06-21-2022, 03:03 PM | #1 |
Rep 22
6WA Cluster Upgrade
Hi All!
I recently purchased a 2016 528i xDrive. Overall love the car but want something more digital as far as the cluster goes. I looked into a 6WB but couldn't justify the cost to myself, even though it is absolutely beautiful. I was looking to swap out my quarter digital one with the 6WA half digital cluster. I found one on eBay (link below) that says it will fit. From my research, it is pretty much plug and play with some coding. https://www.ebay.com/itm/35409359054...#38;media=COPY My question is, is it truly plug and play? Also, does the mileage of the replacement cluster matter? I've seen elsewhere that the donor cluster must be less mileage than my car? As for the coding, I'm in NJ. Can anyone recommend a coding guru to help me with this or even someone that can do it remotely? Thanks in advance and all! Sorry if this has been covered somewhere else. I'm new and I trying searching but couldn't find anything. |
06-21-2022, 03:29 PM | #2 |
Rep 1,356
They are not plug and play. Some vehicles have MOST connector separate so you may have to swap the connector to combine two plugs into one. You will have to clear the VIN and miles from the 6WA before you plug it into your vehicle. Once that is done, you will just need to code for 6WA.
06-21-2022, 08:37 PM | #3 | |
Rep 22
06-21-2022, 08:43 PM | #4 | ||
Rep 1,356
To clear VIN and coding, you can contact addy27 on here or Will at will@bimmerretrola.com They are very knowledgeable on this and can clear VIN and miles. You will have to ship the cluster to them to do it and then then you can have it coded |
06-21-2022, 09:04 PM | #5 | |||
Rep 22
06-29-2022, 03:07 PM | #8 |
Rep 22
OnlyGerman362.00 |
06-29-2022, 03:09 PM | #9 |
Rep 22
07-17-2022, 10:36 AM | #12 |
Rep 1,356
