", yes if it! Which means better tuning potential for you. I can again confirm that they have made a noticeable improvement as stated above
- ANY N55 owner that is ODC about smoothness. It made my car feel newer than it is. This is from someone rocking a fresh set of plugs and full stock gap AND new Eldor coils (with which I was very happy with... until I switched to this B58 kit and was blown away).
Hope my opinion helps others!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      03-02-2022, 01:58 AM   #18
musclesmarinara75
Brow.. and BlkMax... I currently have step colder plugs, If I go with the B5b coils, should I use the same colder plugs?.. or go with what was stock?
      03-02-2022, 06:07 AM   #19
Surly73
Well, now you've got me interested.
My F10 is 3 or 4/2011 production (different places say different things). As far as I know I have original coils, but the plugs have supposedly been replaced under a warranty RO by the dealer. (The injectors were also supposedly replaced, but I'm suspicious whether it was done, or it was done and they skipped coding the compensation numbers into the DME because it's never idled quite right since they replaced all of the injectors. I'm going to explore if I have any hope of reading the flow compensation numbers off of the injectors while they're installed. Based on research I don't think I want to pull them just to read a number and then reinstall them.)
Anyways - Any good threads or guides on choosing the right adapter kit depending on the different versions of things one might have etc...? Maybe I'll put B58 coils and plugs on the 2022 list along with a few other things, but I would be ordering cross-border so I need to get all the right stuff the first time.
      03-02-2022, 06:32 AM   #20
95blkmax
You can use your same colder plugs as you have a PS2. But you'll be able to run a larger gap (be sure to speak to your tuner if you're on custom tuning as they'll be able to further adjust your tune and tell you exactly what gap to run the plugs at)
PM me the last 7 of your VIN and I'll tell you exactly when it rolled out the factory.
So mine was built April 2011 and this is what my injector bracket looks like (metal T)...
So the Nexsys kit that is currently made works perfectly on this kit. BroBMW's has the early N55 injector bracket/ plate and it's that format that would require the slight modding to make it fit. Nexsys is allegedly working on an early N55 kit already but I do not know when it will release.
Yea unfortunately to see the #s on our injectors they do have to come up and out of the cylinder head as they are on the side. Meaning you'll want to have 6 decoupling elements (metal crush ring seals) and 6 nylon seals (the seals at the tip of the injectors). None of them are reusable.
      03-02-2022, 09:01 PM   #21
musclesmarinara75
I thought you wrote T sharp.... I didn't realize you were writing out T SHAPE... about your bracket... I was lost for a minute
      03-02-2022, 10:03 PM   #22
95blkmax
Hey hey! dont pick on my finger tip writing on my phone screen skills
