2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 catch can
      11-17-2019, 06:48 PM   #1
N55 catch can
Has anyone installed a catch can on an N55? I just purchased one off of Amazon (https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1) and was curious how to attach the outlet hose to the intake tube (the one with the electrical connection). It looks like the "flex" portion of the tube just slides onto the connection, but in my experience it isn't that easy! I will probably buy a replacement breather/vent tube in case I break the stock tube. I will also most likely need to reinstall the stock tube to pass smog.
TIA
      11-17-2019, 08:34 PM   #2
E92TTCoupe
Drives: x335i/x550i/x640i/x540i/c750i
Interested in this. Keep us posted!
      11-19-2019, 10:07 PM   #3
Grrrrrr...….
I bought this off of Amazon on the recommendation from a purchaser on a forum I can't remember...
Seems the ports on the can are 5/8" NPT to 3/8" for the hose and the factory hose is 3/4". Do you think I can fine a 5/8" to 3/4" barb? Not so far! I hope I can return this can and get one with the proper connections. Good thing I bought 2 extra factory tubes!
      01-04-2020, 12:50 PM   #4
At this point I'm throwing in the towel. I refuse to pay $200 for the quasi-direct fit unit and I'm having little success at finding a way for the hoses to pass each other without one crushing the other. There's just too little room there. If I could find a short 1" to 3/4" hose with a 45º elbow there may be enough room for the hoses to pass. I'll have to keep looking but for now.....
This project is a no-go.
      01-06-2020, 10:06 AM   #5
burro_blasta
Drives: 2013 535 M Sport
What have seen as far as the usefulness of this in n55s? I know n54s need walnut blasting and/or catch cans but whatever I found makes it look doubtful that this is such an issue with n55s
      01-06-2020, 11:04 AM   #6
When I took the factory breather off to try and install the can, I stuck my pinky finger in the tube to check how much oily residue was in there. After ~56K miles there was a very, very light film on the metal part of the hose that attaches to the downpipe. The film was a light tan color and very thin. I easily wiped it off. I was a bit surprised (and pleased) that there was so little residue in the tube; especially considering part of it is corrugated plastic.
      01-07-2020, 08:27 AM   #7
baconbits
Drives: 2012 535i xDrive M-Sport
My indy mechanic checked my intake valves when he had my intake manifold loose for a valve cover gasket. At 94k and said they were surprisingly clean (just a thin film like you noted) and nowhere near needing a walnut blast. The PCV system on the N55 valve cover works far better than the N54 system so catch cans are pretty much pointless.
      02-06-2020, 07:51 PM   #8
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
How to install A $25 Oil Catch Can
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster.
      02-06-2020, 09:04 PM   #9
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
With how easy that is, throw a breather on the top of the catch can, don't have to worry about hood clearance, good to go.
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      02-06-2020, 09:43 PM   #10
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Lol, I thought about getting a can with a breather, but I thought it might cause an issue with the pressure and the PCV system.
      02-06-2020, 10:34 PM   #11
Originally Posted by Gjohnson7 View Post
How to install A $25 Oil Catch Can...
I've seen that. The thing he doesn't show just happens to be the hardest part; how does one get the two 3/4" hoses to pass in a space big enough for one?
How crushed are the hoses as they pass? Does the restriction cause any issues?
      02-07-2020, 08:33 AM   #12
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Lol, that's my video. I did the install.
Getting those 3/4" hoses to pass each other was the hardest part of the install. They don't seem to be pinched at all or restricted. I am working on a intake cleaning video and I show the blow by the container has collected in only 1500 miles. It's a LOT. I believe I was getting excessive blow by, because of my PCV cap which has now been fixed.
      02-09-2020, 10:52 PM   #13
513
Nice, I commented on your video
      02-10-2020, 07:22 AM   #14
Rob09msport
Drives: 09 335 msport
Could always just upgrade the pcv valve. I wonder if you could find something on thingiverse to print that would work. If you find something that looks good I could print and send it to you. I havent checked myself but you would be surprised. I just printed jack pad adapters for my stands and jack.
      02-10-2020, 08:58 AM   #15
513
What kind of printer do you have? Link?
2011 F10 S55 6MT
      02-10-2020, 02:59 PM   #16
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
What kind of PCV valve upgrade did you have in mind?
Also, you plan on selling any of those jack stand adapters?? Lol!
      02-11-2020, 10:19 PM   #17
SVTruong
SVTruong's Avatar
Drives: '15 428i GC, '15 640i GC
Honest thoughts
So I've been around guys that use catch cans and guys that don't in turbo DI daily drivers, track and drift racers. While it doesn't hurt and everything helps, it's not going to prevent blow by. You will still need to do a valve cleaning periodically every 50-75k as routine maintenance. Because of this, my friends that choose not to use a catch can tell me not to bother. Just sharing what I've seen/been told.
      02-12-2020, 04:48 PM   #18
513
Look at what BMWDoubles just posted regarding the VVT breather... that is why I'd do a catch can.
2011 F10 S55 6MT
      02-12-2020, 05:34 PM   #19
But manufacturers go about PCV systems differently. The N54 was notorious for valve build-up and needs "frequent" walnut blasting. The N55's PCV system was redesigned and doesn't need the walnut blasting the N54 did. In fact, I asked my SA about having it done and he told me they don't do it that often on the N55; NOTHING like the N54. He said they walnut blast the N55 only after all other avenues have been exhausted to solve a driveability issue.
From what I've read VW's are every bit as bad, if not worse, than the N54; Ford isn't much better. I haven't read anything on the other manufacturers as DI is relatively new to them. At least BMW have identified the issue and are correcting it.
      03-17-2020, 02:11 PM   #20
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
have you eventually put one in brother? i'm thinking about going with one of the one's ECS Tuning sells
      03-17-2020, 05:29 PM   #21
I'm waiting for my CPO warranty to expire. We've also been dealing with roof leak repairs. A job that should have taken 2 weeks tops is now in its 5th week! We finally got the carpet installed and are now waiting for a dry day to empty our furniture out of the pod that's been on our driveway since before Thanksgiving!
Anyway, hopefully I'll get it done by the end of next month...
      03-17-2020, 07:27 PM   #22
mangos86q
Drives: BMW 535i X drive
Clean install
https://youtu.be/nOSly841qVw
