04-21-2022, 06:15 PM | #1 |
Rep 332
Drives: F10 535i xDrive, F25 xDrive35i
Axle not sliding in
Hey guys. I'm at a massive loss on what to do. I searched everywhere that I could.
I had rebuilt the front passenger side axle and went to go put it back in. It's the original axle. It won't slide in 100%, there's no amount of force that will push it back in 100%. It's engaging on the differential just fine, but it wont slide all the way in so that it sits on the axle seal...therefore, it's leaking diff fluid. I removed the ring to see if that was causing an obstruction and the story is the same. I tried to use a mallet while turning the axle - didn't work. It makes no sense to me as it's the same literal axle that was in the car, just now rebuilt. |
05-06-2022, 09:37 PM | #2 | |
Rep 207
05-08-2022, 12:45 PM | #3 |
Rep 2,587
You mean you can't get it past the locking ring on the spline of the half axle? This is what I did: get the outer end that engages with the wheel carrier and get it engaged with the wheel carrier, and use the wheel carrier as a giant handle/press to push it in. You should hear a really loud KA-THUNK once it engages properly, and the plastic seal "cover" should only have around 1/4" space between the plastic cover and the diff.
2015 BMW 535xi
