01-21-2022, 10:50 AM | #1 |
![]() ![]() 422
Rep 1,302
Drives: 2011 535i 6MT
B58 Coils
Just did the upgrade and holy cow! smooth as butter... I'll post a quick video here soon. Pics on insta. Totally worth it.
![]() 2011 535i 6MT DS Tune, Custom Intake, meth, PS2, B58 Coils, FBO, E mix Instagram - @bimmerhausperformance Check out videos here |
01-22-2022, 02:36 PM | #2 |
![]() ![]() 818
Rep 2,198
What adapter plate did you go with?
2015 BMW 535xi
01-23-2022, 09:27 AM | #3 |
![]() ![]() 422
Rep 1,302
I got the nxm plates. But I have an early n55 so the mounting holes didn't line up, I had to slightly modify them.
The kit comes with longer boots for the coils and the wire harness, so you need more than just the brackets.
01-23-2022, 03:19 PM | #4 |
![]() 15
Rep 63
Drives: 2011 535ix M-sport
Hmm, I too have an early N55 so modifying the existing holes is interesting.
On another note, I believe your Instagram is @bimmerhausperformance, different than what's on your sig
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
01-23-2022, 10:28 PM | #5 |
![]() ![]() 422
Rep 1,302
Thanks, it is updated. I didn't modify the hole itself, just used oversized washers to pin them down. I will do a you tube video soon.
01-31-2022, 09:42 AM | #7 | ||
![]() ![]() 818
Rep 2,198
From that thread's conclusion: Quote:
2015 BMW 535xi
BrowBMW421.50 |
01-31-2022, 09:45 AM | #8 |
![]() ![]() 422
Rep 1,302
Practically speaking, I have better spark which translates to better combustion, less timing corrections, which builds boost faster and allows me to turn boost up because I get less knock.
02-01-2022, 11:02 AM | #9 |
![]() 291
Rep 1,207
Great product i had to sell to Dan!!! I see hes loving it!!
N55 GENERAL
![]() David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
02-01-2022, 01:09 PM | #10 |
![]() ![]() ![]() 113
Rep 396
does this require re-tuning on whatever tune will be used ?
02-01-2022, 01:12 PM | #11 |
![]() ![]() 422
Rep 1,302
There is a check box within MHD you can check for these coils, but if you are on a custom tune your tuner will be able to add boost if you have the fuel available.
02-01-2022, 01:14 PM | #12 |
Rep 396
ohhh.. Im BM3.. so i'll have to check, I heard people having really good luck with these.. was wondering for awhile... how much for the 6 cost you?
02-01-2022, 01:19 PM | #13 |
![]() ![]() 422
Rep 1,302
The coils are one cost... you can google B58 Coils from FCP or ECS, then the kit to adapt them to your car from nxm is a separate cost. Kit is the wire harness, install plates, and the longer boots for the coils.
zvery77725.50 |
02-01-2022, 02:38 PM | #14 |
Rep 396
Thanks for info... i'll keep that in mind
02-01-2022, 09:56 PM | #15 |
![]() ![]() 111
Rep 314
here another alternative for the earlier n55
https://www.e 90post.com/forums/showpost.php?p=27973271&postcount=15 https://www.e 90post.com/forums/showthread.php?t=1822338&page=2
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
02-28-2022, 05:29 PM | #16 |
![]() 353
Rep 1,076
I contacted bootmod3, they have enabled b58 coil option now on website, app to follow
SWFLf1081.50 musclesmarinara75112.50 |
03-01-2022, 10:16 PM | #17 |
![]() ![]() ![]() 154
Rep 516
So I've been rocking the B58 coils for a couple weeks now (Eldor B58 coils sourced from FCP along with the Nexsys conversion kit). I can attest that even on the stock PWG turbo the improvement is noticeable. Both in idle and WOT, but also in normal driving. As I was telling others, the rev-range feels "effortless". It's still hard to describe but it feels butter smooth and VERY responsive.
Having said that, I am truly happy with it. Is this something for everyone? Probably not. I cannot tell if I feel more power or not. I honestly do not think so (on my baby PWG stock turbo). I personally did it being aware of the many benefits of having a stronger voltage & longer duration spark. This improvement will mostly be felt when pushing the limits of the ignition system once equipped with a larger turbo (which I intend to do). A tuner can push the limits of boost and ignition timing FURTHER and SAFELY. Who would I recommend this to? - ALL who are going to run a larger turbo, point blank. Is it NEEDED, no. Is it better than N55 Eldor coils, or PR coils? According to testing over in "that unspoken other forum", yes if it! Which means better tuning potential for you. I can again confirm that they have made a noticeable improvement as stated above - ANY N55 owner that is ODC about smoothness. It made my car feel newer than it is. This is from someone rocking a fresh set of plugs and full stock gap AND new Eldor coils (with which I was very happy with... until I switched to this B58 kit and was blown away). Hope my opinion helps others!
11' 535i M-sport- BimmerHaus Intake/ GPlus IC/ BMS CP/ EBay Kittyless DP/ Valved Mufflers/ MHD David Shoup E50 Tuned/ B58 Coils/ xHP3/ Stoptech & Hawk/ H&R Sport/ F Strut Brace/ Spacers/ BimmerCoded/ S9 Ceramic 20% Tints/ Flat-Bottom Wheel/ CF Exterior Bits
BrowBMW421.50 musclesmarinara75112.50 |
03-02-2022, 01:58 AM | #18 |
Rep 396
Brow.. and BlkMax... I currently have step colder plugs, If I go with the B5b coils, should I use the same colder plugs?.. or go with what was stock?
03-02-2022, 06:07 AM | #19 | |
![]() ![]() 338
Rep 1,736
My F10 is 3 or 4/2011 production (different places say different things). As far as I know I have original coils, but the plugs have supposedly been replaced under a warranty RO by the dealer. (The injectors were also supposedly replaced, but I'm suspicious whether it was done, or it was done and they skipped coding the compensation numbers into the DME because it's never idled quite right since they replaced all of the injectors. I'm going to explore if I have any hope of reading the flow compensation numbers off of the injectors while they're installed. Based on research I don't think I want to pull them just to read a number and then reinstall them.) Anyways - Any good threads or guides on choosing the right adapter kit depending on the different versions of things one might have etc...? Maybe I'll put B58 coils and plugs on the 2022 list along with a few other things, but I would be ordering cross-border so I need to get all the right stuff the first time. |
03-02-2022, 06:32 AM | #20 | ||
Rep 516
So mine was built April 2011 and this is what my injector bracket looks like (metal T)... ![]() So the Nexsys kit that is currently made works perfectly on this kit. BroBMW's has the early N55 injector bracket/ plate and it's that format that would require the slight modding to make it fit. Nexsys is allegedly working on an early N55 kit already but I do not know when it will release. Yea unfortunately to see the #s on our injectors they do have to come up and out of the cylinder head as they are on the side. Meaning you'll want to have 6 decoupling elements (metal crush ring seals) and 6 nylon seals (the seals at the tip of the injectors). None of them are reusable.
03-02-2022, 09:01 PM | #21 |
Rep 396
I thought you wrote T sharp.... I didn't realize you were writing out T SHAPE... about your bracket... I was lost for a minute
03-02-2022, 10:03 PM | #22 | |
Rep 516
