2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications CATLESS downpipe & o2 question.
      07-12-2019, 09:25 AM   #1
NYC535iowner
Drives: 2013 535i X-drive
Please HELP
I wanted to ask for the people with the catless downpipe on their cars.
I have heard about installing a spacer on the o2 sensor.
I wanted to know how many of you have done this or should I just install the catless downpipe without any o2 sensor spacer.
13'- F10--> Work in progress: V-Style front lip, HAMANN roof spoiler, M5 grill, high kick trunk spoiler, H&R sport springs, C-quence Drilled front rotors, VRSF Catless DP, VRSF charge pipe.
      07-12-2019, 11:37 AM   #2
ziekxq
Drives: 2011 535i xDrive
I have the o2 spacer and there is no check engine light and all emission systems show ready. Plus, I just passed my emissions test in Illinios.
I do get check engine light during winter but very rarely due being extremely cold weather here.
      07-12-2019, 12:06 PM   #3
NYC535iowner
do you have any piggy back to go with the setup or just the catless downpipe. I am just worry that when I install the JB4 + the catless downpipe I will have to be replacing the o2 sensor often.
      07-12-2019, 01:30 PM   #4
ziekxq
I ran jb4 with catless dp and o2 spacer for 2 years than went MHD. Still on original o2 sensors at 105k.
You only put o2 spacer on the down stream so when the exhaust gases are leaving the downpipe the second sensor is spaced out and it reads normal readings.
      07-13-2019, 07:57 AM   #5
BMW535iva
Drives: M5
Where can i get the spacer?
      07-14-2019, 07:45 AM   #6
NYC535iowner
Same question.
Also what happens if I run the catless downpipe without the spacer?
      07-14-2019, 10:45 AM   #7
ziekxq
I will have to search this for you because I bought my downpipe used that already came with the sapcer.
If you dont use spacer than you will get check engine light and emission will show that catalytic converter is not ready.
      07-14-2019, 10:54 AM   #8
ziekxq
Looks like this should do it:
https://www.google.com/aclk?sa=l&ai=...Q2CkISA&adurl=
I would message the guy and make sure it fits.
      07-14-2019, 11:01 AM   #9
ziekxq
I read that L space spacer is better:
https://www.google.com/amp/s/www.uro...-sensor-spacer
You can search cheaper onew on ebay or amazon probably.
neejay7.00
      04-13-2022, 09:10 AM   #10
aumazdelete
aumazdelete's Avatar
Drives: 2012 BMW 535 xi
Quick bump
At what point does an o2 sensor usually go bad. Does anyone know how many total o2 sensors there are and how much they cost? I have 103k miles on my car and thinking if I should just replace the O2 sensors
Also will this spacer do or is there a better one ? https://www.google.com/amp/s/www.uro...-sensor-spacer
      06-19-2022, 02:19 PM   #11
BuiltnBoostedZ
Drives: 2012 535ix
Originally Posted by aumazdelete View Post
Quick bump
Youll throw a code if the o2 goes bad. They aren't expensive if you shop in the right place. I use rockauto.
