2010 2011 BMW 5 Series Forum F10 Dinan Free Flow Exhaust for F10 M5 or 550i |
03-18-2022, 07:42 PM | #1 |
Rep 16
I'm trying to change my F10 535 M Sort from dual to quad exhaust and thinking of purchasing the Dinan Free Flow exhaust. I already purchased the M5 bumper and adapter to fit a quad exhaust but does anyone know if the Dinan M5 or 550i free flow exhaust fit? I don't mind going to a welder and having it modified to fit but wondering if anyone suggests against it? I also have the option of going for the Megan Supremo which make a quad exhaust for my car but would prefer the Dinan model.
03-19-2022, 12:09 AM | #2 |
Rep 2,590
Remus also offers a quad exhaust. I believe the M5 hangers are slightly different from the non-M hanger locations.
spielnicht did some M5 muffler installs recently and can probably chime in better on the M5 to 550i differences.
2015 BMW 535xi
03-19-2022, 09:38 AM | #3 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
As Unspec mentioned, the rear hangers differ between M5 and non-M5 cars. Muffler shops can work around this by custom welding. But if you're installing something like a full M5 exhaust, you're better served by replacing the rear hangers. If you're just going for the M5 mufflers, you're fine either way. If you're a**l like me and always opt for a true OEM install, the rear hangers will run you $150 between used and new parts. Again, not needed unless you want it to look 100% OEM. 99% of those on the forum don't change the rear hangers when installing M5 mufflers.
Now, one man's definition of M5 bumper/diffuser is different from another. Share a pic of the bumper/diffuser and we can better tell you which muffler will work best. For example - Dinan's 550i mufflers WILL NOT work with true M5 diffuser, straight bolt up or custom welding. Share a pic of the diffuser.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
03-19-2022, 05:32 PM | #4 |
Rep 950
Not to add to any confusion but on stock 550is, the M6 mufflers fit without any issue. The M6 muffler tips are wider apart and so they should fit easily in the stock 550i cutouts. BUT if you are using the M5 diffuser, and other plastic parts that go on the M5 under the diffusor, then you should be able to get them on without mods.
03-20-2022, 12:22 AM | #5 | |
Rep 16
03-20-2022, 03:38 PM | #6 | ||
Rep 16
03-20-2022, 10:36 PM | #7 | |
Rep 2,590
2015 BMW 535xi
03-23-2022, 07:35 AM | #9 |
Petrolhead
440
Rep 808
So you got a true M5-spec diffuser. That means any muffler made for the 550i will not work with it since the tips sit further out. I mean some can be welded to work, but definitely not the Dinans. Trust me, many of us have already looked into and/or tried.
Any muffler made for the M5 will work just fine, regardless of hangers.
03-23-2022, 07:23 PM | #10 | |
Rep 16
05-02-2022, 08:46 AM | #11 |
Rep 16
Sorry for the late post…thanks to everyone's input. I decided on going with the Eisenmann exhaust for the 535. I muffler shop did have to modify the hangers since i had a small clearance issue with the m5 OEM diffuser but nothing major.
