2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 550i 2011
      09-03-2020, 09:55 PM   #1
BBHMM
Drives: 550i
Unhappy F10 550i 2011
Hi guys, i have engine replaced from BMW less then 200miles, doing well but i have rough idle and tonight i check errors with Bimmer Link and i have following codes and when trying to ears them its giving me error that cant clean codes(tried with ignition on, with engine running and without..) Please help
https://ibb.co/KFHQTdM
      09-04-2020, 06:13 AM   #2
Wht550jersey
Drives: 2011 550i
Should bring it rite back to bmw
      09-04-2020, 09:16 AM   #3
BBHMM
Drives: 550i
yes but i dont have any CEL on dash or anything like that... just when im scanning, im worried that they will tell me sorry bro everything is fine (it been before with rough idle and old engine always)
O1NE0.00
      09-04-2020, 11:41 AM   #4
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Still I would take it back, especially after such a big job
      09-13-2020, 05:39 PM   #5
windowmaker
Drives: 2013 550i M Sport 6MT
When I had my engine replaced by BMW they fucked up so many things: top engine cover was MISSING, wiring and vaccum hose was all loose, had missing bolts, torn undercover, dented door liner, coolant reservoir started leaking bad, trans-engine join point rubber plugs were missing (open to environment).
Just take it back and make them fix every little fucking thing.
S1nner126.00
      09-24-2020, 12:26 AM   #6
Mandrow7
Drives: 2011 BMW 550i Xdrive
Any update?
Any update on this? I have the EXACT same codes showing in bimmerlink, but they’re permanent and they won’t let me delete them. Rough idle, random misfires, etc
      09-24-2020, 01:31 PM   #7
Hoa
Record a video with the issue and show it to them. Give them details as well like cold start, only at night or after a long drive, etc.. It will help them to duplicate the issue. If they can’t duplicate it, they can’t fix it especially when the car is at the BMW and it runs fine.
      11-27-2020, 10:26 PM   #8
BBHMM
Drives: 550i
No update on this another $2k to different mechanic shops changes bunch of different parts but Car still acting weird when going 60mph and pressing 25-30% gas pedal you can slightly hear rubbing noise and when its 90-100mph you can hear that noise more clearly, its sounds like wheel is out of balance or some bad tire...
Also i forgot to mention PERILLO BMW who did all work on car also change Flex Disc(Guibo) so last shop told me that it is 100% poorly installed Flex disc... (after their work vibration come less but still can fell it and hear it)
No check engine no errors on dash only this rubbing sound...
(I took off my r20 wheels&spacers, changed wheels&tires to stock r19, no difference) please help if anyone know wtf is this... im about to sell this nightmare car or just drive it until its die on road...
