2010 2011 BMW 5 Series Forum F10 Future BMW model information |
04-27-2021, 11:40 AM | #882 |
Rep 19,368
05-01-2021, 09:25 AM | #884 |
Rep 3,479
Still very interested in the G09 X8/XM.
Apparently I wasn't fast enough to see whatever news popped up for a bit on this. But the X8/XM is still supposed to be BMW's first "built from the ground up" vehicle in the modern era, not sharing the CLAR with the rest of the line. Will not be a coupe X7. On my recent PCD, I was at least able to confirm this much with various BMW staff, and that it's still coming. Oh, and that it will be built in Spartanburg. They're tight lipped about everything else. Most likely to have 2 rows, not 3. What I'm seeing, condensed info from the first post:
Cross-continent road trip journal from BMW PCD to Alaska in new X7 M50i in this thread HERE!
New EVEN BIGGER road trip in X5 from BMW PCD to Alaska NOW ONGOING LIVE IN THIS THREAD! Wilderness road trip journal to Eastern Alaska in this thread And road trip journal to Denali and the Arctic Circle here in this thread! Last edited by Wild Blue; 05-01-2021 at 05:29 PM.. |
05-01-2021, 02:51 PM | #885 |
Rep 2,335
Not sure if this is accurate but according to @XtremeMaC these are planned production numbers for the Supra as well as a EOP date of March 2026.
05-02-2021, 04:06 PM | #886 |
Rep 804
I think the april 2021 G87 entry is a bit misleading here without the above clarification ("Though ceramic brakes and bucket seats seem to be missing, all the drivetrain and suspension things are the same as G82" sounds like AWD would be a possible option, at least to me and several others who asked about it), maybe add that to the top post (and the https://g80.bimmerpost.com/forums/sh....php?t=1820632 copy)?
05-03-2021, 03:49 PM | #887 |
Rep 300
XM? That's a Citroën!
4BMWGarage371.00 |
05-04-2021, 09:16 AM | #888 |
Rep 658
Drives: i7 xDrive60
A long time ago when Volvo planned to change the name of the 850 to S7 (and smaller model to S4) they got into problems with Audi so the hade to change the name to S70 and S40. I wounder how this will go for the XM?
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30) |
05-05-2021, 02:12 AM | #889 | |
Rep 2,350
https://www.scania.com/uk/en/home/ex...eper-cabs.html
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
05-05-2021, 08:18 AM | #890 | |
Rep 658
Drives: i7 xDrive60
Scania S 450 or MB S 450?
/Fredrik
05-05-2021, 02:12 PM | #891 |
Rep 2,350
An obvious cross-shop and potential for confusion
05-08-2021, 05:26 AM | #893 |
Rep 125
05-08-2021, 06:43 AM | #894 | |
Rep 6
Maybe eDrive40 also has a "boost" mode. Last edited by brainDotExe; 05-08-2021 at 10:22 AM.. |
05-09-2021, 07:42 PM | #895 |
Rep 13,138
As start of production of the G80 M3 LCI (facelift) and the G82 M4 CSL is scheduled for July 2022 (coinciding with the BMW M '50 Jahre' events), I guess that we may reasonably assume that SOP of the G80 M3 CS will not precede SOP of those two cars.
///M is art ↔ Artemis
05-11-2021, 09:47 AM | #896 | |
Rep 647
Depending on how drastically the LCI changes G80, the current version might end up becoming a real rarity down the line.
///Meant-to-be-sent
05-11-2021, 09:50 AM | #897 | ||
Rep 5,149
05-11-2021, 11:25 AM | #898 | |
Rep 19,368
https://g80.bimmerpost.com/forums/sh....php?t=1781529 https://g80.bimmerpost.com/forums/sh....php?t=1808330 |
BMthusiast785.00 |
05-11-2021, 11:45 AM | #900 |
Rep 19,368
So, for those keeping score:
iX xDrive40 320hp iX xDrive50 515hp iX M60 560hp i4 eDrive35 300hp i4 eDrive40 335hp i4 M50 470hp I suspect we'll soon learn that the numeric value in the name is a reflection of battery capacity only. In other words, I don't think there is any attempt here to correlate the badge to power output like there is with the gasoline and diesel lineups. For example, a future i4 xDrive40 will not make 320hp like the iX xDrive40 does. I say this not least because that would nonsensically put its output below the RWD eDrive40 model's output. Furthermore, an iX M50 (which probably won't exist, but theoretically could) would obviously not have only 470hp like the i4 M50 model does. This is because, again, that would nonsensically place it below the non-M xDrive50 model in the lineup. TL;DR: when it comes to BMW EVs, don't try to guess motor output based on the badge. I was wondering that as well. As you suggest, that may be another model coming later. However, a mere 12% bump in power for the flagship M model over its lesser sibling would be a bit of an uncharacteristic move. Perhaps they intend to deliver even more power for said flagship? They could use the 560hp setup from the iX M60, for example. Though, it's not clear if the i4 will support the "60" battery which is probably paired with the higher output motors in order to yield a more reasonable EPA range. |
05-11-2021, 12:59 PM | #902 | |
Rep 2,180
Tags |
future bmw, release date, upcoming bmw |
