2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Brake Force Display - BimmerCode
      03-01-2019, 10:51 AM   #1
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
I just finished coding for Brake Force Display via BimmerCode. Didn't need to get into Expert Mode, it was all there in the Footwell Module (FRM) menu. I only did two things...
Brake Force Display Type/ Blinking
Brake Force Display flashing frequency/5
Below is a screenshot of the menu before making changes to BFD.
IF you are not familiar with Brake Force Display, please take a look at the video below...
Video Source: Michael Marrero via YouTube Share
      03-01-2019, 11:41 AM   #2
philipm785
Drives: 2016 550i
Interesting - didn't know this was possible. I've always thought that the brake force display was a good idea but unlikely to be all that noticeable to the average driver. The flashing will definitely get attention in emergency braking situations.
John H.230.00
      03-01-2019, 03:01 PM   #3
John H.
John H.'s Avatar
NHTSA Research on "Rear Signaling."
by NHSTA
https://one.nhtsa.gov/Research/Human...Rear-signaling
"New Code: Change of the Brake Force Display in NA."
by JEG23
https://www.bimmerfest.com/forums/sh...d.php?t=675251
      03-01-2019, 05:07 PM   #4
philipm785
Drives: 2016 550i
Thanks for this great additional information. Definitely got me thinking about this.
John H.230.00
      03-01-2019, 08:23 PM   #5
John H.
John H.'s Avatar
Phil:
Were you aware that we have rear fog lamps? All you need is a European switch....
ECS Tuning - European Lighting Options
https://www.ecstuning.com/News/BMW_F...013_2014_2015/
Plug and play. No coding required for this option.
Never been to GA; however, I have a good friend that resides in Jasper. He has told me it can get misty out that way. This is a good safety option without the hassles of coding.
Rear Fog Lights - OFF
Rear Fog Lights - ON
      03-04-2019, 07:58 AM   #6
philipm785
Drives: 2016 550i
Thank you! It definitely does get misty here in GA and I've wished we had the rear fog light option a couple of times this year already.
      03-04-2019, 08:47 AM   #7
John H.
John H.'s Avatar
It is a good way to keep persons off your six. I have engaged this option in heavy LA traffic, as some drivers get a little too close for comfort. Also, on several occasions, have engaged this feature in coastal fog.
JFYI, this rear fog light feature can be coded. If I am not mistaken, it turns on with the headlights. I have seen the option in BimmerCode. I prefer the Euro switch, as you have the on/off button.
In regards to BFD, I will shoot a video, and post.
      03-04-2019, 02:38 PM   #8
I coded BFD so a following driver can see just how fast I'm slowing. As the car doesn't "nose-dive" in heavy braking, it gives the in-trail driver a visual signal that I've stomped on the whoo pedal.
The rear fog light option is already coded and just needs the switch. They can be had from many places and is a simple plug-n-play job. It pretty much takes longer to talk about it than to actually do the work.
John H.230.00
      03-05-2019, 07:40 AM   #9
Surly73
I would love to see some additional coding options for BFD which would influence activation when ABS activates too, not just a certain deceleration rate. When it's slippery out, it would be valuable for those following you to know you're braking at your traction limit, even if that isn't very much braking force. Maybe those options are in there - don't know.
Agree did this on my F10 and E90 (though on the E90 I just had to cut two little plastic tabs - the rear fog button is already there just limited from being pushed. Zero cost!)
      03-05-2019, 08:31 PM   #10
it's not a deceleration rate, it's based on pedal force.
      03-06-2019, 07:16 AM   #11
Surly73
That's not what I've read (and still doesn't address the issue of braking on ice etc...)
Even JEG23's thread linked earlier in this thread (https://www.bimmerfest.com/forums/sh...d.php?t=675251) documents parameter FRM_AUSSENLICHT_PARAMETER expressing triggering deceleration in m/s^2
FRM->3050 FRM_AUSSENLICHT_PARAMETER, 30->ESS_ON_VERZ (default for Europe (14 dec) 10 m/s2; default for US (10 dec) 8 m/s2)
I'm just saying that I'd love another verte or aktiv option to add ABS as a trigger. If you're braking at your limit, regardless of how much deceleration or pedal force, give the option to activate BFD.
      03-06-2019, 12:51 PM   #12
I would have sworn I read it was based on how hard/fast the pedal was pushed...
I sit corrected!
      03-08-2019, 12:21 AM   #13
John H.
John H.'s Avatar
*Phone app users: For some odd reason, the Vimeo video link is NOT SHOWING in phone app. The video number at Vimeo is 322171041
As promised, here is the video...
https://vimeo.com/322171041
http://vimeo.com/322171041
My current BFD settings...
      09-11-2019, 12:59 PM   #14
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
Can someone verify if this works on the pre LCI F10? I see these options in my Bimmercode and have coded, but do not have a way to verify if the Brake Force display is actually functioning while driving.
      09-12-2019, 08:45 AM   #15
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
You need to full brake with ABS on high speed.
      09-12-2019, 07:46 PM   #16
Surly73
Verify WHAT works? The phone coding - no idea. My F10 is pre-LCI and the BFD stuff I documented above is working.
      02-27-2020, 01:50 PM   #17
Casebrius
Drives: 2016 535 M-Sport; 95,97 E36 M3
I mapped adjusted options in footwell Module, but it is still not working in my 2016 F10 535. Is there somewhere else I need to turn it on? There are only 3 options in my brake force display box... ‘brake force display type’ is not an option.
      02-27-2020, 02:51 PM   #18
ramman434
Drives: F30 335i
I had the same issue on my '16. I gave up, but I do want to look back into this.
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
      02-28-2020, 12:23 AM   #19
Casebrius
Did you have a V-Gate Wi-Fi dongle? I think I read this may be the problem....
      02-28-2020, 05:07 AM   #20
John H.
John H.'s Avatar
If I remember correctly....Activated it in basic mode, and went into expert mode to adjust the g-force and delay settings.
      02-28-2020, 12:11 PM   #21
ramman434
Drives: F30 335i
No, I've got the VeePeak:
https://www.amazon.com/Veepeak-OBDCh...403a356b82a4e8
I haven't tried going into expert mode on the app yet. Don't wanna screw anything up
      02-28-2020, 12:12 PM   #22
ramman434
Drives: F30 335i
Any chance of getting a screenshot of your settings?
I was bummed when my wife was following me, and said that my lights weren't flashing under braking.
