2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications How many F10 N55 owners had a charge pipe cracks?
      05-04-2018, 02:30 PM   #45
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
Originally Posted by AMTF10 View Post
You guys make me feel dumb. I ubered for a week to work and back while waiting for my CP to arrive. I had zip ties in the trunk too lol...
Ah dude sorry to hear man!!! I got my VRSF CP in last night, paid for 2-3 day shipping to HI. Install was NOT as easy as everyone says. A bit of a pain to finagle into place, but only took maybe 15 mins. However it was almost impossible to get the CP onto the throttle. It took me an hour in itself and I threw my back out trying to torque it on (I'm only 30 ).
Anyway after an hour of pushing and pulling from all 3 sides of the engine bay, it finally went on. I had to wiggle it for about 5 minutes straight under pressure from different angles until it finally went on all the way. I was literally laying across the engine bay with my feet in the air trying to slip it into place, dripping sweat, and cursing up a storm.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      05-04-2018, 02:32 PM   #46
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Sounds about right. My VRSF install was not easy. I'm definitely leaving it on there when I sell the car. That uninstall isn't worth it
      05-04-2018, 04:19 PM   #47
5soko
5soko's Avatar
333
Drives: M5
Damn, any other companies make a easier and more proper fitment CP for our cars?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      05-04-2018, 04:38 PM   #48
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
The issue isn't fitment. The issue is getting the entire CP in there when it's a non flexing aluminum piece.
      05-05-2018, 05:05 PM   #49
paul223
paul223's Avatar
Drives: F10
FTP charpipe, it is two pieces
      05-05-2018, 11:20 PM   #50
5soko
5soko's Avatar
333
Drives: M5
to be honest, i did a oem CP install, back to stock for a friend, wasnt so hard once you got it at the right angle..
I think the oem CP can survived alot long if some super glue or adhesives is laid around the sensor holder ( Since this seems to be a area we are seeing some common failures at).
Here is the ER chargepipe install on the F10... Slid onto the throttle body with ease.
      05-05-2018, 11:21 PM   #51
5soko
5soko's Avatar
333
Drives: M5
https://www.ftpmotorsport.com.tw/pro...55-charge-pipe
Seems to be a full one piece CP?
The value seems great with this one since it includes the oem clip and seal. But as always, its all about fit and seal at the throttle body, any experiences?
I got my eye on the ER chargepipe, good price and very solidd company with bmw turbo performance parts for years.
      05-06-2018, 11:52 AM   #52
paul223
paul223's Avatar
Drives: F10
It is one piece with rubber flex connect, I have it installed. It is easy to do.
      05-07-2018, 07:06 AM   #53
bradsm87
Australia
595
Drives: F25 LCI xDrive30d
Not true, On $70K car OEM is plastic, so product is certainly better than OEM. You automatically assumed it is lower quality than OEM!
HAHA just because it's aluminium doesn't automatically make it unconditionally better quality
These cars would be rubbish and weigh well over 2 tonne and way more expensive too if BMW made every part that's plastic out of Aluminium. The issue is they didn't quite put enough thickness and/or adhesion in a couple of spots for increased boost levels. I've ran my N54 with upgraded turbos on 17psi for years with the stock charge pipe. Plastic is an excellent material. It's the implementation of that plastic that varies.
      05-07-2018, 02:41 PM   #54
Shieldze1025
Drives: F10 535i
Ugh made me sick watching how easy that slid on to the throttle.
Lesson learned
-Mario Andretti
5soko333.00
      05-21-2018, 06:13 PM   #55
5soko
5soko's Avatar
333
Drives: M5
After digging into the F10 chargepipe issues, i have found that the F10 N55 has had 3 versions of chargepipes in its liftime.. The latest and greatest chargepipe do not come with a support hold or mount in the middle of them. Those started in the MY2014 F10 N55's.
Black plastic welder... sets in 10 minutes, 5 minute working time.. Cures in 24 hours.
Wire ties to hold it down while the it sets.
Preventive maintenance. This thing is never coming off lol.
      05-22-2018, 09:18 PM   #56
Dzbeslic
Dzbeslic's Avatar
Drives: 2013 BMW F10 535xi
Lol, good one, hahahahaha
exclusivo125.50
      10-08-2018, 10:24 PM   #57
exclusivo
exclusivo's Avatar
126
Drives: race car
LMFAO the sensor port blew off of my charge pipe over the weekend. My wife called her uncle who is a mechanic and told him I need help because I was gluing (JB Weld) parts of my car back together. Glad to come here and see my idea wasn't too far off, I added the zip tie too lol
      10-09-2018, 07:13 PM   #58
Shieldze1025
Drives: F10 535i
Haha classic! I suggust you inform your wife of your car knowledge I got mine convinced that I'm smarted than any mechanic, just so she won't try to go behind my back lol
People also like to think luxury cars are diamonds. They're just cars, they work the same way. Air goes in, add some fuel, a spark, and compression and you have power. In this case it's simply pressurized air, zip tie a glue will get you through!
But I would definitely recommend replacing it with a better one. You'll be running at 95% efficiency until then.
-Mario Andretti
      10-09-2018, 11:54 PM   #59
burro_blasta
Drives: 2013 535 M Sport
Was also losing my mind trying to get my vrsf CP on to the throttle body...I think it was just the dry o ring and dry metal against metal making it too tough
Rubbed vasoline around the inside of the vrsf CP making sure to cover the o ring and then it magically slid on to the throttle body. Was almost worth the earlier agony for the sweet sweet relief when it finally easily slid right on
      11-05-2018, 06:47 AM   #60
tcabill
tcabill's Avatar
Drives: e63 650i, F10 535i, E93 335i
Mine blew the TMAP sensor off too, peak boost @ 20psi.
2012 535i M-Sport PWG, Wagner FMIC, VSRF no meow, chargepipe, Walbro 450 with custom fuel lines, MHD map e30 2+, JB4 (monitor and logging only now), xHP Stage 3, K&N drop-in, Paddleshift retrofit
      11-05-2018, 05:48 PM   #61
Bts535i
Drives: 2012 535i xdrive
thanks.. I haven't seen to many people having trouble with ours and have been putting it off.. guess it's time for a piece of mind at least
      11-06-2018, 07:56 PM   #62
5soko
5soko's Avatar
333
Drives: M5
Been running my OEM chargepipe for a while now at 14 psi with catless downpies, so far so good.. OEM chargepipe has held up well.
      11-07-2018, 06:30 PM   #63
Shieldze1025
Drives: F10 535i
Nice man. Mine blew about 4 weeks after switching to a catless DP.
-Mario Andretti
      11-08-2018, 06:45 AM   #64
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
I am stage two (recently switched to MHD stage 2 after installing ER catless dp) and have not really pushed the car for the fear of destroying my chargepipe. VRSP went on sale yesterday, and I immediately placed an order for one. Only if VRSF would hurry up with their intercooler I would do a stage 2+ and start logging.
      01-03-2019, 01:38 PM   #65
t.otoole51
Drives: 2011 F10 535i msport
2011 BMW/535i  [0.00]
I haven't heard or seen of many N55 owners with cracked charge pipes, so was wondering how common it was on the F10..
If so, miles and year of F10 N55.
First time blogger so if this isn't how to you post, forgive me. I have a 2011 F10 535i mSport. Fully stock. Getting bootmod3 tomorrow and charge pipe next week (when the part comes in).
No issues with stock charge pipe but my mechanic strongly recommended upgrading for long-term reliability.
      01-04-2019, 02:37 PM   #66
SWFLf10
SWFLf10's Avatar
I personally haven't witnessed any issues with my 535, but a friend with a 435 had his chargepipe blow apart with only 25,000 miles and the only mod was a sport cat downpipe. I know they are different chargepipe designs, but I still think it's a smart idea to replace the stock one with an aluminum aftermarket one for peace of mind.
