2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Need some advice on wheels
      05-26-2019, 03:15 PM   #1
maciasstrong
Drives: 2016 535 M Sport
Hi All,
Looking for some advice here... I have a 2016 528i M Sport package but want to put some nice wheels on instead of the stock 18 msport wheels that it came with. Im looking at some Niche Vosso 203 ?
Wanted to understand from those who have gone to a 20 inch setup, the experience you have had:
1) Was there a significant difference in the ride quality?
2) Was performance impacted noticeably (e.g. acceleration, handling, etc)? For better or worse
thanks for any advice
      05-26-2019, 04:47 PM   #2
Originally Posted by maciasstrong View Post
Hi All,
The stock M-Sport wheels should be 19", AFAIK.
A heavier wheel will degrade ride quality. It will also negatively impact turn-in as well as during transitions. You may also lose significant sidewall impacting (no pun intended) the ride. That said, I've put many an aftermarket wheel on my cars and, IMHO, sticking with the manufacturers wheel, no matter the size, is the way to go. Suspensions are designed with the wheel/tire weight combo taken into consideration.
      05-26-2019, 06:52 PM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
if anything from pure aesthetics the 20" wheel will look nicer. Performance shoud be better since you won't have so much sidewall roll
      05-26-2019, 07:26 PM   #4
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I do believe that 528i (as well as 520d, etc, in Europe) also came with 18" M-Sport, listed as 350M style. Similar wheel design to the 351M wheel style that is for 535 & 550 F10s that are 19", but with seven double spokes. Check out this link for F10 OEM wheels.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      05-26-2019, 08:21 PM   #5
maciasstrong
thank you for the info .. yes mine came with stock M35 wheels 18 inch ... just want a little more wheel just wasnt sure if the 20inch would look to big
      05-26-2019, 10:38 PM   #6
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Look at the wheel weight of what you have vs. what you want to buy... lighter is better. If you can't afford forged look at the flow formed/rotary forged wheels. Can get 19 -20" about 20lbs - 25lbs depending on diameter and width of wheels. Cast wheels are likely to be heavier. Also decide if you want a "square" setup with same size all around (allows you to rotate tires so they last longer) or a staggered setup with wider wheels/tires in the rear. Your choices will impact how your car handles and corners...
      05-29-2019, 09:36 AM   #7
ferizzo
Drives: 2016 BMW 550xi M-Sport
I happen to come across this site that shows a 528i M-sport with 20s. I was trying to look at black/gray wheels so came a cross this...thought maybe this would help you decide if 20s are too big (IMHO - 20s look perfect on an F10).
http://www.autofuturedesign.com.my/v...V-FF-105-9.jpg
      05-30-2019, 10:10 PM   #8
WahooSteeler
Drives: 2012 528i xDrive
Maciasstrong, is this your wheel? This is from a 2015 528 MSport. This is 18x8 245/45/18. If so, I would be interested in buying yours if you upgrade.
      06-02-2019, 06:17 PM   #9
maciasstrong
WahooSteeler i will let you know when i do the upgrade here soon ... and thank you all for the info ill upload some pics of my car here in sunny California
      06-30-2019, 09:55 PM   #10
maciasstrong
these came out good thanks for the help fellas
      07-01-2019, 08:19 PM   #11
KEN210
China
Drives: F10/18 - 528
Nice! What is your offset at the back?
      07-02-2019, 01:45 PM   #12
frenchfries1971
Drives: Fiat 500 Riva, Vitara Allgrip
I have a question as well but just joined the forum, I need to post a reply first, sorry
      07-03-2019, 12:18 PM   #13
SoCal550
Drives: BMW 550i
Are those gloss black ? I just did something similar to my 550i with 19's
      07-06-2019, 04:14 PM   #14
maciasstrong
i have 9.5 265 /35/20 in the front and 10.5 in the back with 285/ 35/ 20
      07-06-2019, 04:18 PM   #15
maciasstrong
sweet !! looking car ... yes they are gloss black ... i like those OEM wheels .. but i deceided to do stagger offset makes it looks alittle more sporting .. your looks clean man ... the only thing i would like to do the chrome reflector to gloss back but some of these after market shops want stupid money. happy late 4th fellas
      05-31-2020, 02:01 PM   #16
Kashreem
Kashreem's Avatar
Drives: Bmw 535i
Thumbs up Help
🔥🔥🔥clean i have the same rims hey did i have vibration Becuase when i hit 60 mph it feels shakey i have 255/35/20 and 285/35/20 on the same rims
