2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes would 550i rear brake fit 528i rear brake?
      05-26-2016, 09:04 PM   #1
tofuflower
Drives: 528i
Hi all,
Been trying to figure out would the F10 550i rear brake fit the F10 528i(N20).
Does anyone know if this is possible?
Are the calipers the same? just different rotor size? if just rotor size different.
Does that mean all i need is to change the rotor disc?
Thank you in advance!
Sorry all I can find is topics about the M5 brake switch.
      05-26-2016, 10:35 PM   #2
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
doubt, check realoem.com
check the part numbers.
      06-07-2016, 07:48 PM   #3
snj1013
Drives: 2011 528i
Different sized rotors require different sized calipers and pads. I'm sure you would need to change them all. Also, the larger rotors won't clear 17" wheels. I'm sure you have larger wheels if you're considering a brake upgrade, but just another point.
      06-22-2017, 01:06 PM   #4
mr-crown
Drives: 2013 535i Msport
I'm running APEX 19' wheels. Although my car came with the Msport package and the stock wheels were already 19's.
