2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications PLS Help F10 N55 constant misfire on cylinder 3
      02-22-2020, 10:30 PM   #1
NJQG
Car was running MHD stage 2 when it first started to get the misfire. Changed all the plugs as well as new coils. Problem still on cylinder 3. Next i figured maybe i'd try the fuel injector. Changed that and had it calibrated. Still same issue on cylinder 3. I also set the tune to stage 0. Just to see if it would by chance help it did not. I'm lost on what to do so any help or direction would be greatly appreciated. Car has intake, charge pipe, intercooler, and catless dp if that makes any difference.
      02-22-2020, 10:53 PM   #2
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Did you try changed the plugs and coils from cyl 3 to any others see if it changes? After that if it's still cyl 3 I would do a compression test
      02-22-2020, 10:56 PM   #3
NJQG
I swapped all out with new plugs and coils.
      02-22-2020, 11:49 PM   #4
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Did you tap your plugs down? Anywhere between .18 - .22
You can put in a gallon or 2 of e85 to calm the knock without any fuel upgrades. Don't go past 2 gallons if you don't have upgraded fueling hardware
IG: @bmwdoubles
      02-23-2020, 03:58 AM   #5
mfractal
VAG Survivor
mfractal's Avatar
40
Drives: E90 335i
Did you install new decoupler rings with the new injectors ?
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
      02-23-2020, 09:28 AM   #6
ey2001
ey2001's Avatar
310
Yes I know but who knows if that one new plug is bad... I am just asking because it happened to me... I installed new plugs and cyl 2 was misfiring so I changed it out with my cyl 1 and then I was getting cyl1 misfiring so I took that plug back to dealer and I showed them the misfiring and the receipt and gave me 1 new plug..
      02-23-2020, 09:49 AM   #7
NJQG
I used oem plugs and did not tap them down.
      02-23-2020, 09:52 AM   #8
NJQG
Yea i made sure to use a new decoupler with new injector. Im stumped on what to do next im going to try swapping the plugs around to see if there is any change. Although they are all new?
      02-23-2020, 01:35 PM   #9
badass335
badass335's Avatar
Drives: 2017 540i Xdrive
i'm having the exact same issue. I also have MHD but my car is completely stock otherwise. New plugs were installed a few weeks ago at my dealer. Even before the plugs i noticed the the car would be idling, i'd get a single "jerk' or "stumble' randomly. it started happening about a month ago. i removed MHD completely and still had the "stumble". What i did notice was if i applied load to the car, (climbing a hill, put in 5th or 6th gear manual mode at a low speed and try to accelerate), the car would start to stumble and go into limp mode. the other thing i noticed was at slower speeds and lower rpms, even maintaining a speed at say 1500rpm, i could feel the random "stumble" here and there. I'm going to look at new coils, just because i haven't replaced them for over 100,000kms. Be interesting to hear what your resolution will be.
      02-23-2020, 03:15 PM   #10
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Other possible obvious spots. 02 sensors and MAF cleaning.
IG: @bmwdoubles
      02-23-2020, 05:59 PM   #11
mfractal
VAG Survivor
mfractal's Avatar
40
Drives: E90 335i
Yeah I'd check your coils. This high load low rpm misfire is usually plugs coils or fueling related.
      02-24-2020, 06:42 PM   #12
NJQG
So a small update. I swapped plugs between 3 and 1. The problem followed the plug to 1. I believe what may have happened, was the bad injector somehow fouled up the new plug I put in. I'll find out for sure tomorrow if this works or not.
      02-24-2020, 09:26 PM   #13
badass335
badass335's Avatar
New coils arrive on friday so will test. Hopefully it's not hpfp
      02-24-2020, 10:19 PM   #14
ey2001
ey2001's Avatar
310
Nice! Hopefully that's the issue... because new plug went bad on me too...
      02-25-2020, 08:03 AM   #15
95blkmax
Drives: '11 535 M-Sport
sweet! This is annoying but it's much better than you swapping the coil/plug and it STILL being on cyl3 lol. Best of luck!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      02-25-2020, 09:16 AM   #16
NJQG
Thanks. I definitely hope this does the trick. I been driving my 9" lifted sierra so I've gotten really friendly with the local gas station.
      02-26-2020, 06:07 PM   #17
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Nice, kinda a wide variety of cars you got there... nice.
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      02-28-2020, 06:33 PM   #18
badass335
badass335's Avatar
Did your issue get resolved? I installed new coils and all still having issues. And randomly getting Super Knock on cylinder 6 now too. Removed mhd and running stock but still getting misfires on cylinder 3. Moved coil and plug to cylinder 1 and still having misfire on cylinder 3. Might order new injectors and have bmw install them for me anyways.
      02-29-2020, 01:36 PM   #19
NJQG
Yea I finally got my issue resolved. After a the new injector the spark plug was still useless. After swapping in a new one all is well.
      04-15-2020, 03:13 AM   #20
manleykeedan
Drives: odui a7
Car was running MHD stage 2 when it first started to get the misfire. Changed all the plugs as well as new coils. Problem still on cylinder 3. Next i figured maybe i'd try the fuel injector. Changed that and had it calibrated. Still same issue on cylinder 3. I also set the tune to stage 0. Just to see if it would by chance help it did not. I'm lost on what to do so any help or direction would be greatly appreciated. Car has intake, charge pipe, intercooler, and catless dp if that makes Speed Test Scrabble Word Finder Solitaire any difference.
      03-27-2021, 02:09 PM   #21
robinjamess
Drives: bhw a4
TcsWebmail DadeSchools Upsers
      03-27-2021, 02:15 PM   #22
badass335
badass335's Avatar
I use to have the same issue. Prelude to injector failure. I replaced all my injectors and problems went away. It is still possible yours may need a carbon clean depending in mileage but for me, new injectors and new plugs solved it.
