2010 2011 BMW 5 Series Forum F10 battery discharge issue (jb4?) |
09-28-2021, 03:51 PM | #1 |
Rep 19
Few weeks now I’m having warning about excessive battery discharge when I start my car in the morning.
Nothing have changed recently and nothing is connected to the car. Only JB4. It was working fine over last 2 years. Codes: 213601 Power management: Quiescent current violation Error present and stored 122108 Divert air valve: stuck closed Error stored “13 535. Battery is barely new, changed and coded 3 months ago. |
09-30-2021, 06:44 AM | #2 |
Rep 1,873
IMO - don't guess. You need to pull the stored error referred under 213601. This may require ISTA. It will tell you which circuit branch.
My F10 had a malfunctioning parking brake actuator which would not sleep correctly back in 2014 or something like that. It could be just about anything and the modules store information to help you identify where the issue is. If you just throw parts at it, you might waste a lot of money and still not fix the problem (who here would have guessed it was a parking brake actuator?) That being said if any chargers, dongles or add on electronics are present try disconnecting them. Just for the search hits I'll repeat something I've written many times before: "Battery discharging while stopped" almost certainly does not mean you need a new battery, it means you have an excess load draining the battery when the car is supposed to be asleep. Sometimes a full reboot might fix the problem, and certainly won't hurt. |
09-30-2021, 08:34 AM | #3 | |
Rep 19
thanks for reply, that makes sense . I’m also pretty sure it’s something really small and dumb has open circuit. I recently hit trash can with rear bumper so it might be even one of the parking sensors. |
