03-21-2020, 11:28 AM | #1 |
Rep 119
Fuel additive for N55
Looked at these but at only 50k on my 2015 I'm not sure I need to add anything yet. Getting ready to do spark plugs, ignition coils, brake warning will probably come on any day. Thinking about doing an 8at fluid change and update.
Sup
03-21-2020, 01:30 PM | #2 |
Rep 2,590
Don't bother except for maybe injector cleaners, and even then it's questionable if it actually does anything.
2015 BMW 535xi
03-21-2020, 02:23 PM | #3 |
Rep 915
I usually run shell 93 vpower every few fill ups ill add techron fuel cleaner.
Instgram @burninja
03-22-2020, 09:36 AM | #6 |
Rep 915
Id run techron every few imo.
Instgram @burninja
04-21-2020, 12:37 PM | #7 |
Rep 616
Money is probably better off spent on walnut blasting. If you have crazy build up on your intake valves you will notice immediate difference in your car after a good cleaning. FYI running meth will help keep them clean too
04-30-2020, 02:49 PM | #10 |
Rep 1,154
ChiltiCoatl891769.00 |
05-05-2020, 09:02 AM | #11 |
Rep 14,522
I'm gonna start using Techron on every fill up! I don't daily drive the car and I now hope after adding the oil catch can this will help eliminate some of the blow by
05-07-2020, 12:21 PM | #12 |
Customize Everything!
44
Rep 279
Which catch can did you end up getting? I saw a massive thread about catch cans but feedback on finding one that has a oem like fit was hit or miss. Either the tubes were too big or pain in the ass to install and run the lines effeciently.
08-03-2020, 10:10 PM | #13 |
Rep 119
East Bay. You?
Sup
