2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum N20B20B engine overhaul
      11-26-2024, 02:38 PM   #1
TSlackM
Drives: BMW F11, BMW E84
Hi, i was lucky to have my engine with 130k km spin one of its rod bearings.
These engines are for whatever reason extremely expensive and hard to get by.
So after a lot of scouting for replacement engine, an overhaul has been decided.
However i need torque specs for essentially the entire engine as most
Of the engine have to be taken a part and cleaned properly to remove metallic residue.
Changing the oil pump also. As that cannot be trusted anymore, and also
Can the oil control valve be trusted? or disabled in anyway to keep max oil flow
At all times?
Regardless, what is most needed is the torque specs for all the nuts and bolts in this engine
Assuming it is similar for both N20 eninges so for either is fine.
Any tips to where to get a hold of or purchase is greatly appriciated.
Cant seem to find it myself.
      11-28-2024, 10:15 AM   #2
TSlackM
Bmw dealer was kind enough to print out everything. So then it is sorted
