2010 2011 BMW 5 Series Forum F10 Camera Calibration or something else |
07-26-2023, 12:17 PM | #1 |
Rep 255
hey guys, my all around vision camera system is somewhat malfunctioning. Please see the video below, it works but it feels like the camera's are pointing the wrong way.
https://www.youtube.com/shorts/77kFd5-REYM In the video I am going in Reverse, but it feels like the car is moving forward. At the end i'm turning my front wheels full left then right, and you can see them on the screen! I have used ISTA to initialize them and calibrate them, but still not having any luck. Thanks for any suggestions! |
07-28-2023, 12:12 PM | #5 |
Rep 255
Yes, I installed new mirrors that came with their own cameras.
I re-used mine and it still didn’t work, the view is the same with mine or donor car lens so it’s probably not the cameras themselves. |
07-28-2023, 02:09 PM | #6 |
Rep 1,509
So your vehicle came with camera on mirrors and it had this issue prior or it happened after you did the swap? You swap both or just one? Was your mirrors damaged or something?
07-28-2023, 08:28 PM | #7 |
Rep 255
Yeah my car came with the full camera system from factory, and it was working perfectly fine before, zero issues.
I swapped for m5 mirrors, from 2015 with the same system. I used my oem cameras, I used cameras that came with it and same issue persists. |
07-30-2023, 07:27 PM | #10 |
Rep 255
Flashed the module, all went well and no change.
Cameras are still wonky.. next step will probably be taking the mirrors apart and trying to swap the cameras from left to right and right to left. |
08-01-2023, 12:07 AM | #12 |
Rep 255
Happy to report that problem is solved!
I switched the camera left to right and that didn’t really help much, slightly better but still not normal. Assembled the mirrors back and went into coding values of the TRSVC, found this entry and changed it from f10 LL and f10RR to newmirrorLL and newMirrorRR. Working perfectly now! I’m case anyone retrofits mirrors or installs different ones from a used car, most likely they will need this coded to work. Orientation of cameras doesn’t matter, the part number on them looked the same to me. |
08-02-2023, 08:26 PM | #13 | |
Rep 26
