2010 2011 BMW 5 Series Forum F10 MHD vs Bootmod3 - up/out-dated map tables |
07-12-2020, 08:22 PM | #1 |
Rep 68
Drives: 2011 535ix M-sport
I am still going back and forth about which one to get. I know that MHD has been updating features of their tune over the past 2 years, but I don't believe seeing any update to the mapping tables. I searched through Facebook and Google for the N55 PWG updates and it seems the same map is being used for the last two years.
Bootmod3 didn't update anything for two years, then earlier this year they updated the maps, in which they and F10 owners here have said gives smoother power delivery. I am stuck with the 172 tune since I am an early 2011 F10 (I believe 172x is for later N55 PWGs - correct me if I'm wrong). I'm not planning to go methanol injected or using E85 on a daily basis. This is my daily. So, I am starting to lean towards bootmod3 since they did update their tables recently. Am I missing something or has MHD updated their (fuel/timing/boost/vanos, etc.) maps too?
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
07-13-2020, 05:53 PM | #2 | |
Rep 688
2014 Carbon Black 535i M Sport - Bootmod3 / M Performance Exhaust / Carbon Graphite Vorsteiner V-FF 103 / KW V2
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
OnlyGerman362.00 |
07-13-2020, 06:06 PM | #3 | ||
Rep 1,261
07-14-2020, 12:42 PM | #4 |
Rep 68
I already ordered the MHD wifi flasher adapter, but I am starting to lean towards bootmod3. I appreciate your feedback.
I remember reading how someone read the tables, comparing bootmod3 and MHD. They said there were more tables in bootmod3. I remember in the older cars when I would read performance chips, there were only two tables, part and full throttle (older throttle sensors had only open or closed signals). So, if there are more tables mapping the power, this could make the tune smoother, better power, and the tune does more of the work to adapt to different factors (intake temp, load, etc) instead of extending the ecu's adaptations.
07-14-2020, 05:21 PM | #5 | |
Rep 1,261
08-31-2020, 12:29 PM | #6 |
Rep 68
An update. I went with Bootmod3 and don't regret it one bit. I built my own wifi agent finding the instructions online. Tons of power and a newer Coyote engined Mustang got surprised on the highway (in Mexico) that he could not pull away from me. Only limiting factor was the PWG turbo upper end and shifting at 6k rpm.
What I liked with the BM3 is I recently did all the stage 0 prep within the last 5k miles, coils, plugs, charge pipe, filters, trans filter/fluid, turbo control valve (solenoid), water pump & T-stat, rear guibo, diff bushing, and switched to LiquiMoly 0W-40 engine oil. I was able to first load the MPPK tune to ensure everything worked well without any codes or drivability issues. After a day and some shake down tests, I went to Stage 1 and the trans tune. The transmission shifts much better and I don't notice the gears changing. Then two weeks later I installed the ebay FMIC and I did the same thing using MPPK first, then Stage 1, checking for any boost leaks with logs. Of course, now that I know what this engine can do, for my daily driver I am thinking of a Pure Stage 1 upgrade and with my early N55 HPFP shared with the N54, it should make some good power in all rpms and maintain the same drivability around town. And so the bug continues to bite.
OnlyGerman362.00 |
08-31-2020, 04:26 PM | #8 |
Rep 68
It depends on what you are defining for linear?
Power application: It has a smooth power delivery and the logs confirm it. In lower load scenarios, it behaves like stock. In the upper RPMs, it's still smooth, but the turbo is limiting the power. Pedal: if you are talking about the pedal input, where you can adjust the pedal to throttle body, it does not have the option to be linear. In my Comfort setting, the throttle opening ratio is slower which is good. In Sport mode, the ratio is faster, yet still smooth. It works very well. Many people use bootmod3 with XHP. For my purposes and goals, today, the bootmod3 trans tune is very good increasing line pressure, removing torque limiters, and shifting faster yet staying smooth. The downshifts were harder with the stock trans software. Bonus is this trans tune comes with the OTS bundle.
08-31-2020, 06:25 PM | #9 | |
Rep 965
09-01-2020, 09:57 PM | #10 |
Rep 194
Had BM3 for about a year, was at first happy with it but then started noticing drive-ability issues. Going from partial throttle to off it would sometimes judder, almost as though the fuel cut wasn't immediate. Took the car on a road trip to pikes peak, flashed to the 91OCT tune to cope with their fuel grade and elevation and the car didn't like it, would stumble and miss occasionally at full throttle.
I've since flashed to MHD and none of the issues I had with drive ability are present. The initial decel when letting off the throttle is more pronounced, similar to how the car is stock which solved the decel juddering issue. Performance is very similar, but personally MHD feels more refined. Will be trying out MHDs PS2 map in the next 2 or 3 weeks when I throw the bigger turbo on. |
09-02-2020, 12:26 PM | #11 | |
Rep 68
What Stage were you running and how many miles on your engine?
09-02-2020, 10:21 PM | #12 | |
Rep 194
Tried all the stages available, and all had the same issue. Started off with Stg 2 93 Oct, 91 Oct, then down to stage 1 etc. Only tune that didn't do it was the M2 tune, which was the first clue it was tune related. Currently on MHD Stg 2+ 93 Oct and its as smooth as stock, but with more power. Ill really put it to the test once the PS2 goes on... Car has been proactively maintained by myself and currently sits at 78k miles oil changes every 4k miles since I got it at 27k miles (I know, I know...overkill) one step colder NGK plugs every 20k ignition coils changed at 50k Trans fluid and filter done at 50k and again at 70k and the list goes on. **Not bashing BM3, I think they make a good product overall and are quick to reply to customer inquiry's, just wasn't a good match for my car for some reason. |
09-27-2020, 11:36 AM | #14 |
Rep 68
Reasons why? Could you elaborate? Thanks
09-27-2020, 03:45 PM | #15 |
Rep 1,230
more up to date tables. Bluetooth. Faster map flashing. More options on the OTS. Top tuners are using MHD
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
09-27-2020, 10:19 PM | #16 | |
Rep 68
Overall, I am very happy using Bootmod3 for a stage 1 93oct and the logs show it runs great on my engine. I again really like the M Performance Power Kit (MPPK) OTS option so I can check/log how my engine (and its components) respond to a modest increase in boost before going Stage 1 or 2 and to check/log after doing an upgrade, like the FMIC. I do plan a Stage1 Pure Turbo upgrade sometime in the future and will go custom tune. Again, my early N55 does not have as many updates or tuning options.
09-29-2020, 04:40 PM | #17 |
Rep 1,230
Top tuners out there are D. Shoup, wedge, and Doc Vu who all use MHD. Kevin Baldi is the only one i know who tunes the shit out of n55s on BM3. I had Cary Jordan on BM3 and he was great. But by far hands down David Shoup. Ive flashed over 70x with MHD and also XHP since i got the bluetooth. Everything went smooth. No bricking.
N55 GENERAL
09-29-2020, 11:12 PM | #18 |
Rep 68
Thanks for explaining that for custom tunes.
For OTS maps with how this thread started, Bootmod3 has done very well and is more up to date in their tables with the early N55s.
09-30-2020, 09:24 AM | #19 | |
Joint Chiefs of Staff
24183
Rep 190,777
