2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Car jerks at 8 gear 100-120kmh
      11-27-2024, 08:02 PM   #1
sirudropsmth
Drives: BMW F11
Hello everyone,
BMW F11 530d 190kw xdrive
The problem is when driving at 100-120kmh. The car is running at 1.1-1.3 RPM in eighth gear, when going up a small hill the car starts to jerk, when shifting to a lower gear in manual mode the jerk disappears. This also happens when driving on a straight road, if you start to press the acceleration easily the car start jerking and when RPM is higer than 1.5k RPM it’s all gone. Any ideas? ;(
      11-27-2024, 10:45 PM   #2
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
How many Miles do you have and has the transmission Fluid ever been changed?
      11-27-2024, 10:51 PM   #3
sirudropsmth
Drives: BMW F11
190000miles. Yes, when I bought a car I changed oil at service immediately, after 40000miles changed again.
      11-27-2024, 11:01 PM   #4
ChiltiCoatl89
How small of a hill are we talking? Its not wise to put strain on your higher gears on low RPM going up an incline.
      11-27-2024, 11:46 PM   #5
sirudropsmth
Drives: BMW F11
We are talking about very small hills, 5-10% gradients on the highway. As I mentioned before, this also happens when driving on a flat road with the cruise control activated at a speed of 110 km/h and a gentle press on the accelerator pedal, then the car starts to shake, as if you were driving a manual gearbox in fifth gear at 50 km/h. But like I mentioned before everything gone at 1.4-1.5rpm, or manually put from 8 to 7 gear. Maybe it could be the throttle body when it is almost closed and not enough air?
      11-28-2024, 12:04 AM   #6
ChiltiCoatl89
You do not have any drivetrain codes present?
      11-28-2024, 12:07 AM   #7
sirudropsmth
Drives: BMW F11
No, i don’t.
      11-28-2024, 12:08 AM   #8
ChiltiCoatl89
Have you replaced anything in regards to your air intake? I.E Intake Plumbing and even gaskets and o rings?
      11-28-2024, 12:12 AM   #9
sirudropsmth
Drives: BMW F11
The air intake manifold was removed and washed in an ultrasonic bath. That's all.
      11-28-2024, 12:28 AM   #10
ChiltiCoatl89
How recent was that and any gaskets replaced? When you changed the transmission fluid, were you aware of an adaptation reset?
      11-28-2024, 12:37 AM   #11
sirudropsmth
Drives: BMW F11
Originally Posted by sirudropsmth View Post
about 15000 miles ago. About the gaskets I can’t tell you, because all these jobs do a service which repairs only bmw cars. Yes i know about adaptations reset, this was done after an oil change.
      11-29-2024, 02:10 AM   #12
ChiltiCoatl89
Ignition, Air, and Fuel I would narrow out first.
      11-29-2024, 02:16 AM   #13
ChiltiCoatl89
How do your intake valves look? where they ever walnut blasted?
