2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Wheel spacers
      09-30-2018, 02:42 PM   #1
v8power550xi
Drives: 2013 bmw 550
Wheel spacers
I need some information I want to get some wheel spacers installed on my car., I have the regular stock m rims 19" on my 2013 bmw 550xi. I wanted to know what spacers should i get would
Like my rear to come out more for some grip
      09-30-2018, 09:51 PM   #2
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
15mm rear and 10mm front. I recommend the BMS Tuning brand spacers personally, but any quality spacers and extended bolts will be fine.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      09-30-2018, 10:00 PM   #3
v8power550xi
Heyyy thanks man can you send me a link of a website I can purchase
      10-01-2018, 08:09 AM   #4
bake
bake's Avatar
http://www.burgertuning.com/BMW_wheel_spacers.html
Bake
      10-04-2018, 10:30 PM   #5
socale39
Drives: 04 545i SMG
I’d recommend getting non colored spacers. Over time they discolor and frankly look bad. Stick with H&R IMO
      10-29-2018, 10:51 AM   #6
LondonF10
Drives: F30 320d m sport
Could you advise on spacers size...I have OEM 373’s on my F10 2015 535d m...
Thank you
      10-29-2018, 09:27 PM   #7
bake
bake's Avatar
Thank you
373's have the same offsets as 351's. 10mm front and 15mm rear.
Bake
      10-30-2018, 04:03 PM   #8
LondonF10
Thank you 🙏🏼
      11-20-2018, 12:10 AM   #9
BMWF10550i
Drives: 550i
I have 12mm in front and 20mm in the rear. No issues on stock m sport 19".
https://drive.google.com/file/d/1-71...w?usp=drivesdk
https://drive.google.com/file/d/1-4u...w?usp=drivesdk
https://drive.google.com/file/d/1-8r...w?usp=drivesdk
https://drive.google.com/file/d/1-9a...w?usp=drivesdk
      11-20-2018, 03:46 AM   #10
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
looks good and flush!
      11-21-2018, 11:45 AM   #11
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
How much spacers going on style 312 rear,front wheels look regular.
      11-25-2018, 06:43 AM   #12
Jaap968
Drives: 535i xDrive Touring
Seeing the recommendations I just wonder if the track width of a xDrive (AWD) model is different as I just changed from 18" to the 351m 19" on my 535i xDrive Touring and don't think I could fit any spacer up front without the wheel sticking out. On the rear I have added a 12mm which also seems the max. Maybe it is because the ride height of the xDrive which results in no negative camber (even slightly positive) at the front?
      11-25-2018, 12:08 PM   #13
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Pretty sure it's the same track width. I think it's the ride height, the fronts really cambers in when you lowers it.
      12-19-2018, 01:51 PM   #14
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
I have a set of 10mm H&R spacers if anyone is interested.
I used the for a couple weeks before I picked up rims.
Let me know.
      12-22-2018, 07:21 PM   #15
Duckysaurus
Duckysaurus's Avatar
42
Drives: 2021 G05, 2014 F10, 2009 E90
2014 BMW 535xi  [8.50]
2009 BMW 328i  [0.00]
I'm running with 0mm front and 15mm rears for tiny bit more grip+looks. Depends how aggressive you want it to be.
      12-23-2018, 11:48 AM   #16
F10535
Drives: 535i
Let me know.
how much ?
      03-08-2021, 09:31 PM   #17
RuskyRambo550iX
Drives: 2015 550i xDrive
So I know this is an old thread, but wanted to just see if I understand this correctly, on a stock 2015 550i xDrive with 19s square setup, a 15mm spacer for the back should be sufficient, correct?
      08-02-2023, 12:32 PM   #18
starlights
Drives: G05 50i
Just listed a set of Turner Motorsports Spacers with extended lugs in the marketplace incase someone is looking. 12.5mm & 15mm. Barely used.
https://f10.5post.com/forums/showthread.php?t=2037908
