02-01-2022, 04:02 PM | #1 |
Rep 2
F11 GPS problem
Hi to all.
Searched all over the place and can't find solution. OEM navigation stopped to work properly, 20-30m off. Rarely it shows exact position and direction of traveling. Tried to update maps to latest, tied to go in circles and eights to try to calibrate. Checked with ista and no faluts. Bought some cheap gps antenna and connected to nbt to check but probably not good and nbt shows antenna fault. OEM antenna connected and immediately shows all parameters like before. Here are some pictures attached from mine and from my friends G11. Gps tracking shows major difference and don't know if is it problem in antenna or nbt? Someone had same issue? |
02-10-2022, 02:43 PM | #2 |
Rep 3
Same EXACT problem
I have the EXACT same problem. Navi was working OK until two days ago. I've tried everything I've found on the web. No change. Please let me know if you have any success.
