2010 2011 BMW 5 Series Forum F10 F10 550i (N63TU) Tune by Cedar Performance |
10-06-2021, 02:38 AM | #1 |
Rep 156
Got the F10 dyno tuned today at Cedar Performance and just wanted some feedback on what the car actually put down at baseline and the end result. Car is stock and has 41k miles, installed new NGK 97506 plugs gapped at 0.022” and Eldor coils the day before tune.
Baseline- 355.9whp/334.9wft-tq Final dyno- 438.7whp/405.1wft-tq Even though it’s stage 1 I’m feeling a little disappointed in the numbers. Car pulls nicely though.
2014 BMW 550i M Sport- Tuned by Matt @Cedar Performance-Daily Driver
2016 Audi Q5 3.0T Prestige-Weekend Warrior 2008 Infiniti G37S Coupe 6MT-RIP 2015 Lexus RC350 FS-SOLD Last edited by TuckerE36; 10-06-2021 at 03:38 AM.. |
10-06-2021, 09:24 AM | #2 | |
Rep 191
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
10-06-2021, 12:14 PM | #3 |
Rep 156
I told Matt at Cedar Performance that I wanted a semi conservative tune, he said there was a lot of room up top for improvement. I was also thinking their dyno read low, which isn’t typical for dyno jet, usually Mustang dyno’s read lower from my past experience with dyno tunes. I might start logging some data and then return for an adjustment in the future. The engine is highly maintenanced so I’m not worried about going a little more aggressive than then current tune.
2016 Audi Q5 3.0T Prestige-Weekend Warrior 2008 Infiniti G37S Coupe 6MT-RIP 2015 Lexus RC350 FS-SOLD Last edited by TuckerE36; 10-06-2021 at 12:20 PM.. |
10-06-2021, 12:35 PM | #4 |
Rep 156
I guess I’m feeling a little cheated for some reason because the custom tune was $1200 and a BM3 OTS stage 1 tune for hundreds less makes more power.
2016 Audi Q5 3.0T Prestige-Weekend Warrior 2008 Infiniti G37S Coupe 6MT-RIP 2015 Lexus RC350 FS-SOLD |
BettyFkinCrocker180.00 |
10-07-2021, 07:27 AM | #5 | |
Rep 191
If anything, I'd say theres more room in the curve than up top. You can clearly see its making less power than the stock tune from 2.7k all the way to 5.4k. Thats not a big deal because when you are WOT, shifts stay around/above 5.5k and reducing power (primarily torque) in the lower rpm is "safer" for the powertrain. But yes, ultimately you would have been better off with BM3 as its cheaper and potentially produces the same or more power while being equally as "reliable" while still retaining the ability to get a custom tune in the future if you chose. You should start with getting a draggy and testing 60-130. That way, if you do have Matt make adjustments you can see how they are performing (in a real world fashion, as opposed to a dyno).
IG: @derringerF10
TuckerE3649.50 |
10-07-2021, 08:35 AM | #6 |
Joint Chiefs of Staff
23794
Rep 190,150
Im assuming you are running 91 octane, OTS maps adds 25%HP / 30%TQ , you got 23% HP / 21% TQ
There should be a lot more room for power
10-07-2021, 10:43 AM | #7 | |
Rep 156
10-07-2021, 10:50 AM | #8 |
Rep 156
I run 93 oct. I’ll log some data and return for an retune at some point. I’m not unhappy with the little bump in power but… lol
10-07-2021, 11:37 AM | #9 |
23794
Rep 190,150
On 93 Octane the off the shelf maps add even more power 28%HP / 31%TQ
TuckerE3649.50 |
10-08-2021, 12:07 AM | #10 | |
Rep 503
Drives: 2013 BMW F10 N55 535i XDrive
10-08-2021, 02:48 AM | #11 |
Rep 156
Oh snap... lol
11-01-2021, 01:35 PM | #12 | |
Rep 3
When we recapped the tuning session, we explained that your baseline was lower than our expectations as well, but considering the delta is on-par with any other "stage 1" tune out there, I'm happy with it. One thing I'll note, is our tune actually makes power north of 6000 RPM, where as a lot of these other dyno sheets I see that "make more power", are making all the power at 5000 RPM, and only decrease from there. Not sure why anyone wants a tune where peak power is outside of their car's shiftmap, especially when the power is ultimately "the same." Ultimate, we found the limit on your car as you can tell in the graph when we increased the requests a bit on the last run, the car offset the gains by reducing timing. The only way with the same fuel to make more power would be to desensitize the knock tables. This can also be done, but this is how you blow up engines! Also, I found this thread: https://f15.bimmerpost.com/forums/sh....php?t=1507189 These graphs are pretty odd. I mean, for starters, many of them are in different correction factors, many of them are different dynos, many of them are different mods, different mods, different tunes. It's a 20 page thread comparing apples to oranges. Really, your dyno sheet is cleaner/nicer than any sheet posted in that entire thread, which makes me proud of my tune! If you'd like, I can give you the same basic "stage 1" ots flash that BM3 sells (more or less), that's heavy on midrange torque, and low on output above 6500, but that's not usually what people come to me for Lastly, I'll leave you with these photos. This is your last dyno run, compared to a client we did about 5-6 days after yours. We set his up with essentially the exact same tune file, obviously with a few specific adjustments. The ambient conditions are essentially the same, actually a bit favorable in your end, but his car made more power than yours. The second picture is of your baseline, compared to his baseline. 380whp vs 355whp, with very different torque(boost) curves, bone stock software, same ambient conditions, same dyno. Unfortunately as you can see there's an RPM Glitch, so the graph looked funny with the X-Axis on RPM. I also attached one with X Axis Speed. |
11-01-2021, 07:45 PM | #13 | |
Rep 156
11-02-2021, 08:01 AM | #14 | |
Rep 191
You likely aren't hitting the torque limiter on a stage 1 tune. Theres folks running high 10s, low 11s (so an estimated 650-700 crank hp) not hitting torque limiters.
IG: @derringerF10
11-02-2021, 09:06 PM | #15 |
Rep 156
11-04-2021, 06:57 AM | #16 |
Rep 191
You definitely wouldn't be hitting the limiter at 6k+ rpm. Your peak torque is at 4.6k tapering down all the way to 350wtq by 6k rpm. You've got an unrelated issue. Might be overboosting or something of that nature. Get logs.
IG: @derringerF10
11-04-2021, 11:45 PM | #17 |
Rep 156
Going in on monday for xHP tune. I'll see if I can find a way to data log.
11-05-2021, 12:14 AM | #18 |
Rep 503
Still having problems with your numbers eh??... fucking so frustrating
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
TuckerE3649.50 |
11-05-2021, 01:40 AM | #19 |
Rep 156
I'm meeting Matt on Monday, we will see how it runs after the XHP flash. If it still cuts out in second gear ill have the tune revised
11-05-2021, 10:54 PM | #20 |
Rep 191
For what its worth, most people (on n63 platform) put up slower numbers with xhp vs stock. While its possible xhp fixes whatever issue you might be having (my guess would be overboost or load targets etc) you'll likely end up slower overall. It will feel jerky and more aggressive which people translate as faster, but when compared with actual numbers (draggy, 1/4 etc) it usually isn't. So then you end up with a slower car and more wear on the trans
IG: @derringerF10
11-20-2021, 05:43 PM | #22 |
Rep 61
Drives: BMW 550i ; BMW 335i
So I just my 550i I just ordered catless downpipes vrsf, and I’m gonna get an intake and charge pipes and meth kit. I was told to do all I could before I got the jb4 and did a tune but I’m wondering if it could cause me problems with a stand alone meth kit before I did the tune. I just don’t want to run into problems before I even tune. I could also just wait till I have everything and just get it all done at one time what do y’all think.
CSS
