09-03-2020, 09:55 PM | #1 |
Rep 109
F10 550i 2011
Hi guys, i have engine replaced from BMW less then 200miles, doing well but i have rough idle and tonight i check errors with Bimmer Link and i have following codes and when trying to ears them its giving me error that cant clean codes(tried with ignition on, with engine running and without..) Please help
https://ibb.co/KFHQTdM |
09-04-2020, 11:41 AM | #4 | |
Rep 1,261
09-13-2020, 05:39 PM | #5 |
Rep 150
When I had my engine replaced by BMW they fucked up so many things: top engine cover was MISSING, wiring and vaccum hose was all loose, had missing bolts, torn undercover, dented door liner, coolant reservoir started leaking bad, trans-engine join point rubber plugs were missing (open to environment).
Just take it back and make them fix every little fucking thing. |
S1nner126.00 OnlyGerman362.00 |
09-24-2020, 12:26 AM | #6 |
Rep 3
Any update?
Any update on this? I have the EXACT same codes showing in bimmerlink, but they’re permanent and they won’t let me delete them. Rough idle, random misfires, etc
09-24-2020, 01:31 PM | #7 |
Rep 1,356
Record a video with the issue and show it to them. Give them details as well like cold start, only at night or after a long drive, etc.. It will help them to duplicate the issue. If they can’t duplicate it, they can’t fix it especially when the car is at the BMW and it runs fine.
11-27-2020, 10:26 PM | #8 |
Rep 109
No update on this another $2k to different mechanic shops changes bunch of different parts but Car still acting weird when going 60mph and pressing 25-30% gas pedal you can slightly hear rubbing noise and when its 90-100mph you can hear that noise more clearly, its sounds like wheel is out of balance or some bad tire...
Also i forgot to mention PERILLO BMW who did all work on car also change Flex Disc(Guibo) so last shop told me that it is 100% poorly installed Flex disc... (after their work vibration come less but still can fell it and hear it) No check engine no errors on dash only this rubbing sound... (I took off my r20 wheels&spacers, changed wheels&tires to stock r19, no difference) please help if anyone know wtf is this... im about to sell this nightmare car or just drive it until its die on road... Last edited by BBHMM; 11-27-2020 at 10:41 PM.. |
