2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW Warranty issue with changing to ACS springs
      05-30-2012, 08:42 PM   #1
Klecha man
Klecha man's Avatar
Drives: 2012 535
Has anyone had any issues with BMW trying to void the factory warranty because of changing the stock springs to ACS?
      06-14-2012, 08:45 AM   #2
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Not at all and I did mine at the dealer.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      06-14-2012, 09:57 AM   #3
Klecha man
Klecha man's Avatar
Drives: 2012 535
Hunter... you have a sweet sweet car. Love it.
      06-14-2012, 04:45 PM   #4
saeba1
saeba1's Avatar
Drives: 2015 F82 M4 DCT
Hi, which dealer if u don't mind me asking?
I am also in Chicago area. In fact, I think I saw your car a few times in A&L bodyshop...
Mine is currently in the shop. Thinking about doing the spring after the body work.
      07-11-2012, 01:19 PM   #5
gurns
gurns's Avatar
Drives: 2021 G82 Dravit Grey
The representative from the dealership I bought my car from said the warranty on the car is NOT affected by installing different springs. Response is time late but thought I'd share it nonetheless.
      07-11-2012, 05:10 PM   #6
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Your car's warranty doesn't get voided just because you replaced your springs. However, your struts and all other components failure that are directly linked to lowering your vehicle will not be covered.
If you're planning on selling/trading your car in the future, I recommend using coilovers. You can throw your stock struts/springs back when you don't want the car anymore, then sell your used set of coilovers. That's a lot less expensive than keep blowing a OEM struts after riding the ACS springs. OEM struts are not meant for lowered springs, no matter how clever Eibach, ACS, and H&R advertise it. Unless, you're running Sport Struts then you "should" be okay since they're made for Sport springs. Just don't cut corners on a BMW, it is, after all an expensive sport sedan.
Just my 2 cents.
      07-11-2012, 05:16 PM   #7
JNoSol
JNoSol's Avatar
Let's see if your dealer's response will be consistent once your struts are blown, and they discovered you're using aftermarket (non-Dinan) springs.
