11-11-2024, 11:35 AM | #1 |
![]() ![]() ![]() ![]() 202
Rep 904
Should I Buy an Aftermarket Thermostat or an OEM?
My 2015 528i has a check engine light that an independent mechanic said is indicative of a bad thermostat with his scanner. Should I buy an OEM thermostat or should I buy an aftermarket one? I think the mechanic mentioned that if I were to buy it from him he would buy an aftermarket thermostat which starts with the letter 'B'.
11-11-2024, 01:02 PM | #2 |
![]() ![]() 95
Rep 288
They are cheap, buy OEM
ctcarbonari507.00 |
11-11-2024, 01:04 PM | #3 |
![]() ![]() ![]() 507
Rep 389
Drives: 2015 BMW 535i M Sport
11-11-2024, 01:40 PM | #4 |
![]() ![]() 746
Rep 1,628
I would recommend this. They make it for BMW 528i.
https://www.fcpeuro.com/products/bmw...at-11537633476 |
11-12-2024, 12:20 AM | #6 | |
![]() ![]() ![]() ![]() ![]() 2024
Rep 649
Drives: 2016 F10 BMW 535i M Sport
11-12-2024, 11:42 AM | #7 | |
Rep 904
11-12-2024, 11:56 AM | #8 |
![]() ![]() 746
Rep 1,628
They produce it for BMW. They sell it under their own brand without BMW logo so it’s cheaper.
11-13-2024, 02:31 PM | #9 |
Rep 904
Thank you all for the input. Now, when I turned the car on and drove it, the check engine light doesn't appear anymore. I had to cancel the order for the thermostat unit. Do you think I should go through the hassle and get it re-scanned to see if the error code for the thermostat would still be present. Hassle because mechanics are always pissed off.
Has this ever happened to you in regard to error codes or light symbols? |
11-13-2024, 09:20 PM | #10 |
Rep 649
Why did you cancel the order for the Thermostat? I would have the part ready incase the code reappears. When was the last time the Wp was serviced?
ctcarbonari507.00 StradaRedlands6746.00 |
11-14-2024, 10:19 AM | #11 |
Rep 904
I thought the problem was perhaps a sensor error. I will most likely have to attempt to buy it today. I don't know what is meant by "wp."
11-14-2024, 11:05 AM | #13 |
Rep 904
11-14-2024, 08:43 PM | #14 |
Rep 649
How often is it driven? I would get a second opinion or get Bimmerlink and read those codes out to us.
11-15-2024, 11:37 AM | #15 |
Rep 904
11-15-2024, 11:42 PM | #17 |
Rep 649
Once more, Highly recommend you buy a Bluetooth OBDII that supports Bimmerlink or equivalent, and when you take it out for a drive, monitor the WP RPM and coolant temps, and more! So if it does happen again, you can supply yourself with data in relation to such fault.
ctcarbonari507.00 |
