2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 275/30R20 on 11 inch wheel? Is Kumho usable?
      03-10-2019, 01:59 PM   #1
ihatemyfitment
Drives: Bmw F10 525d M-Sport
does anyone have a picture of 275/30R20 or 275/35R20 on a 11 inch wheel? maybe also with kumho tires?
Purchased my new 11" wheels and looking for a minimalist stretch kind of wheel with tyre.
Gonna run with 20x10" 245/35R20 front and 20x11 275/30 (or 35) back. Looking for referens pictures.
not gonna slam the car, only lowering springs, that's why im hesitating.
      03-10-2019, 11:49 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
here's my 21x11 with 295's with a slight stretch. so with 275's it'll really be stretched in my opinion
this is with my coilovers setup high to give you a better look at the sidewall
      03-12-2019, 03:08 PM   #3
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
If the fitment allows, why not go with 285/30/20?
      03-16-2019, 02:39 PM   #4
ihatemyfitment
What offset u got with those 11" ? tried my 11" with et 35 looks good but felt like it stick out a bit to much, saw an with et 28 if im not mistaken and it runs flush with fender??
      03-17-2019, 06:06 AM   #5
remmib
remmib's Avatar
Norway
1568
ET28 would stick out even more than the ET35. I believe it's ET38 in the pics above.
      03-17-2019, 08:54 AM   #6
lsturbointeg
like remmib said yes these are ET 38mm which to me is flush and no SPACERS! 275's to me would be stretched!
      03-17-2019, 06:52 PM   #7
neverdone
Drives: X5, 335, Ford Lightning, 63 me
I'm looking at getting 19x11 +35 with 275/35 as well, you guys are thinking that will be too stretched? I wont be lowered for now....
      03-18-2019, 09:11 AM   #8
lsturbointeg
I think so. doesn't matter the wheel size but it's still the same width 11" so 275 will have a really stretched look. if you look at my 295's and that's 20mm more and it still has a slight stretch from the pictures I posted. from most post listed guys running with an 11" width are trying to either get 295, 305 and even 315's to fit tho a 315 you're better off with a 12" wide wheel
      03-18-2019, 08:18 PM   #9
neverdone
So are you running 255 in the front then?
      03-19-2019, 11:24 AM   #10
lsturbointeg
yes 255/30 r21 on a 9.5" wheel. need to run a spacer but now sure how much?
      03-19-2019, 05:33 PM   #11
neverdone
Doesnt look like much...5mm maybe.
      03-19-2019, 05:37 PM   #12
lsturbointeg
5mm That's probably about right. Gonna raise the car to get at least a 1/2" gap when it warms up a bit. Still in the mid 20's
      03-26-2019, 08:55 AM   #13
KEN210
China
Drives: F10/18 - 528
I have 275/35/20 with Niche 20 inch x 10.5 (offset: 35), saw some running marks on the tires so had to have a bit negative camber. Not sure though if it will be the same since we have here is longer wheelbase (F18 528li). My front is 245/40/20 with 20 inch x 9.0 (offset: 35) has no issue.
      03-27-2019, 08:09 AM   #14
TEF
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Not to detract from the car's great looks, but how do you manage Ohio roads without damaging those tires and/or wheels? I drive in NE Ohio regularly (in fact Cleveland on Monday) and do concede that most roads are better than those in PA, but there are areas under construction such as I 271 around Cleveland that never seem to be completed. It appears that even speed bumps might be a challenge.
      03-27-2019, 07:53 PM   #15
lsturbointeg
I don't drive my car on roads I've never been on. I stick to the usual areas that I know that don't have potholes and if they do i avoid them. mostly the nicer areas around Toledo like Maumee and Perrysburg. the roads in Michigan are shit lol! i only drive up there in August for the Woodward Dream Cruise and i pray i don't hit potholes than
      03-28-2019, 09:13 PM   #16
KEN210
China
Here are pictures with 245/40/20 with 20X9.0 (offset: 35) front. 275/35/20 with 20 X 10.5 (offset:35) back.
      04-01-2019, 01:38 PM   #17
JayyEVee
JayyEVee's Avatar
Drives: 2014 BMW 535i //M Sport
2014 BMW 535i  [0.00]
Gonna be quite a bit stretched, you may have the wheel rim poking some.
I run 285/30/20 on a 10.5 wheel in the back, and that's already stretched to my eyes. You're going the opposite directions on tire and wheel size (smaller, and wider).
If they are correct offset and not poking out, I'd hit a 295/30/20 and call it a day.
Don't think I have enough posts to share pics yet, so they may be invisible. :/
      04-02-2019, 08:14 PM   #18
Proimport
I'm running 20x10.5 +42 on the rear with 285/30/20 and it's a slight stretch so a 20x11 on a 275 will be a stretch stretch. I would do a 295 or a 305 on a 20x11.
      04-24-2019, 01:08 PM   #19
Lukaas54
France
Drives: BMW F10 530d
Hey,
Front fit is good ? You have spacer ?
Thanks 🤗
Lukas
      04-24-2019, 11:30 PM   #20
KEN210
China
Hey,
Thanks 🤗
Front just right. Did not use any spacer.
Tags
275/35r20, f10, tyre, wheels
