2010 2011 BMW 5 Series Forum F10 What should normal coolant temperature be? |
09-06-2018, 07:09 AM | #1 |
Rep 364
Hi,
I've been monitoring the coolant temperature in my 520d for a few days, no matter how hard i push the car, in excess of 70mph i cannot get the coolant temperature to exceed 88degrees c. is this normal? I would have expected at least some sort of increase whilst the car was being really really pushed, but nothing! wondering if I ought to change the coolant temperature sensor thanks |
09-07-2018, 02:53 PM | #2 |
Rep 81
Drives: 2015 528i xdrive M-Sport
I recall reading the BMW sets the cooling system to run the engine cooler the harder it's pushed (relative to operating temp). Lean cruise under light throttle typically runs hotter for better fuel economy, run leaner = run hotter. This is all gasoline related though so not sure how the diesel motor cooling system relates.
09-10-2018, 01:17 AM | #4 |
Rep 364
You can enter the diagnostic mode on the cluster (I have the 6wb panel, may be different on others)
So I shouldn't be worried it temp not going above 88? I remember in my golf when the temperature wouldn't go above 78 it turned out to be a faulty temperature sendor, made a massive difference in fuel economy too |
09-10-2018, 11:19 AM | #5 | |
Rep 15,858
88C is the opening temperature for the diesel thermostat. Running ~88C is right on the money, if the cooling system is efficient. |
09-10-2018, 11:21 AM | #6 | |
Rep 15,858
