2010 2011 BMW 5 Series Forum F10 35 dollar air scoop for you 5 series |
01-06-2022, 02:17 AM | #1 |
Rep 522
I've tried all different configurations for air intakes:
- drop-in filters - open-air filters - a custom behind the grille system All with no noticeable effects besides sound. The best sounding one was the custom behind the grill with a shorter tract to the turbo inlet. That one sounded bonkers, but again no substantial increase in performance. The best upgrade I've experienced was on my N54 335 using the stock airbox and two scoops behind the grille. The difference was felt up top. So, after all the experiments, I went back to stock with a drop-in filter. I wanted to get a scoop for the stock entry point behind the grille but didn't want to pay 300-40 bucks for AFE or whatever. I noticed the F30, N20 motors have the same entry point but on the opposite side and found that scoops were substantially cheaper, so I thought I'd give it a whirl. I flipped it upside down and trimmed it a little bit and it seems to fit well. I've driven it around but haven't got a chance to really get on the throttle so I'm not sure of the improvements if any at all. My N55 doesn't respond to mods as well as my N54 did. Things you'll need - F30 scoop for an N20 - Self tapping screws - A straight pick tool used as a punch to start the hole for the screw. ( wear gloves or suffer getting your hand cheese grated from the radiator) - https://www.ebay.com/itm/AVT-Air-Int...-127632-2357-0 To be fair I had removed my rock deflectors on my left side where I had my custom ram air intake so it was easier to install this scoop.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
01-06-2022, 10:02 AM | #2 |
Rep 1,442
Drives: 2011 535i 6MT
That is a similar concept to what they have on e90's. Very well done. However, check out my post. We are just about done proving ram CAI from behind the grill will actually improve turbo performance as you increase speed. I am working with DS on this and he said he has never seen a turbo spool up this easily before.
The plan is to start to manufacture and sell this intake but I want data and proof first. |
Bmwdoubles_194.00 |
01-06-2022, 12:10 PM | #3 |
Rep 668
I like it doubles!! Thanks for sharing. Looking forward to hearing your feedback on it once you give it the beans a few times
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
Bmwdoubles_194.00 |
01-06-2022, 03:01 PM | #4 | |
Rep 522
BimmerHausPerformance514.00 |
01-06-2022, 05:06 PM | #5 | ||
Rep 1,442
01-09-2022, 05:02 PM | #6 | |
Rep 2,595
2015 BMW 535xi
01-09-2022, 05:06 PM | #7 | ||
Rep 1,442
01-10-2022, 01:32 PM | #8 | |
Rep 147
Drives: 2014 BMW 528i
Tri Nguyen
Bmwdoubles_194.00 BimmerHausPerformance514.00 |
01-10-2022, 04:03 PM | #9 | ||
Rep 522
Yeah it makes a little difference up top at freeway speeds. If BrowBMW and Shoup get the tune right for an upfront air ram I'll keep the right side scoop, and add another scoop to blow air on to the left air ram. 2 scoops of raisins.
01-13-2022, 09:29 PM | #10 |
Rep 305
Thanks for sharing. I like bang for your bucks mods. Something I'll add to my custom intake box
Bmwdoubles_194.00 |
