2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications David Shoup Tune
      03-19-2020, 11:25 PM   #89
ziekxq
Drives: 2011 535i xDrive
Originally Posted by BrowBMW View Post
I just asked him about which turbo he'd recommend and he said the big boost 3.3, interesting... time to do some research.
That kit is capable of 620whp... I bet you can get 550whp with pump gas on it. I am not going to waste money switching over unless I had a low mileage newer 2016/17 model. But looks like a good option if you going to pay 2500 on pure stage 2 then might as well on bb 3.3 as it comes with almost everything for FBO.
      03-19-2020, 11:29 PM   #90
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
He said he could get the bb3.3 to spool just about as fast as the speed tech kit which, from what I have seen, has less lag than the PS2. But this is reading marketing materials, hard to say otherwise. Maybe I should ask him for some bb3.3 sample data files to see when boost is coming in hard and how many lbs it can run.
      03-20-2020, 07:40 AM   #91
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
It's all in the tune. My ps2 custom tune makes 570 @20psi on race fuel. Big boost customer service is garbage. Manifold is great. Turbo is great. If your xdrive there is no mount for that kit yet so ull run into an issue. Rwd will have no problems.
      03-20-2020, 07:45 AM   #92
$howtime456
301
Drives: BMW 640i
Originally Posted by ramman434 View Post
Did you have to reach out to the site for pricing? I don't see any actual pricing listed.
Also, since they've got it listed for a 525i, I'm assuming that there's not too much as far as chassis differences that all of these parts listed will fit our 535s?
Link from earlier in the thread for reference:
http://ultraracing.my/ecatalog/index...-525-2-5-2010/
THANKS! I'm enjoying lurking on this kinda stuff as I piece together a list of things I want to do down the road as funds become available lol.
Grab the part numbers off the site and find the cheapest way to get em. Mines was amazon
      03-20-2020, 11:07 AM   #93
ziekxq
What cyl timing you running at 20 psi? And is that 570 to the wheels?
Are you running Helix OD?
      03-20-2020, 05:20 PM   #94
ziekxq
Revision 2.5 logs:
1st run:
https://datazap.me/u/ziekxq/v25-1st-...=0&data=4-5-22
2nd run:
https://datazap.me/u/ziekxq/v25-2nd-...=0&data=4-5-22
3rd run:
https://datazap.me/u/ziekxq/v25-3rd-...=0&data=4-5-22
Random logs:
https://datazap.me/u/ziekxq/v25-rand...=0&data=4-5-22
      03-20-2020, 08:49 PM   #95
Bmwdoubles_
Bmwdoubles_'s Avatar
Drives: BMW F10 535
  [0.00]
Rev 1.3 logs
Still a little laggy under 3k rpm. Check out the delta from boost target to actual. At 3k rpm only 10.8 PSI
https://datazap.me/u/bmwdoubles/run-...#38;zoom=0-124
I will say the car fees stronger than it ever has. I'm sure the e50 is a contributor.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg
      03-20-2020, 08:58 PM   #96
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Run 3 looks good. You hit boost much faster than I do. Hope he can correct mine.
      03-20-2020, 09:13 PM   #97
ziekxq
The boost falls off quickly with this new revision but same thing happen previously and he fixed it in last revision so hopefully he can help me hold the boost a little longer till 6200-6300k rpm.
      03-20-2020, 09:18 PM   #98
513
Shouldn't you have more boost than that doubles with your HOD?
2011 F10 S55 6MT
      03-20-2020, 09:36 PM   #99
ziekxq
He just need to bother him a little to get that map lol.
      03-20-2020, 11:42 PM   #100
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Yeah I have my 2.5 tmap right because the 3.5 was giving me errors. We should be able to pull out 20-22psi on the 2.p sensor and we'll go from there. I'm still early in my revision with DS. He's doing good work right now It's just been a bit slow with the back and forth. So in due time, I'm confident he'll have me running strong.
      03-21-2020, 12:31 AM   #101
ziekxq
When I was overboosting I could read up to 30 psi on 2.5bar, so I don't think we need 3.5 bar sensor because we will never be pushing that high.
      03-21-2020, 10:39 AM   #102
$howtime456
301
Drives: BMW 640i
will have to check the logs. im on spoolfx150 pump.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      03-21-2020, 11:56 AM   #103
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
My man, aren't you going single turbo?
      03-21-2020, 02:37 PM   #104
$howtime456
301
Drives: BMW 640i
i have the speedtech kit just not installed yet. Was supposed to get the big boost but juan fucked me due to the motor mount issue for xdrive so im still on ps2 still have some room left to play with now that i fixed my issues and can boost more than 22psi. hoping to touch 600 before we make the swap
N55 GENERAL
David Shoup Tuned
      03-21-2020, 03:34 PM   #105
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Here's my last run with D Shoup. It looks roughly like over 380 whp with these calculations.
442 ft-lb @ 5356Rpm
Look at torque act.clutch nm
https://datazap.me/u/bmwdoubles/run-...8;data=3-14-23
Then convert nm to torque
https://www.metric-conversions.org/e...oot-pounds.htm
Then calculate using rpm and torque
https://spicerparts.com/calculators/...que-calculator
Then multiply 15% drivetrain loss, take that number and minus it from the hp to get your real whp.
Grant it these are very rough estimates without a dyno. It's ok with 17 PSI. Let's see if I can hit this 550whp mark.
We're working on getting power down low since the manual and my hardware is laggy down there.
I'm currently as a fast as a 550i stock or an e90 M3 stock in regard to numbers obviously a time slip will be the real truth or a lap time. Keep in mind I didn't rev this thing all the way out so I could actually be clearing 400whp. There's some hesitation at the top we're also working out so I'll wait to we have that cleared.
I need to crush those 5.0's on track
      03-21-2020, 08:41 PM   #106
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Mr. Shoup coming through today!
Rev 1.5 at 19psi produces a smidge over 400whp
https://datazap.me/u/bmwdoubles/run-...38;data=3-5-14
He mentioned 500whp is going to need more PSI. I'm guessing around 20whp per PSI so maybe 24-25psi to reach 500whp.
We'll see.
      03-21-2020, 08:50 PM   #107
ziekxq
https://datazap.me/u/bmwdoubles/run-...=0&data=3-5-14
We'll see.
From what I have read don't go by torque act MHD as that can be very misleading. I think per Pure 17psi is 400/425whp so 19 would be around 450/480.
      03-21-2020, 09:07 PM   #108
513
That's awesome. I thought that the PS2 with HOD would give you enough fuel to hit higher boost levels. I see you are 1 to 1.5 PSI off of target. Does he expect to be able to pull more PSI out of it?
2011 F10 S55 6MT
      03-21-2020, 09:19 PM   #109
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Yeah we're anticipating 20psi
      03-21-2020, 09:20 PM   #110
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
We'll see.
Are you thinking BHP or WHP? Threw the British phrase in there lol
