2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone mounted original M5 343M 20" rims on an F10/F11
      03-16-2021, 05:57 PM   #155
gr8brwnshark
Drives: 2013 BMW 528i, 2006 BMW X5
2013 BMW  [0.00]
Bringing this back because I think I accidentally bought m6 343m wheels for my f10. Downsized the tires from 295 to 285 thinking this would've made it more flush but it still sticks out quite a bit. The car rides smoothly and I usually never have many people with me so rubbing isn't an issue. Is it safe to keep running this set up?
      03-16-2021, 08:47 PM   #156
Unspec
Unspec's Avatar
Drives: 2015 BMW 535xi
Those are either M6's or reps with non-OEM offsets. I thought it was the angle in your other photos, but with these photos I can 100% say that no way they're genuine M5 343's. Even your front wheels are poking a bit. They should be safe to run, your paint will suffer tho because of how much they poke out of the wheel well.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-16-2021, 10:07 PM   #157
gr8brwnshark
2013 BMW  [0.00]
Thanks for dropping in and checking the pictures out for me again. Super disappointed that I didn't catch this sooner when I bought them but I took the sellers word. I haven't had any issues with the paint yet, it's been a few months, but maybe I might find out down the road.. I just got new Michelin tires today which weren't cheap so I do need to stick with the setup for now. Feels a bit uncomforting to not have any idea on what the offset and wheel widths are now after doing much research.
      03-17-2021, 01:23 AM   #158
Unspec
Unspec's Avatar
Stick a tape measure through the spokes to measure the barrel width. If it's 9.5 and 10.5 front and back, then at least you know they're probably M6 wheels and you'll know the rough offsets. Where did you buy them from? Forums?
There's really no reason you can't unmount the tires and mount them on M5's, the tires will fit fine. You'll just need to go through the hassle of selling your old wheels.
2015 BMW 535xi
      11-26-2021, 03:31 PM   #159
lucid21
Drives: 2014 6MT M5 Comp
I just bolted on OE 343M wheels to my 2011 550i MSport with stock suspension for a test fit.
Tires are 305/30/20 and 275/35/20.
No need for spacers anywhere. There are about 5-6 mms to the front caliper from the rim center/hub. I don't see the caliper deflecting that much under load. I tried a few hard stops and no marks on the caliper or rim.
I think the 343m rims are perfect for this car as is. The 305 tires seem like they *may* clear the fender if camber changes favorably under compression but I did not drive the car long enough with people in it to test. I see that some posters reported 295s rubbing but not sure about the F10 model (and if the hub spacing is different on a 550i compared to other models). I am planning to go with 295/30 and 265/35. I will have the rims finished back in OE machined silver first; don't like the all black look.
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
      12-26-2021, 10:49 AM   #160
lucid21
I had the wheels powder coated champagne. Looks much better than black. Winter tires on; 265/275. These wheels are perfect for the 550 and will also look good on my M5. And, yes, I can actually feel the weight difference compared to the OEM 20" cast wheels.
      12-26-2021, 10:37 PM   #161
Blue Angel
Blue Angel's Avatar
265/275 combo looks better than 275/305 combo in my opinion. The wider setup definitely pokes a little.
      12-27-2021, 10:38 AM   #162
lucid21
Agreed. 265/285 would also look fine. 275/305 was too much indeed.
      01-13-2022, 01:43 AM   #163
MuonShowers
Drives: BMW 535i M Sport
M5 343M wheels are a perfect fit for the 535i M Sport. For the aesthetics of matched diameter and sidewall height I chose 255/295.
Front: 255/35/R20
Rear: 295/30/R20
2011 BMW 535i 6 Speed Manual RWD in Titanium Silver Metallic and Black Nappa Leather Interior with M Sport Package Premium Package 2 Chrome Delete
20" M5 M Double Spoke Forged Matt Black Wheels Front: 20X9J ET34 Rear: 20X10J ET34
Pirelli P Zero (PZ4) ALP Front: 255/35/R20 Rear: 295/30/R20
      01-13-2022, 09:56 PM   #164
Blue Angel
Blue Angel's Avatar
Front: 255/35/R20
Rear: 295/30/R20
How much rear camber do you have? Looks like a lot but it's hard to tell for sure from that pic.
What tires are those? They look pretty stretched for a 295 on a 10" wheel.
I ask because your fit looks great, but most people with 295 rear on 343m have rubbing issues and have to add camber to clear.
      01-16-2022, 04:11 PM   #165
MuonShowers
They are Pirelli P Zero (PZ4) Alpina homologation, and I just took a look at the service receipt for the alignment and it doesn't have the read outs but I remember looking at their screen and they were within factory specification. Maybe it's because the Pirelli has a smaller section width and tread width than something like a Michelin Pilot Sport 4S even though they are both size 295/30/R20.
      01-16-2022, 05:36 PM   #166
MuonShowers
      01-16-2022, 10:25 PM   #167
Blue Angel
Blue Angel's Avatar
Aha! You did exactly what I was going to do - head to Tire Rack for some stats, I presume?
Well, using a narrow 295 is obviously a great fitment on 343m!
Copyright ©2000 - 2022, vBulletin Solutions Inc.
