2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications How many F10 N55 owners had a charge pipe cracks?
      01-04-2019, 05:42 PM   #67
Originally Posted by SWFLf10 View Post
I personally haven't witnessed any issues with my 535, but a friend with a 435 had his chargepipe blow apart with only 25,000 miles and the only mod was a sport cat downpipe. I know they are different chargepipe designs, but I still think it's a smart idea to replace the stock one with an aluminum aftermarket one for peace of mind.
Were only that an option in The People's Republik of Kommiefornya...
      01-09-2019, 02:19 PM   #68
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
FWIW, our local club has seen half a dozen of the charge pipes fail on N55's between different series.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      02-04-2019, 01:37 PM   #69
w1zk1d
Just here to learn.
w1zk1d's Avatar
Drives: 2020 BMW M550i xDrive
Does this void any warranty if installed?
      02-05-2019, 11:38 AM   #70
Freak1c
Freak1c's Avatar
145
Drives: 2018 M3 ZCP MW
In the process of changing out my charge pipe for a for an aftermarket CP I broke the stock pipe trying to remove the vacuum line. The entire connector just broke off the CP. It very clear that the stock CP is very brittle.
      02-05-2019, 05:51 PM   #71
Make sure it has a CARB sticker before you go in for a smog check. ANY intake "modification" without the CARB sticker will be an immediate failure. If your new CP (intake) doesn't come with a CARB sticker, have a stock CP on hand for the smog check. Side note... Just got the registration notice for my 2014 535i. Even though a smog check should be required, a new law says all I need to do to is pay a $20 smog check fee; without getting a smog check! Can't tell me it's about mitigating pollution!!
Been there (not BMW), done that, had to reinstall the entire factory intake...
      08-14-2020, 04:42 PM   #72
Phiwee
Drives: F30
Sorry to bump such an old thread.
It was a pain the a$$ to get the charge pipe in. Honestly shoulda just went with ER brand if Goes in as easily as Bryan@Kies.
How necessary is putting the rubber o ring inside? I even tried lubing it up as someone mentioned on new pipe and still wouldn’t go in. But without the o ring inside it went on so easily?!
It still feels super tight and secure with the clamp on the shell.
      08-14-2020, 05:11 PM   #73
Surly73
I'm thinking that you'll definitely be needing any O-rings. My FTP installed OK. Because of something stupid I did, I had to do the process twice. The first time went super easy. The second time, for whatever reason, I seemed to scratch the new CP against more things. Oh well.
      08-14-2020, 05:11 PM   #74
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
You'll get boost leaks without the O ring.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      08-16-2020, 03:31 PM   #75
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
i went VRSF and had issues installing it. that was only because i was being a girl when trying to get the CP to slide on. stood on the motor with my knee and yanked up really hard and it popped into place to where i was able to get the c-clip in place.
      08-16-2020, 06:20 PM   #76
Phiwee
Drives: F30
How necessary is putting the rubber o ring inside? I even tried lubing it up as someone mentioned on new pipe and still wouldn't go in. But without the o ring inside it went on so easily?!
LOL! Man how did you even get up on the engine with the hood being there
I finally got it in too, shoulda went with ER! But I was being cheap because it was cheaper :
      04-18-2022, 11:37 PM   #77
aumazdelete
aumazdelete's Avatar
Drives: 2012 BMW 535 xi
This literally has to be the worst install ever!!! It took me 30 mins to get everything off and prepared. I have been trying to get that top end into the throttle body for the last 5 hours. Waiting for my friend to get here and I’ll have him pull while I pushed against the charge pipe and hopefully it snaps into place. I have tried VASELINE like the countless YouTube comments said to Lmao. I even swapped the old O ring into the new charge pipe and it still will not click. What the hell I should’ve read these reviews about the VRSF charge pipe before purchasing it. The other brand seems to click in right away
      04-19-2022, 01:37 AM   #78
aumazdelete
I kid you not I read this post … decided alright going to get on the motor lmao and just yanked the charge pipe as hard as I could and then it finally snapped on… greatest click I've ever heard .
      04-20-2022, 07:23 AM   #79
lsturbointeg
dude LOL! It was music to my hears when i heard the CLICK
      04-20-2022, 12:55 PM   #80
Speaking of "click," any of you guys watch Rainman Ray's Repairs on the youtube? Every time I tighten a nut, bolt or screw now I say "click" when it's tight enough! Does that make me a groupee?
