2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum How do I remove the factory scoop behind the grille?
      04-26-2016, 10:52 PM   #1
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
There is what I think is an factory plastic scoop behind the grille. I am trying to remove it so I can fit custom air scoops directly to the intake air duct, but can't figure out how to take this thing out. I removed all the screws at the top, but apparently it's connected somewhere else. I'm hoping I don't have to remove the front bumper.
Here's a photo from LACSTER
IG: @bmwdoubles
      04-26-2016, 11:31 PM   #2
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
Take the front bumper off and the top metal cover, you should able to take it out, I took mine out.
BMW f10 550i Msport
      04-26-2016, 11:33 PM   #3
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Ugh the front bumper? I might cut it out haha. Do we need it?
IG: @bmwdoubles
      04-26-2016, 11:58 PM   #4
PJinCA
USAF Pararescue Veteran
Drives: F10 535
I looked at it as well, it doesn't seem to serve any real purpose other than maybe an additional layer of protection for the radiator.
      04-27-2016, 12:01 AM   #5
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Ah yeah maybe it does deflect crap from hitting the radiator at full velocity. The whole front bumper though, ugh.
IG: @bmwdoubles
      04-27-2016, 02:25 AM   #6
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
Are you referring to the flaps that automatically close down if the engine is at the wright temp! and pushes air away from the engine bay to reduce fuel consumption.
      04-27-2016, 02:44 AM   #7
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Yeah, but mines static and not controlled by the ecu.
IG: @bmwdoubles
      04-27-2016, 10:02 AM   #8
PJinCA
Drives: F10 535
Yep, same here. They don't move, so they seem to serve little to no purpose other than to deflect debris from the rad.
      04-28-2016, 03:35 AM   #9
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
It's impossible to remove that assembly with the bumper on-
The slits are just extra supports for the grille frame.
CUT them though, do not attempt to snap them off with your hands or with pliers etc+force. They are designed with slack/flex, so theres a chance something else will break before those do.
Don't ask. Just. Dont.
      04-28-2016, 11:44 AM   #10
550Reasons
550Reasons's Avatar
Drives: F10 550i
I cut them / pry them off, aint nobody got time for taking the bumper off
2011 550i
2013 M5
2014 M5 CP
2016 550i
      04-28-2016, 11:46 AM   #11
PJinCA
Drives: F10 535
They seem pretty easy to just cut, a dremel would work well there
      04-28-2016, 12:19 PM   #12
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Haha that's what I'm saying. They don't serve a purpose or at least it doesn't seem like they do. It seems like it's the ghost of something that should be there. Like an electronically controlled version of it.
IG: @bmwdoubles
      04-28-2016, 12:23 PM   #13
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
I was thinking of trimming the fins and not the entire square bracket leaving 2 square holes.
Don't judge me
Here's my homemade version of a scoop until I have a professional do it. And this is the reason I'm asking. So far no noticeable increase in power
IG: @bmwdoubles
      04-28-2016, 07:32 PM   #14
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
are you trying to keep it open to force cold air in all the time?
      04-28-2016, 07:40 PM   #15
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
It's always open its not mechanical. I'm trying to increase the static pressure for higher CFM. Truly the best approach is shortening the distance from the grille to the turbo inlet coming from the other side and not a scoop from the driver side.
IG: @bmwdoubles
      04-28-2016, 11:11 PM   #16
PJinCA
Drives: F10 535
These ram air scoops will give you no added HP at slow speeds, I had the RPI scoops on my old cars. I felt it only when I went to make a pass on the freeway, then I felt the power, which is exactly what RPI said would happen
