2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 535i xDrive - Pure Stage 2 PWG
      08-15-2019, 12:04 AM   #111
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Originally Posted by lsturbointeg View Post
Originally Posted by ey2001 View Post
I'm on stock turbo... honestly with stock turbo I don't feel the lag with Wagner... now.. my old school Honda Accord... that has a lag... I had a big turbo on that...
I hear ya! With my Integra I had a smaller turbo so it spooled quickly but my intercooler was a medium size which worked well with my setup. Definitely brought down the IAT's. I'm gonna research and see if anyone went with an aftermarket radiator cause that would help especially with constant hard pulls. Funny how back than having turbo timers were a must but nowadays it's not needed with today's factory turbos
Yup.... I remember those days... I always thought turbo timer was bs but I remember going up to the canyons and when I popped my hook my turbo was glowing... I had the turbo time to like 2 mins and when the car shut off I checked the turbo and it wasn't bright red... lol.. mhd has coolant target settings to bring down the temp... I know you just installed the jb4 but maybe you could do a bef
      08-15-2019, 05:20 AM   #112
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Those were the days lol! BTW what's a bef? Part of the MHD?
      08-15-2019, 08:20 AM   #113
ey2001
ey2001's Avatar
310
Backend flash... you could use your jb4 and Ecu flash
      08-15-2019, 11:28 AM   #114
lsturbointeg
Duh, I made a post about BEF lol. That's probably something down the road i will do. All these projects cost money and sometimes the bank(wifey) denies my loan request
ey2001310.00
      03-02-2021, 07:43 AM   #115
Grownmanlos
Grownmanlos's Avatar
Drives: BMW f10
Originally Posted by jonobro View Post
How much was pure turbo upgrade and labor for someone to instal ?
Pure Stage 2 - $2125
Installation Kit - $200
Turbo Inlet - $414
VRSF FMIC - $575
VRSF Chargepipe - $180
LPFP Stage 2 - $100
DV+ - $135
Labor - $600 - I got hook up
Total - $4329
I am not including xHP Trans Flash in this because that is not part of turbo upgrade.
What's LPFP?
Hi do you have any links on the lpfp I'm looking to upgrade mine thanks
      03-02-2021, 10:05 AM   #116
ziekxq
Drives: 2011 535i xDrive
You can get this one:
https://www.summitracing.com/parts/v...8aArT0EALw_wcB
But I heard people getting the hellcat 525:
https://www.highflowfuel.com/i-35461...caAmrsEALw_wcB
I haven't seen a reason to upgrade yet plus my next move would be dual pumps though I don't anymore lol.
      03-02-2021, 12:44 PM   #117
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Originally Posted by bradsm87 View Post
They make the F series OTS maps for MHD as well as offering custom maps.
They seem to be in Germany, so I dont know how their response time will be.
You are not going with David Shroup?
2011 F10 S55 6MT
      03-02-2021, 01:39 PM   #118
ziekxq
That's an old post. I already went with David Shoup been with him close to a year I think.
I tried Twisted Tuning first and that didn't workout and then I found out about David and it has been all good since then. Been pushing 19psi. Wanted to do helix but not sure because that will add total cost to around 2000+.
I would need to get bpm4 module $700, another fuel pump plus bracket probably $150 bucks, then helix, mircon filter and e85 fuel line with Bluetooth sensor another $1400.
Not sure I want to do that but David said I can probably push 600 to the wheels if I do that.
      03-02-2021, 09:24 PM   #119
513
600 awd would be a fun ride...
2011 F10 S55 6MT
      03-02-2021, 09:30 PM   #120
mashpotato
Drives: '11 F10 N55
Just curious. Your differential/bushing, transfer case bushing are all ok at these power level (500+)? Or needs to be on polyurethane?
      03-02-2021, 11:01 PM   #121
ziekxq
So far yes though I am about to get rear diff gaskets and mount plus guibo replaced. But this is regular maintenance item at my mileage of 128k.
Since I am going to there replacing the mount I decided to go with this:
https://www.fcpeuro.com/products/bmw...reet-pfr5-6031
      07-03-2021, 03:50 PM   #122
ziekxq
Update - almost 20psi to redline on 3 gallon e85 + 93 octane with lpfp stage 2 (walboro 450):
https://datazap.me/u/ziekxq/v57-5th-...og=0&data=4-24
      07-03-2021, 04:54 PM   #123
513
https://datazap.me/u/ziekxq/v57-5th-...&data=4-24
Is that all David could pull out of the turbo safely even with the LPFP? I am doing my clutch now and was gonna start the tuning process, wasn't sure what to expect! Lmk… tyvm
2011 F10 S55 6MT
      07-03-2021, 05:03 PM   #124
513
Actually, looks like it! Your wgdc was at only 75% but you afr was down to under 12 at the end of the pull… so you need more fuel! Wow.
Did you see a big difference between the MHD OTS map and David's tune?
2011 F10 S55 6MT
      07-03-2021, 05:46 PM   #125
ziekxq
I never ran OTS map as I believe they only target 17psi if I remember correctly and drop towards the end.
I am pretty sure we can do 21psi but don't want to risk it at this fuel level... nothing David can do with just lpfp when limitation is now at hpfp... next goal is to get port injection setup so I can run full e85. Though, we not done tuning yet so who knows we might end up being at 21psi lol. Which is pretty good for the fuel I am running compare to what everyone said that you can't pull more then 17psi on the fuel system I am running atm.
      07-03-2021, 05:57 PM   #126
513
Yea, I am running 6-7 gallons of e85 on stock everything. Are you not going with helix overdrive?
2011 F10 S55 6MT
      07-03-2021, 06:18 PM   #127
ziekxq
Too many bad stories from helix, so I am going to do motiv reflex with port injection kit. I messaged spool to see if they have dual pump setup for our cars.
I am going to check with David if I should pour more e into the tank because previously before when we were testing to get my timing corrections to be at 0 he raised my rail pressure on hpfp to 2900psi somehow. I'll see if it is possible he can do that again or maybe he wouldn't want to mess with that now that car is running great when it comes to timing corrections.
      07-03-2021, 06:31 PM   #128
513
Have you asked DS about what he thinks about the helix? I know doubles took it off…
2011 F10 S55 6MT
      07-03-2021, 09:43 PM   #129
ziekxq
He said at first things were fine then people started having problems so he said you can put it at your own risk. He is basically neutral on helix.
      07-04-2021, 08:21 AM   #130
FdisFingF10
Drives: 2011 BMW 550i M Sport 6M
I was going to wait until fall for PS2 but seeing your flat 20 lbs across the log, ooof, I want it now haha.
I am 18.5 peak and holds about 14.5 to 6k then still just under 12 at 6800. Takes a lot to move this 4200+ lb monster.
      07-04-2021, 12:16 PM   #131
513
If you have the old style fuel pump and do not have any sort of active steering - this is an option too:
https://vargasturbo.com/product/shot...#configuration
In theory it seems "safer" than helix since it's overdriving the stock HPFP in a different way.
I'm not sure I want to do port injection and deal with controllers etc.
It moves our stock HPFP to be run off the belt instead:
https://www.e90post.com/forums/showthread.php?t=1435188
2011 F10 S55 6MT
      07-04-2021, 07:03 PM   #132
ziekxq
Not on my xdrive not compatible.... reflex by motiv is the new thing if you want to run port injection... read up on it. At this point I am trying to get as much power out as possible before moving in to a new car lol.
