2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Code 2TB on a 205 F10
      06-30-2016, 02:45 PM   #23
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
I don't think there is any added benefit to this mod, I am pretty sure that this only applies to N63\S63 motors from what my dealer was telling me when I asked why the 2012 535i I traded in for the 550 did not have it. Just go into sport mode and hold the DSC button for around 10 sec and have fun!
      06-30-2016, 03:49 PM   #24
tjwomer
Drives: 2013 535i
When it claims you need to go back in and code new FA's, what are you actually looking for in each of the different ECUs?
      07-01-2016, 10:40 AM   #25
Sunny 528i
Drives: 2012 528i
Before when i put the car in sport mode and tried to deactivate the traction, it would kick it back to comfort
all good now with sport+
      07-01-2016, 10:48 AM   #26
Stück
Stück's Avatar
I myself love the shift paddles and use them frequently. I have a few complaints with them though.
If you don't have the shifter kicked over to M/S it will still upshift for you. Sometimes it upshifts for you at the same nanosecond you upshift, resulting in skipping 2nd gear and going to 3rd for example... this has happened a number of times and its annoying because 1--->3 is slooow.
The other thing is that when you're negotiating a tight turn, or sliding with some opposite lock its difficult to use the paddles as your hands aren't likely to be in the correct position.
As someone that has only ever owned manual vehicles in my life I have to admit the paddles make an automatic car at least a little fun. Before I coded 2TB and added the paddles spirited driving was kinda lacking any excitement.
      07-01-2016, 02:20 PM   #27
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
      07-11-2016, 10:03 AM   #28
LOZ535DGT
Drives: 335D F31
Originally Posted by quicksilv86 View Post
It works!
You have to code new FA (as explains the pdf file attached above) in 4 ECUs :
-EGS,
-GWS,
-Kombi,
-ICM.
Do you mean you have to do page repeat page 16 for each of those ECUs?
      07-11-2016, 01:26 PM   #29
Sunny 528i
Drives: 2012 528i
Yes, once you have complete the first step of adding 2TB in VO, removing 205 in VO and saved new FA, go back to each of these 4 ECU folders under the coding menu in E-Sys and right click and code, do not right click on the under laying CAFD files. In my case i could only code 3 of the 4 ECU folders as one of the ecu folder didnt allow me to select "code" option.
      07-18-2016, 11:09 AM   #30
RmanuelC
Drives: BMW F10 M PACK 520D
Originally Posted by MWPos View Post
FA (VO) Replace 205 with 2TB.
Code new FA in ECUs EGS, and GWS.
Simple as that, and no new software for the gearbox, but I never noticed faster shifting times...this did change the display mode to be S1, S2, S3, etc.
Hello, I need help to activate sport+
I have a f10 2012 without paddle shiffers.
I code icm, kombi and egs.
I can see a sport+ on kombi but the car dont leave select it.
whats the problem?
Thanks
      07-25-2016, 02:16 PM   #31
thommo599
Drives: F11 LCI 530d Luxury
Just out of curiosity adding 2TB would this give you launch control too?
Or is that part of the mechanical side of the gearbox?
Thanks
Ian
      07-25-2016, 02:26 PM   #32
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Thanks
Ian
No. Launch Control is in EGS, but 2TB will not automatically set LC to aktiv.
      06-23-2017, 08:51 PM   #33
JMack2688
Drives: 2011 BMW 535xi
Does anyone have experience with this. I don't even have the rocker switch on my 2011 535 xdrive. I bought a superset one from ebay. Any help ? I'm new to BMW but not working on cars. I'd rather not do this myself. Thanks
      06-27-2017, 07:15 AM   #34
Surly73
Same specs as mine. I changed 205 to 2TB at one point, I believe. For me it changed DS to S1, S2, S3 and that might be about it. My transfer case was replaced under warranty and required coding and my 2TB (and all other coding) was lost. When I recoded I didn't both with 2TB.
I'm working on a retrofit to an LCI steering wheel with paddles so I will likely be putting 2TB back in to get the paddles to work.
I can't say I observed any different behaviour of the transmission in terms of shift points (i.e. what RPM shifts were performed) or shift program selection (i.e. what shift profile/program was used for shifts of various levels of aggressiveness).
[ After getting my M Performance Exhaust I became aware that there's three major shift programs/types - a slow and lazy automatic shift, a faster shift that sounds almost like a manual transmission and a DCT-style "brap" shift. I sure wouldn't mind if I could code a preference for more aggressive shift programs in general. ]
      04-02-2018, 07:41 AM   #35
damascus7
damascus7's Avatar
Poland
Drives: 535i F10
Any clue what to code when adding a rocker switch with comfort/sport option into 07.2011 f10 535i without 2TB. What about wiring and socket plug? Any DIY?
      04-26-2018, 07:18 PM   #36
etnsandman
Drives: 2015 M5 Competition
I have found an easy way to code sport transmission. BimmerCode has added it. After getting my car ungraded to the latest iStep last week at the dealer I was recoding the car to my preferences and noticed they’d added transmission coding. Love the faster shifts paired with MHD stage 2.
The traction struggle is real....
      04-28-2018, 03:50 PM   #37
Surly73
I noticed absolutely no difference in behaviour on my 205-equipped 2011 535xi after coding to 2TB. When I first did it, I actually reversed it since it didn't do anything for me. I put it back when I retrofitted paddles late last fall and 2TB was part of the equation to get them to work. Note that I don't have a COMFORT/SPORT switch either.
As part of other warranty work I also got taken from a 2015-era istep to the latest in February and I noticed some changes in 1-2 and 2-3 shifts when really on it (i.e. the most aggressive shift program). When I refit my M PE for the summer I'll be listening to the sound of those shifts to see if I can further tell what's changed.
      09-18-2018, 03:30 PM   #38
the_vermi
Drives: 2013 528i
Can anyone help me out here?
I have coded the following via Bimmercode:
ICM/3000 ICMKOD_B_SPORTLENKUNG nicht_aktiv ===> aktiv
KOMBI/3000 FDS_MENUE_TEXT_1/2/3/4 menue_4 ===> menue_3
KOMBI/3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_4 ===> menue_3
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
EGS/3000 Applikation -> LC -> aktiv
SAT is enabled and working fine. I can see Sport+ when I hit the rocker switch, but I can't actually select it. The highest I can go is Sport. When I try to switch up to Sport+, nothing happens.
Did I possibly overlook something?
      10-22-2018, 09:49 PM   #39
SonOfAnakin
El Conquistador
Drives: 2015 535i xDrive
I have found an easy way to code sport transmission. BimmerCode has added it. After getting my car ungraded to the latest iStep last week at the dealer I was recoding the car to my preferences and noticed they'd added transmission coding. Love the faster shifts paired with MHD stage 2.
Does the BimmerCode addition also enable Launch Control? That's really the big reason to enable this, in my opinion. Would like to know before I pay for BimmerCode. Already paid for Carly, unfortunately.
      02-29-2020, 05:17 PM   #40
Henndryk
Drives: E32, F11
Hi guys, i've readed whole threads and im trying to add sport+ to mines F11 3.0 d pre-lci.
What done i wrong?
I've coded VO, changing 205 to 2TB, and coded ECU's are
-EGS,
-GWS,
-Kombi,
-ICM
In CIC menu i can see only SPORT, and nothing more.
Got SAT, when i pull lever left i got S1-S7, but still don't get SPORT+
I've done those steps:
205-> 2TB done, FA overwrited to my car,
Loaded FA, Activated VA
Right mouse click at Ecu's writed above, coded and i can't saw sport+
Can anyone help me?
      03-24-2020, 10:47 PM   #41
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
What done i wrong?
-EGS,
-GWS,
-Kombi,
-ICM
Can anyone help me?
Did you ever figure this out?
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster.
      08-02-2020, 07:30 PM   #42
mharper76
Drives: 2014 535i
No GWS?
Did a bit of coding today on my 2014 535, following your instructions for enabling sport+... I was able to code -EGS,-Kombi, and -ICM but GWS doesn't have a coding option, is that normal?
I tested and Sport+ does enable and seems to work just fine; just wondering if GWS was necessary?
      08-03-2020, 02:49 PM   #43
Did you remove 205 an add 2TB to the VO?
      08-03-2020, 04:54 PM   #44
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Yes, GWS not having a CAFD is normal. Some have one, some don't, no one really knows why but it's perfectly normal. I think it's the same thing for the EGS.
2015 BMW 535xi
ISTA VM Setup/Tutorial
